Connecting Wii to a DVI-D monitor? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 28 (permalink) Old 08-05-2009, 01:53 PM
Rewindlabs's Avatar
Rep: 202 (Unique: 166)
Originally Posted by Jjangthekid View Post
Thanks for your help. Yeah I have sound taken care of, I'm not totally sure if this will work out. On paper it should but not totally sure. DVI-I is the female part and DVI-D is the male counterpart right? So it should be okay hopefully.
Additionally since there is only one HDMI port for my monitor, is there a HDMI splitter so that I don't have to keep plugging out the HDMI cable from the PS3 to the 360?
http://www.google.com/#hl=en&q=hdmi+...fp=-Pw1cEIpNGU
Google will be your best bet...as long as your careful with your cords i would just save the cash since there is 100+$ general price on hdmi splitters im seeing...
You could buy this
http://www.amazon.com/HDMI-Splitter-.../dp/B000FMJLQC
and just keep an hdmi cable in both your ps3 and 360 and leave the splitter in your monitor and since your only putting wear on a cheap hdmi cable and this 15$ splitter piece it won't cost much if either fails up?
Again you may just be wanting to avoid plugging a cable in...so just check out some of the google hits...
Rewindlabs is offline
post #22 of 28 (permalink) Old 08-05-2009, 02:16 PM
tubesaddict's Avatar
Rep: 90 (Unique: 77)
No! DVI-I is integrated digital and analog, DVI-D is digital only.
tubesaddict is offline
post #23 of 28 (permalink) Old 08-05-2009, 02:50 PM
Rep: 443 (Unique: 358)
You'll need to use component video and a component to DVI adapter like this. There is no component to HDMI adapter available (I think it's impossible to make that conversion) so that's pretty much your only option.
Edit: This is the Wii component video adapter. There are 3rd party ones that are a little cheaper.
e_dogg is offline
post #24 of 28 (permalink) Old 08-05-2009, 02:57 PM
Component to HDMI converter:
http://sewelldirect.com/Apogee-RGB-C...-Converter.asp
post #25 of 28 (permalink) Old 08-06-2009, 12:40 PM
Originally Posted by tubesaddict View Post
Interesting - didn't know they made one of those. It must have some circuitry inside as a straight component to HDMI transition is not possible. But, good find!
e_dogg is offline
post #26 of 28 (permalink) Old 08-07-2009, 12:52 AM
getllamasfast's Avatar
Rep: 100 (Unique: 88)
I know you are looking for a way to hook up your wii via DVI, but I found a cable that goes directly from the wii to VGA instead. Here's the cable and here's a review.
TF2
getllamasfast is offline
post #27 of 28 (permalink) Old 08-07-2009, 05:45 AM - Thread Starter
Jjangthekid's Avatar
Rep: 14 (Unique: 13)
Wow looks great. Thanks for that.
Jjangthekid is offline
post #28 of 28 (permalink) Old 04-03-2010, 02:07 PM
stryyker's Avatar
Rep: 0
Hi people. I just bought my new samsung XL2370
To my ps3 using HDMI.
Xl2370 Just have Audio entrance, HDMI, DVI, and i as just thinking using My wii on my samsung to.
Ive read some of posts here, and im tryin see if have a real solution to put my WII working on my monitor.
I have the normal Compun. (http://img.hardcore-gamer.net/tienda...omponentes.jpg)
The solution the people see to works, is wht?
This and This?
Im gona read the review and see if some people have that advice and if works well.
Ty and hope someone reply =)
stryyker is offline
