[MOD] Extreme Overclocking | non-K Haswell (turbo enabled) Desktop/Mobile 4GHz+ Overclock |Turbo Bin Increase Recursion Hack | Mobile i7 4XXXmq/hq to i7 extreme conversion - Overclock.net - An Overclocking Community
post #1 of 29 (permalink) Old 04-03-2016, 02:53 PM - Thread Starter
tmashpotato's Avatar
Rep: 7 (Unique: 7)
Hi all,
After I saw this result: http://hwbot.org/submission/2830783_0.0_cpu_frequency_core_i7_4700mq_4550_mhz , I got interested to replicate it with a similar method and decided to share my steps to score higher than a desktop 4.4ghz 4770k (according to cinebench wink.gif) on my Clevo P150SM
Intel Stock microcode has a Turbo multiplier bin glitch that allows unlimited multiplier increase, I used prema's bios and removed a cpu microcode update to let the cpu run the stock glitched microcode.
1) Download or dump your BIOS, if your bios is ami (my case) then use AFUWINx64
2) Get AMI Aptio UEFI MMTool v5.0.0.7 and UEFITool, HxD (or your fav hex editor)
3) Open your BIOS image with UEFITool, then File>Search, in our case Haswell has the following ID:
Quote
C3 06 03
, enter C3 06 03 in Hex pattern dialog click OK
4) You can see the last four Hex pattern result, double click the first result and a structure item in the main dialog will be highlighted, right click>Extract as-is to a folder (be sure to be neat and organized or you will mess things up)
5) Do the same with the third result and save it as a diff name other than the first one
6) Now in the folder you have saved the 2 files from step 4&5, open the first one with HxD(any hex editor) and look for
Quote
C3 06 03
be sure to choose Datatype:Hex-values then hit search
7) Press F3 to find again till you reach this pattern(highlighted):
8) (1) Indicates the microcode version, 17 in this case, we want 00 (cpu stock), (2) the platform ID (the search context we reached at) (3) the microcode length = 5000 (in my case) in reverse (important to know when the microcode ends in order to remove).
9) Adjust the cursor on the beginning of the highlight text/microcode (01) right click>Select Block>Length>5000 or whatever in your case
10) Delete the highlighted blocks (after step 9) then save the file
11) Do the same with the second result from step 3 to 10 then save
12) go back to UEFITool, double click the first result like you did in step 4, right click the highlighted structure in the main dialogue > Replace as-is then choose the FIRST file you edited in HxD
13) Double click the third result and follow step 12 with the SECOND file you edited in HxD
14) You will see "Rebuild" in action row, File>Save image as> P15SM04.PM2 in my case (can be any name as long as your flashing tool recognize it)
15) Open AMI Aptio MMTool > Load Image > your modified rom > CPU Patch Tab and verify there is no 06C3 in CPU ID
Windows Mod to remove auto update microcode on boot:
1) Remove mcupdate_GenuineIntel (and backup) from System32
2) Done
Overclocking:
1) Check CPU MCID:Download AIDA64 , open AIDA64>Motherboard>CPUID and look at IA Brand ID, it should be 00h
2) Download the latest beta Throttlestop (not stable) in my case 810b2
3) Make sure you don't have XTU installed or running (especially at startup) or it will reset any changes in Throttlestop
4) Open throttlestop, click FIVR and look at "[checkbox] Overclock [DIALOG] Max" and note it down
5) Now here is the magic! close FIVR and open it again, [DIALOG] Max value should increase by 2 (up to 80x max ~ 8ghz) everytime you open and close FIVR aslong as long as you increase one of the cores, (bin recursion on msr15, you can't set this outside throttlestop if you can't read max turbo possible by the cpu itself everytime)
6) Increase "Set multiplier" to maximum after your final changes in FVIR (Iv set mine to 42x all cores, so I increased set multiplier to 42 aswell - note voltage ID is messed up ignore it)
7) Increase voltage in FVIR for stability by using cinebench run 3 times instead of prime95, as it stresses FPU which increases heat and tdp instead...
8) Unlock maximum TDP and turbo wattage in TPL, in my case:
9) Done! Changes should be persistent as long as you dont save and exit from BIOS, here is my result in Cinebench with temp throttling (from 4.3 to 3.9 ghz), room temp 25-27 XD: (no.1 at 4.2ghz, no.7 stock latest microcode)
UPDATE: OCed RAM from 1600 to 1866, [email protected], +200mV adaptive vcore:
I'm also getting 852 with 4.5ghz, t̶h̶o̶u̶g̶h̶ ̶i̶t̶s̶ ̶u̶n̶s̶t̶a̶b̶l̶e̶ ̶a̶s̶ ̶t̶h̶e̶ ̶f̶r̶e̶q̶u̶e̶n̶c̶y̶ ̶s̶c̶a̶l̶e̶s̶ ̶d̶o̶w̶n̶,̶ ̶(̶m̶a̶y̶b̶e̶ ̶d̶u̶e̶ ̶t̶o̶ ̶h̶i̶g̶h̶ ̶v̶o̶l̶t̶a̶g̶e̶)̶
Static voltage table like on load method using TS:
https://www.youtube.com/watch?v=0wqkk05UpTo
Post your results and I'll copy it here.
Tips:
-I highly recommend lapping heatsink and use liquid metal thermal paste or any decent tp ( I used collaboratory liquid ultra) before doing this.
-If your cpu throttles no matter what, try decreasing dynamic voltage in FVIR and look at maximum value the package power indicate while stressing, decrease the value by 10% in order to avoid rapid throttling (happens with bad TP) biggrin.gif
-Do not attempt the OC if you are looking after long service life wear&tear (I expect 2 years from now if I stress the cpu everyday for an hour, which i never do tongue.gif)
Happy overclocking, and don't melt your laptop:)
Thanks to Intel if they leaked this on purpose, kinda futureproofed my machine XD
Updates:
-Tested on desktop i5 4430 without altering reference clock, OCable 3.2 to 3.6ghz max (high voltage monster cpu biggrin.gif.just look at the stock TDP : 84 W)
-To add:(This has been done by Asus with desktop on haswell launch aswell, though BIOS updates were pushed asap, steps should be similiar with desktop mobos, there is a decent advantage of applying this on non-extreme mobile due to the insane cost. getting a K processor with desktops is a wiser choice for cheap extra
-Intel has done the same mistake again with Skylake this time, would be interesting to see how far 6700HQ can go.biggrin.gif
(Thank you MOD for finally removing the useless posts, funny PM example: "aj****** sent you this private message on https://overclock.net , April 17, 6:46 pm
if your UEFI/BIOS has the settings in it, you really should set them there and not in XTU. XTU is ****! Meanwhile, have you tried the mod on the locked Xeons on this architecture? That is where things start getting interesting. Meanwhile, you come off as a complete a**, TBH.")
Just to clarify, only Throttlestop works with the OC, since in my case, XTU/BIOS does not read the [secret]MSR register, as reading it increments max bin with mc
tmashpotato is offline
post #2 of 29 (permalink) Old 04-03-2016, 02:56 PM
ლ(╹ε╹ლ)
Rep: 179 (Unique: 140)
+rep with your first post, great! Good post!
Duality92 is online now
post #3 of 29 (permalink) Old 04-03-2016, 02:56 PM
TheReciever's Avatar
Rep: 434 (Unique: 322)
Very Impressive!
Biased rPGA and MXM 3.0A/B Elitest.
TheReciever is offline
post #4 of 29 (permalink) Old 04-03-2016, 03:12 PM
Rabies is my business
BulletSponge's Avatar
Rep: 236 (Unique: 194)
That's freaking amazing! Welcome to OCN!
The New Recruit
(17 items)
AMD R5 1600X
Asus ROG Crosshair VI Hero
EVGA 1080 ti SC2
G.Skill Trident Z 3200
WD Black 256GB Performance SSD
WD 1TB Caviar Black
WD 1TB Blue
Samsung 840 Evo 120 GB
EVGA Supernova 750 G2
Noctua NH-U12S
Phanteks Enthoo EVOLV
Operating System
Windows 10
BenQ XL2730Z
Mouse
Logitech G502
Audio
Creative Soundblaster X-Fi Titanium HD
Audio
Klipsch ProMedia 2.1 BT
Other
Sennheiser PC 363D
BulletSponge is offline
post #5 of 29 (permalink) Old 04-03-2016, 03:57 PM
Posting it here on OCN where people would prefer to believe that laptops cant achieve these thresholds, you may also want to share it with NBR or Tech | Inferno if not already
post #6 of 29 (permalink) Old 04-03-2016, 04:14 PM - Thread Starter
Rep: 7 (Unique: 7)
I already did, and so far this is the only forum which appreciates OC regardless it being a laptop smile.gif
and yes, know that feeling when desktop replacement laptops gets compared to custom built desktops... your right, the reaction at NBR and TI was not nice (private messages peasants lol), so far so good at OCN, thank you for the warm welcome smile.gif
Edit: fixed my "english" lol
post #7 of 29 (permalink) Old 04-04-2016, 12:54 AM
Laptop Enthusiast
Imglidinhere's Avatar
Rep: 447 (Unique: 333)
Quite happy to see someone post something like this. Definitely a good sign that laptop modding is starting to appear more regularly. ^_^
SKYNET v3.1
(17 items)
SKYNET Mobile v3.0
Inspiring Greatness
Ryzen 5 2600
ASRock B-450M Pro4
8GB GTX 1070
16GB Corsair DDR4 LPX @ 3000 CL15
Sabrent 256GB NVMe SSD
1TB WD Black NVMe SSD
512GB Samsung 840 Pro SSD
1TB WD Black HDD - External
650w Antec NeoECO
Arctic Freezer X
Fractal Design Define Mini-C
Operating System
Windows 10 Pro
DELL S2419NX
Keyboard
RedDragon K556
Mouse
Logitech G502 Proteus Spectrum
Audio
HyperX Cloud Revolver-S Headset
Audio
Bose Companion 2 Series III
i7-8750H @ 3.9GHz
Intel HM370
6GB GTX 1060
32GB DDR4 2666
256GB SSD
500GB Samsung 840 Pro
1TB Western Digital Black NVMe SSD
180w Power Adapter
Tongfang GK5CN6Z
Operating System
Windows 10 Home
1920x1080 144hz IPS Display
Mouse
Mousepad
Xtrac Ripper
Intel Core i5-6300HQ
Dell Proprietary
4GB Nvidia GTX 960M
Samsung 12GB (1x8GB 1x4GB) DDR3L 1600 MHz
256GB SanDisk M.2 SSD
1TB HGST 7.2k HDD
130w PSU
Custom Cooling by Dell Solutions
Operating System
Windows 10 Home 64-Bit
15.6" 1920x1080 IPS Screen
Keyboard
Dell
Mouse
Logitech G602 Wireless
Mouse
Xtrac 'Ripper' Mouse Pad
Imglidinhere is offline
post #8 of 29 (permalink) Old 04-05-2016, 05:32 AM
czin125's Avatar
Rep: 52 (Unique: 47)
Does this only work on MQ processors or can HQ processors use this?
czin125 is offline
post #9 of 29 (permalink) Old 04-05-2016, 07:05 AM - Thread Starter
Rep: 7 (Unique: 7)
All Haswell CPUs including desktops, though I think Haswell-Refresh like 4720 (?) would only work if you replace existing microcode ranging from v01 to v06 (as stock microcode is late 2014, maybe v11), and not stock (v00, or v00 = v11 in refresh). You should even do that (for OCing else just do bios update) when using Haswell refresh CPU with old desktop motherboard, and make sure you adjust dynamic cpu voltage lower than the equivalent non-Refresh or else it will crash on boot (depends on your luck in order to reach voltage control before crashing biggrin.gif), only new microcodes have proper stock voltages, see this: PSA: Stop combining Intel 8 series with the new Haswell CPUs..
MB, i'll modify the title for better clarification.
EDIT: Thank you all for the reps oneeyedsmiley.png
post #10 of 29 (permalink) Old 04-05-2016, 09:45 PM
Rep: 59 (Unique: 48)
AFAIK the unlock doesn't work on any desktop chip, only on Haswell CPU's with turbo overclockable feature.
ucode is offline
