Why not to replace your laptop's thermal pad with thermal compound... - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 08-15-2016, 06:01 PM - Thread Starter
aweir's Avatar
Rep: 254 (Unique: 189)
I decided to tear apart my laptop, a Compaq CQ61, and replace the CMOS battery and clean the heatsink off. After I removed the heatsink I tore the thermal pad and thought it would be OK to just use Arctic Silver on the GPU and CPU. After I put it back together the laptop kept shutting off randomly. I had a feeling it was the GPU so I dug my old XFX HD 4890 graphics card gathering dust out of the closet, and took the heatsink off and cut out a square of thermal pad off one of the Vram and placed it on the laptop's GPU. Now it's running fine, so I'm a little curious why the heatpipe isn't attached more securely so that you can use thermal compound instead of a thermal pad on the GPU.
There is almost no tension on the GPU heatsink at all.
aweir is offline
post #2 of 12 (permalink) Old 08-15-2016, 06:05 PM
MMO Enthusiast
luisxd's Avatar
Rep: 19 (Unique: 19)
Did it come originally with thermal compound or a thermal pad?, i actually had a similar issue when taking apart my laptop and installing AS5 but haven't tried installing a thermal pad on gpu..
My mods:
Corsair 300R Brushed Metal [MOD]
WoodBox [Scratch Build]
Dell Optiplex 170L 2.0 [MOD]
CLEVO P870TM1G
(12 items)
i7 8700K
GTX 1080
GTX 1080
G Skill Ripjaws
G Skill Ripjaws
Samsung PM981
Crucial M4
Vapor chamber
Clevo P870TM1-G
QHD Matte diasplay
Mouse
Logitech MX Master
Mousepad
Corsair MM100
luisxd is offline
post #3 of 12 (permalink) Old 08-15-2016, 06:11 PM - Thread Starter
aweir's Avatar
It had a thermal pad on the GPU and thermal paste on the CPU. I guess a thermal pad works better.
aweir is offline
post #4 of 12 (permalink) Old 08-15-2016, 06:15 PM
I might have tacos tonite
Crazy9000's Avatar
Rep: 491 (Unique: 345)
You have to use a thermal pad if the heatsink isn't making solid contact. The thermal paste can't fill a real gap, it's only meant to fill in tiny cracks between two surfaces that are clamped together.
The pads offer worse performance, but they work with a gap, while paste wont.
Crazy9000 is offline
post #5 of 12 (permalink) Old 08-15-2016, 06:18 PM
Rep: 233 (Unique: 176)
That is unusual and likely a problem of lack of care in production/cost cutting. With almost all of the laptops I've taken apart the GPU makes direct contact with the heat pipes contact point. Wonder if you couldn't slip some cardboard in there somewhere to force contact...
I am a Marxist. Not the Sanders/Sweden/state bureacracy kind, but the workers' democratic control over the means of production kind.
I often use the debates I get into on these forums to demonstrate logical fallacies to to my students and debate teams I coach. Beware - your arguments are under scrutiny of adolescents and teenagers!
claes is offline
post #6 of 12 (permalink) Old 08-15-2016, 06:29 PM - Thread Starter
aweir's Avatar
I know. This is what the heatpipe looks like. Same laptop. Skip to 8:18 to see the heatsink. You'd think the GPU heatsink would be screwed down also.
aweir is offline
post #7 of 12 (permalink) Old 08-15-2016, 07:33 PM
MMO Enthusiast
luisxd's Avatar
Just tried and it's still shutting down itself so it's not my case =(
My mods:
CLEVO P870TM1G
(12 items)
i7 8700K
GTX 1080
GTX 1080
G Skill Ripjaws
G Skill Ripjaws
Samsung PM981
Crucial M4
Vapor chamber
Clevo P870TM1-G
QHD Matte diasplay
Mouse
Logitech MX Master
Mousepad
Corsair MM100
luisxd is offline
post #8 of 12 (permalink) Old 08-15-2016, 07:44 PM
jlhawn's Avatar
Rep: 238 (Unique: 195)
This is good info to know, thanks aweir.
although my alienware laptop with a nvidia gpu had thermal paste that I replaced a couple years
ago and it worked fine, but if I ever re-do one with a thermal pad I will be sure to replace the thermal pad
and not use paste.
jlhawn is offline
post #9 of 12 (permalink) Old 08-15-2016, 07:53 PM
Jedi Knight
Nick the Slick's Avatar
Rep: 43 (Unique: 43)
I can't speak on other manufacturers as I work mainly on HP's, but I can say this is pretty common for HP laptops. Mainly older ones though. They've gotten better at using thermal paste on the newer (late 2014-current) ones though. Pre-2014 it was pretty rare to see an HP with a dedicated GPU that used thermal paste and not a pad. Hell, even on some current models they are using pads instead of paste on even the CPU's with low TDP. But anyways, you should change your thread title. It's safe to use thermal paste on a laptop GPU as long as it came stock with paste, if it comes with a pad, only replace it with another pad.
Vibranium
(16 items)
Intel Core i7 7700k
ASUS Z170-PRO
MSI GeForce GTX 1070 Sea Hawk EK X
G. Skill Trident Z
MyDigitalSSD BPX
Crucial MX300
ADATA SU800
Seasonic SS-750KM3
Custom Liquid Cooling
Phanteks “Enthoo Pro Series"
Operating System
Windows 10
VIOTEK GN32DB
Keyboard
Logitech K800
Mouse
Logitech G603
Audio
JBL LIVE 650BTNC
Audio
Fiio E10K DAC/AMP
Nick the Slick is offline
post #10 of 12 (permalink) Old 08-15-2016, 08:01 PM
Watercooled
lexer's Avatar
Rep: 47 (Unique: 33)
You need to fill the space with something, i usually use a sheet of thin cooper (0.5mm+/-) with thermal paste on both sides
I7 8700K@4.7Ghz / Z370-A / 2X8GB 3200Mhz ADATA Spectrix D40 / 1TB Intel 600P / EVO 850 250GB / 4TB WD Gold / RTX 2080 GAMING OC / NZXT Noctis 450 ROG / EVGA G2 850W@ECO
Heatkiller REV 3.0 / XSPC EX360 / DDC 3.25 + EK-XRES / 3x Venturi HF-12 PWM
lexer is offline
