Low fan speed = lower FPS - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 02-07-2019, 01:04 PM - Thread Starter
Veteran
Korruptive's Avatar
Rep: 29
So I recently got an Asus GL703GS with 8750H and a 1070.
I have undervolted it (core voltage offset -0.145v) and applied conductonaut.
Temps are much better; 40-45c idle and it no longer thermal throttles even when running AIDA64.
CPU @ 3.88GHz - 75c (fan 100%)
GPU @ 1835MHz - 70c (fan 100%)
The laptop has 3 fan profiles and they are linked to the GPU's boost clocks.
The problem is this laptops fans are noisy and I prefer to keep it on the silent setting.
I did a bit of testing with Destiny 2
Silent = 1000MHz~1100MHz 85-95 FPS - 55-59c
Balanced = 1600~1700MHz 115-125 FPS - 64-69c
Overboost = 1700~1850MHz 120-135 FPS - 67-72c
Is there a way to unlink the fan profile from the boost clock?
Strix
8700k
Asus RoG Strix Z370-E
Zotac Mini 1080 Ti
Corsair Vengeance RGB White
Samsung 960 Pro 2TB NVMe
EVGA 750w GQ
NZXT Kraken X72
Lian Li Dynamic White
AOC AG271QG
Keyboard
Aukey RGB
Mouse
Logitech G600 White
Mousepad
Razer Firefly
Audio
Audioengine A5+ S8 Sub + D1 DAC
Korruptive is offline
post #2 of 4 (permalink) Old 02-07-2019, 01:26 PM
Overclocker
JackCY's Avatar
Rep: 283
With the modes where ever you're setting them you're not setting fan speeds but likely power limits/performance limits instead.
Getting around this probably means hardware mods because you won't be able to do software mods unless they are readily available.
JackCY is offline
post #3 of 4 (permalink) Old 02-08-2019, 02:49 PM
cloppy007's Avatar
Rep: 76
Have you tried speedfan?
I'm looking for a Thermalright bolt-thru kit
cloppy007 is offline
post #4 of 4 (permalink) Old 02-08-2019, 05:16 PM - Thread Starter
Veteran
Korruptive's Avatar
Rep: 29
Yeah unfortunately speedfan is long out of date and there was no option to change the fan speed
Strix
8700k
Zotac Mini 1080 Ti
EVGA 750w GQ
NZXT Kraken X72
AOC AG271QG
Keyboard
Aukey RGB
Mouse
Logitech G600 White
Mousepad
Razer Firefly
Audio
