NZXT Phantom 410 Project - Overclock.net - An Overclocking Community
post #1 of 19 (permalink) Old 03-22-2013, 09:30 AM - Thread Starter
jompenleet's Avatar
Rep: 3 (Unique: 2)
Welcome! This is a progress log from jompenleet.
To be able to see the current state of the case you're going to click the last page here in this thread.!
This picture is one of the most recent one's.
Though i recommend you to check the last page in the thread for more pic's
Here is the original state of the NZXT Phantom 410 case. (Just moved the components of my old OEM computer into the case)..
Got a new Motherboard + processor + cpu cooler (Scythe Grand Kama Cross)
After getting some new fans Xigmatek 1253 & a new fan to the cpu cooler Xigmatek XAF Series 140mm
it looks like this.
Interior before cable sleeving and cable management.
mad.gifHere i actually cut a whole in the side of the case to give it a bigger window.. And i forgot to take pictures sorry.
Here's a link to the tutorial i followed to be able to do this!
http://www.youtube.com/watch?v=WpZoE-zj0-k
:thumb:Thank's alot to MNPCtech for the really informative tutorials on case mods!! thumb.gif
Interior after hardmod sidepanel + psu cover & fully sleeved cables.
P.S Im still waiting for my stormtrooper sticker & white LED tubes for the case
jompenleet is offline
post #2 of 19 (permalink) Old 03-24-2013, 02:26 AM - Thread Starter
jompenleet's Avatar
Rep: 3 (Unique: 2)
Will be updating with new pics as soon as i get my LED lights & Stormtrooper sticker :-) please subscribe
post #3 of 19 (permalink) Old 05-09-2013, 01:34 PM - Thread Starter
jompenleet's Avatar
Rep: 3 (Unique: 2)
Got sick of the orange LED fans so i decided to modify them abit..
First i took apart the case and looked around for fans laying around..
Found some!
case without fans :-(
Xigmatek F1253 and F1450 i think?
Cleaning the fans for the paint to stick
Safety first! (if u ignore this ur fans may not spin at all)
Removing the LED's
close up look..
Fans on top of the case
Scythe grand kama cross CPU cooler after painted the fan
overall look
What do u think? Still waiting for stickers and Cold cathodes!
Subscribe
post #4 of 19 (permalink) Old 05-10-2013, 03:48 AM
PhantomTaco's Avatar
Rep: 88 (Unique: 76)
I think you've done a beautiful job dude honestly. Rep for a job well done. A few critiques I do have:
The pci power connectors for the GPU look kinda weird just being pulled down to the corner of the bay cage like that. If you wanted another option, I'd cut a whole in your PSU cover on the inside by the covered grommets at the bottom to feed the cables into from there so the cables just go straight down under the GPU. Would just make it look nicer and be easier on the cable length and storage.
Maybe consider painting the ram heatsinks to black or white or maybe even grey to match the rest of the build better. I know it's a minor thing, but seeing as how you've put so much effort into it you definitely had a goal in mind.That or just buy a new kit, maybe something like the Avexir Core series white led kit they've got on newegg if you want some nice lights (I use them myself and LOVE them).
Also,so this is a gigabyte 680 soc right? So if I'm right it exhausts air out towards the window right? You could make yourself a fan mount there in the window to exhaust the air from the GPU. Unless you have plans to liquid cool your system in the long run.
Regardless good stuff
PhantomTaco is offline
post #5 of 19 (permalink) Old 05-10-2013, 04:38 AM - Thread Starter
jompenleet's Avatar
Rep: 3 (Unique: 2)
Thank you PhantomTaco for you opinions and i will definately consider your thoughts for future projects.
Ill be drilling a hole in the PSU cover as soon as i find a hole saw.
And about painting the RAM Heatsinks, hmm. From what i've read its not a good idea to put paint on heatsinks at all. The paint cold be isolating the heat & end up ruining the motherboard but ill look for some Heatsink Paint and see what magic i can do.
And about the GPU fan's directing the heat to the acrylic window. Yes but ill show you a demonstration of the Air flow
Excuse my paint skills.
Blue lines = Cool Air
Red lines = Hot Air
I've got pretty good GPU and CPU heat while overclocked. CPU will reach 50 degrees Celsius in full load
And the GPU will reach a maximum of 60 with stock overclock.
post #6 of 19 (permalink) Old 05-16-2013, 02:46 AM - Thread Starter
jompenleet's Avatar
Rep: 3 (Unique: 2)
Got me some watercooling now.
And some new dust filters (the old ones sucked)
Made a Hole in the PSU cover for the GPU Cables
Also painted the Chassi details in Glossy White
Got two identical NZXT 140mm fans for the top (had too look symmetric)
Water cooling in place
So what the case currently looks like.. Ill be getting some more parts next week. Subscribe smile.gif
P.S Also installed some Revoltec Cold Cathodes....
So i got some new stuff that my friend at timwill clothing drew for me..
He also had some contacts to be able to make it in this frosty nice look :-)
Here we are applying a new sticker to the acrylic side
finished!
End result & my friend David himself :-D
Also got me some custom made fan stickers, drawn by David @ Timwillclothing
sticker on the modded 120mm xigmatek fan
stickers on the modded 140mm NZXT fans
Voila!
I do have some other things waiting to be done with this case (otherwise i wouldnt have this blue led still in there)..
Check back soon and see what has happened!
Peace
post #7 of 19 (permalink) Old 05-19-2013, 11:31 PM
choLOL's Avatar
Rep: 17 (Unique: 14)
Subbed. Looks great! How did you paint the 5.25 bay locks? Did you remove them totally then paint, or did you just paint over them?
choLOL is offline
post #8 of 19 (permalink) Old 05-20-2013, 04:48 AM - Thread Starter
jompenleet's Avatar
Rep: 3 (Unique: 2)
Hello choLOL and thanks for subscribing.
Painting these locks was actually alot easier than i thought. Here's a picture explaining the removal
So first you pull the left part (two iron pins) out of the 5.25 bay.
Once you have that part out you just pinch the two plastic pins together and you have it removed.
Stay tuned! Will soon be updating the case with new mods!
Best Regards jompen!
post #9 of 19 (permalink) Old 05-23-2013, 11:56 AM
choLOL's Avatar
Oh, looks easy enough. Gonna try it in the future. Thanks!
choLOL is offline
post #10 of 19 (permalink) Old 06-29-2013, 03:09 PM
Rep: 0
Very awesome mod! Might have to steal your mod for my new white Phantom 410 case once I get all the parts together! thumb.gif
Kronos Baelfire is offline
