Ram Configuration And Grounding Help - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 12-25-2013, 01:37 PM - Thread Starter
Royal - Sloth's Avatar
Rep: 0
Hey guys still new to the forum
When i plug the power cable into the PSU and then into the mains to ground myself as i have attached my anti static wristband to a silver screw in it, do i switch on the PSU by the switch on the back of the PSU and not the wall , or dont switch anything on ?
Also which is the best ram configuration to go with , I'am using 16GB Corsair Vengeance Pro Ram at 1600mhz = 2 sticks of 8GB ram, with an Asus Z87 Sabertooth Motherboard. My manual for the motherboard recommends using it in a Dim A2 and Dim B2 configuration which is the second one and fourth one. Although i see many people have installed their ram into the other 2 sockets which is the first and third one ?
Please reply
Thanks
Royal - Sloth is offline
post #2 of 5 (permalink) Old 12-27-2013, 05:06 AM
Overclock Failed...
billbartuska's Avatar
Rep: 1249 (Unique: 969)
DO NOT power up the powersupply when installing/removing compoments! Unplug it from the mains.
Your owner's manual will identify the memory slots and where to install the sticks.
Please reply
Thanks
Hope that helps
https://www.overclock.net/images/smil...lame-small.gif5 GHz Overclock Club https://www.overclock.net/images/smil...lame-small.gifMisinformation is available from a variety of other sources. Misinformation is just like real information but wrong
....and enough power to shoot the speaker cones through the walls.
billbartuska is offline
post #3 of 5 (permalink) Old 12-27-2013, 05:25 AM - Thread Starter
Rep: 0
Originally Posted by billbartuska View Post
Hope that helps
But i should put the PSU's Power cable into the PSU and the mains socket , but just dont turn anything on ?
Thanks
post #4 of 5 (permalink) Old 12-28-2013, 06:29 AM
Overclock Failed...
Hope that helps
Thanks
No, No.
The psu will supply (some) power to the motherboard (BIOS) even with the PSU turned off.
post #5 of 5 (permalink) Old 12-28-2013, 08:47 AM - Thread Starter
Rep: 0
No, No.
This is a new build and no power connections are being made inside the case from the PSU right now as still building so there is no power cables connected into the modular psu , just the power cable going from the psu too the mains.
