Thermaltake Core X Case Owners Club: X1, X2, X9, X9 Snow Ed. - Page 208 - Overclock.net - An Overclocking Community
post #2071 of 4440 (permalink) Old 10-03-2015, 08:27 AM
Linux Lobbyist
DanBr's Avatar
Rep: 6 (Unique: 5)
Originally Posted by tcassa View Post
First mod finally done. Here are the side panels with the half window/mesh completed. Need to be cleaned up a little bit.
Next is to get the black acrylic for the inside midtray.
looking good!
DanBr is offline
post #2072 of 4440 (permalink) Old 10-03-2015, 09:47 PM
battleaxe's Avatar
Rep: 97 (Unique: 79)
Just got my case an X9. This case is amazing for the price. Can't believe the space in this thing for $150.00
Sorry about the crumby photos. Was late and didn't want to wake anyone. Just early photos of tearing apart anyway.
Can I join the club? BTW is there a thread sticky for our sigs? Or do we just make our own. Doesn't matter I guess...
battleaxe is offline
post #2073 of 4440 (permalink) Old 10-04-2015, 03:15 AM
Rep: 3 (Unique: 3)
Not completely finished
What goes around - comes around
whyscotty is offline
post #2074 of 4440 (permalink) Old 10-04-2015, 05:27 AM
skkane's Avatar
Rep: 14 (Unique: 12)
I love the open test bench look myself with those panels off but dust would get the better of it in the end smile.gif
Are those vardar fans? The blades / hub look funky.
6900k @ 4.3Ghz @ 1.25v :: Asus X99 Sabertooth :: 2x SLI Gigabyte G1 1080 :: 32Gb Crucial DDR4 2400 :: Samsung 960 Evo 1Tb :: Kingston HyperX 1Tb :: 2x WD Purple 4TB R0 / HGST 4TB / WD 1TB :: Fractal Design Kelvin S36 :: Acer XB270HU :: Corsair AX1200i :: K70RGB :: Mionix Avior SK :: Phanteks Enthoo Evolv TG
skkane is offline
post #2075 of 4440 (permalink) Old 10-04-2015, 05:34 AM
ItsRow's Avatar
Rep: 0
I feel scared posting here, everyone has X9's with fully watercooled setups and I ordered my X1 with just aircooling ._.
But, I've been stalking this thread for a while and have seen some pretty amazing ideas and case mods (Darlenes killing it) because Im supposed to stay under 2000$ to stay out of divorce court, I'm really wishing I could do a full waterloop.
Edit 1: tcassa, can we have a buildlog for those amazing looking side plates?
Edit 2:
Im pretty sure those are Scythe: Gentle Typhoons, I would guess the 1850RPM editions.
ItsRow is offline
post #2076 of 4440 (permalink) Old 10-04-2015, 07:04 AM
Originally Posted by whyscotty View Post
I know what you mean, that's why I put tempered glass on the entire top and one entire side. biggrin.gif
47 Knucklehead is offline
post #2077 of 4440 (permalink) Old 10-04-2015, 09:36 AM
Rep: 3 (Unique: 3)
Dust is quite easy to keep at bay - Dustbuster
GT1850 are the fans
Originally Posted by ItsRow View Post
Edit 2:
Correct my friend
post #2078 of 4440 (permalink) Old 10-05-2015, 07:47 AM
battleaxe's Avatar
Okay, I have a 360 RAD showing up today. I plan to use the pump from my AIO coolers on my GPU's to get me by until I can get a proper pump and res. The two GPU's will share the 60mm X 360 RAD for now. This should be better than the single 120mm RAD I had on each previously. So I will have two AIO pumps driving the 360x60mm RAD for now, which will cool the 290x's. Is this reasonable? I realize this is not the way most of you would do this, but I'm just starting out and want to build it up slowly instead of dropping 1000$ on a custom loop. Seems to me the flow would be better on a custom 360 RAD than it is on the AIO 120mm coolers I have on them now?
I plan to plumb another (on CPU) 120 rad into my existing H80i AIO cooler to give a bit better surface area, and hopefully improve temps just a bit on the CPU to take care of that. So I will have two 120mm AIO cooler on the CPU. I already own all the AIO coolers so the only cost to me is the coolant and the water lines.
Eventually, I will get a real 360 RAD for the CPU and a separate pump for that as well.
Question: is there a feasible reason why this won't work temporarily and offer better results than I had previously?
post #2079 of 4440 (permalink) Old 10-05-2015, 09:04 AM
RnRollie's Avatar
Rep: 160 (Unique: 125)
Repurpose an AIO pump? Somehow that spawns images of dropping a Ford Pinto engine into a Corvette or Viper body... yes, it will move.. but you'll soon wish it didn't.
While a pair of puny AIO pumps in series will work.. its just.. i dunno... wrong
If its for proof of concept, then alright.
If it is for "just a few days", then dont, wait the few days till you get the right stuff.
If it is for "jsut a few weeks/months",... then just dont... i doubt its reliable.
But hey, give it a go if you want., lets us know what happens.
Reality is futile, you will be assimilated by (your) perception.
Golden Rule(s) for Fans: CHEAP + SILENT = NO PERFORMANCE ▼ CHEAP + PERFORMANCE = NOT SILENT ▼ SILENT + PERFORMANCE = NOT CHEAP
+Most SILENT Case Fans are not well suited for CPU-HS-Towers or Radiators
+Most SILENT Case Fans are not well suited for cases, especially if they have filters. (added by doyll on 23/04/2014)
RnRollie is offline
post #2080 of 4440 (permalink) Old 10-05-2015, 09:21 AM
battleaxe's Avatar
Likely a few months. I understand the pumps will not be as strong as a proper pump/res. Just biding my time to get the right stuff. I don't understand how it could pose a problem though? The RAD should be less restrictive than the included ones right? I'm not argueing, I just want to think it through logically. If there is a real reason (other than; why would you do that) I'd like to try it. I figure, what could it hurt? And it buys me time...
Keep in mind, this will cost a lot more than just the pump. I have to get real blocks for the GPU's, res, and pump. And likely I will just wait until the next GPU upgrade to even bother with the new GPU blocks as I don't see the point in getting blocks for such old cards as the 290x. So there's that too...
So, yes its a sort of experient of sorts, but one that I believe should work... correct?
