Advice on a mid tower case - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 11-22-2016, 10:06 AM - Thread Starter
maverickpk's Avatar
Rep: 3 (Unique: 3)
Hello there,
My current build is in a Coolermaster ATCS 840. I'm looking to move it into a mid tower case and needed advice on the case. Things that are of importancr
- Aesthetically elegant and pleasing to the eye (not a monster looking one)
- Good airflow.
- Low noise
- A little room for expansion for adding an extra hard drive
- Good cable management
Thanks & Best Regards
"Life is a series of complex calculations somewhere multiplied by zero"
http://valid.canardpc.com/show_oc.php?id=1276134
maverickpk is offline
post #2 of 20 (permalink) Old 11-22-2016, 10:09 AM
I fix Stuff
XanderTheGoober's Avatar
Rep: 316 (Unique: 244)
Phanteks has been getting rather good reviews lately. Check this out. http://www.newegg.com/Product/Product.aspx?Item=N82E16811854003
Helpful Links & Hardware History (Click to show)OCN Marketplace Expectations (Click to show)
- I always test my purchased products before leaving trader feedback. If I bought something from you and you have not gotten feedback give me a little friendly PM bump. smile.gif
- When selling items I do my best to pack and ship by the next business day.
- You can never communicate too much, that said I try to relay any relevant information during a transaction as soon as it becomes available.
- I am willing to work with you on whatever you need, I am only a PM away.
Xander's Windows tune up guide
XanderTheGoober is offline
post #3 of 20 (permalink) Old 11-22-2016, 10:19 AM
Linux Lobbyist
Rep: 232 (Unique: 175)
Phanteks and Fractal fit your bill. Can't really recommend anything else where cable management is a concern (would otherwise suggest SilverStone as well).
I am a Marxist. Not the Sanders/Sweden/state bureacracy kind, but the workers' democratic control over the means of production kind.
I often use the debates I get into on these forums to demonstrate logical fallacies to to my students and debate teams I coach. Beware - your arguments are under scrutiny of adolescents and teenagers!
claes is offline
post #4 of 20 (permalink) Old 11-22-2016, 10:44 AM
AyyMD's Avatar
Rep: 6 (Unique: 5)
  • Fractal Design Define S
  • Fractal Design Define C
  • NZXT S340
  • Phanteks Enthoo Pro M w/ an extra fan
  • Phanteks Enthoo Pro M Acrylic
  • Phanteks Enthoo Pro w/ front fan replaced
  • Phanteks P400/S
  • Phanteks Enthoo Pro M Tempered Glass
Etc, etc
AyyMD is offline
post #5 of 20 (permalink) Old 11-22-2016, 11:56 AM
Linux Lobbyist
I wouldn't include the S340 personally - can't get enough air through those vents!
claes is offline
post #6 of 20 (permalink) Old 11-25-2016, 03:21 PM - Thread Starter
maverickpk's Avatar
Rep: 3 (Unique: 3)
Many thanks for the advices. Really liked the Phanteks Eclipse P400. I wasn't sure from the pics where the DVD or a Blu-Ray drive go. Any thoughts there? The Phanteks Enthoo seems to have place for only 1 DVD drive. I have a DVD drive and a Blu-Ray drive. So that case probably won't work.
post #7 of 20 (permalink) Old 11-25-2016, 03:52 PM
Linux Lobbyist
There is a strong trend away from optical drives and drive bays lately in favor of a more direct airflow path. So nope; no 5" bays on the Eclipse.
claes is offline
post #8 of 20 (permalink) Old 11-25-2016, 03:59 PM
Dimensive's Avatar
Rep: 227 (Unique: 140)
Dimensive is offline
post #9 of 20 (permalink) Old 11-25-2016, 04:07 PM
Gamer
dlewbell's Avatar
Rep: 57 (Unique: 50)
The smallest Phanteks case that will support multiple drives is the Enthoo Pro. It supports 3 optical drives, & is a really nice case, but may be larger than you want. The Enthoo Luxe is the same chassis with built in lighting & nicer panels, but is a bit more expensive.
Edited for typos. I should never type on a phone.
TV Gaming PC
ASUS G75VW
(6 items)
i7-8700K
MSI Z370 Gaming Pro Carbon
EVGA GeForce GTX 1070 FTW
GSkill Ripjaws V 16GB (2x8GB) DDR4-3200
Samsung 950 Pro 512GB M.2 2280
Seagate Barracuda 2TB 3.5" 7200RPM
Optical Drive
LG WH14NS40 Blu-Ray Writer
EVGA SuperNOVA 750 G2
Phanteks PH-TC14PE_BL
Enthoo Luxe
Operating System
Windows 10 Pro
Visio E601i-A3
Keyboard
Logitech K400
i7-3630qm
GTX 660M
Samsung 840 EVO
7200 RPM HDD
Optical Drive
DVD
Operating System
Windows 10
dlewbell is offline
post #10 of 20 (permalink) Old 11-25-2016, 04:43 PM
I fix Stuff
The enthoo pro has 3 5.25 bays, the enthoo pro m only has 1. make sure you're looking at the appropriate case.
I just bought the enthoo pro after looking into these types of cases for over 2 hours the other night. hope this helps.
