Searching the perfect case...for me. RGB Sync, Glass and not too wide - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 02-05-2019, 04:35 AM - Thread Starter
rul3s's Avatar
Rep: 0
Hi guys!
Actually I'm on a Thermaltake View 31 RGB, but I'm not too happy because RGB fans are only button controled and it's too wide for me, so I'm looking to replace it but I'm not finding one for my needs:
- RGB Fans 12/14cm with motherboard sync (Aura, Mystic Light, etc...)
- Tempered Glass (one or two sides)
- Max 20-22 cm width.
Optionals:
- PSU metal case isolator
- Having front USB/buttons
- Led ilumination on front/internal, also RGB Sync
For example, Thermaltake View 37 RGB Edition would be great if it was thinner, but actually is 26cm... I'm thinking also about buying a good case with all requisites without RGB and buying RGB fans separatelly.
Any idea mates?
Thanks!
View31-Ryzen
(16 items)
InWin-Intel
Ryzen 2600
Gigabyte x470 Ultra Gaming
RTX 2070 Windforce OC
KFA2 Hall Of Fame Extreme DDR4 4000 CL19
Samsung 970Evo 250GB NVMe
Samsung 850Pro 512GB
Western Digital Black 2TB
Corsair HX650 Modular
Noctua NH-U12
Operating System
Windows 10 PRO
Samsung C24FG70
Keyboard
Corsair K70 RGB
Mouse
Zowie FK2
Mousepad
Razer Goliathus Cosmic Speed
Audio
Asus Xonar STX
Intel Core i5 3330
Asrock Z77 Extreme 4
AMD RX570 4GB
Kingston HyperX DDR3 2400 8GB
Kingston A400 240GB
Seagate 500GB
Aerocool Templarius 600W
Scythe
InWin
Operating System
Windows 10
HP 22"
Keyboard
Logitech K110
Mouse
Logitech MX518
rul3s is offline
post #2 of 3 (permalink) Old 02-06-2019, 09:51 AM - Thread Starter
rul3s's Avatar
Rep: 0
After looking a lot I decided on one of the new Thermaltake models this year, the Versa J25. Have RGB with Sync, tempered glass, etc ... but one thing, it seemed very cheap with all that for 70€.
Well it has arribed today and it has been a full-fledged disappointment, even though I qualified the concept of "disappointment", I came from an Antec Twelve Hundred that endured 6 years perfectly, changed by boredom, then a Raijintek asterion classic, changed by to low airflow, and finally the Thermaltake View 31 that in comparison to the other 2, it was noticeable that it did not have that much quality.
Well, speaking of the Versa J25 ... The platform is the same for La Versa J22, J23 and J24, the fronts change and little else.
The used steel looks "weak", the fit of the tempered glass is very little adjusted, and again has gaps, so I do not want to imagine the vibrations that will occur over time.
The fans have seemed noisy and not very well finished, things like keeping them looking for a while and not see a completely uniform movement .... So nothing, return and something else.
Seeing the quality of this I dare not ask for another thermaltake, not anymore. The view 31 I do not finish to like, and has resulted in change in less than 1 year, and it is even worse.
So looking at the end I decided on the Phanteks ENTHOO PRO M Special Edition http://www.phanteks.com/Enthoo-Pro-M...alEdition.html.
It seems to comply with everything I asked for, it is a little wider than I wanted (23.5cm) but looking at the shape of the legs I think it will serve me since it is mounted on a shelf of the wall that makes 20cm.
Tomorrow it arrives to me, so already I will say to you such with this one to see if it "satisfies" to me.
View31-Ryzen
(16 items)
InWin-Intel
Ryzen 2600
Noctua NH-U12
Operating System
Windows 10 PRO
Samsung C24FG70
Keyboard
Corsair K70 RGB
Mouse
Zowie FK2
Mousepad
Audio
Asus Xonar STX
Intel Core i5 3330
AMD RX570 4GB
Kingston A400 240GB
Seagate 500GB
Scythe
InWin
Operating System
Windows 10
HP 22"
Keyboard
Logitech K110
Mouse
Logitech MX518
rul3s is offline
post #3 of 3 (permalink) Old 02-06-2019, 10:05 AM
RTX ON FPS OFF
anticommon's Avatar
Rep: 27
I recently switched to a TT A500 that was on sale ($170 AR I believe) and its very sturdy, good quality materials for sure. doesn't come with RGB but it does show off the internals pretty well. Airflow could be better but I am planning on opening up the front/top panels at a metal shop soon.
KRAKEN
9900k
Gigabyte Z370 Gaming 7
EVGA RTX 2080 Ti XC ULTRA
Kingston HyperX Predator RGB
ADATA XPG SX8200
EVGA SUPERNOVA G2
EK Velocity Nickel-Plexi, EK Vector RTX Nickel-Plexi, EK EX360, Koolance 360mm, Enermax Neochanger
Thermaltake A500
Operating System
W10 Premium
Alienware AW3418DW
Keyboard
Corsair LUX
Mouse
Logitech G502 Spectrum
Audio
Audiotechnica ATH-900X, SBX G5, MODMIC
anticommon is offline
Tags
Case , rgb , sync , tempered glass
