Help me in my little project please. - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 03-08-2019, 12:40 PM - Thread Starter
gavros777's Avatar
Rep: 12 (Unique: 10)
I got this open computer case(it's made for mining but will use it for personal computer use.)
https://images-na.ssl-images-amazon....L._SL1200_.jpg
and this 3 tier shelving unit to place it upon.
https://images-na.ssl-images-amazon....L._SL1500_.jpg
In the 2 shelves below i plan to place 10 hdds(for now more later) vertically being held together by this metal bar(times 4)
https://images.homedepot-static.com/...nc-64_1000.jpg
(plan to use thumb screws to hold the hdds on those metal bars).
I found some nice looking laptop coolers on amazon like this
https://images-na.ssl-images-amazon....hL._SX679_.jpg
and got the idea to place them under the shelves so they cool the hdds that will be sitting above the shelves.
Are those laptop coolers good and quite enough for an open case project like mine and can you recommend me the best way to mount them under the shelves or if you have any better ideas for cooling my hdds.(so far i can only think of using zipties to hold them onto the shelves.)
(I'm thinking also if it's possible to mount regular 120-140mm pc fans under the shelves.)
I will have my hdds together like in this video
but place them horizontal on the shelves.
I also consider using screen mesh around the shelving unit to keep the dust out.
What kind of screen mesh do you recommend and what would be the best way to mount it around the shelving unit?
So far i'm thinking to glue velcro on the shelving unit and the screen mesh and mount it that way for easy removal when i want to access the hdds.
I'm thinking to do similar screen mesh installation on the pc open case that will be sitting above.
Would love to hear your ideas and advices guys, thanks in advance!
gavros777 is offline
post #2 of 9 (permalink) Old 03-08-2019, 01:06 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 609 (Unique: 502)
I bought a bug screen role and cut out the pieces I needed and used some cardboard for casing.
Look here:
https://www.overclock.net/forum/1808...t-wave-39.html (post #383)
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
Fractal Design Arc Midi R2
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #3 of 9 (permalink) Old 03-08-2019, 01:41 PM - Thread Starter
gavros777's Avatar
That's an amazing idea, thank you so much!
Will be thinking twice now before throwing away my amazon mailing boxes.
post #4 of 9 (permalink) Old 03-08-2019, 01:55 PM
I Love this Hobby!
Welcome!
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
Optical Drive
Noctua NH-D15
Operating System
Win 10 Pro 64bit
Keyboard
Mouse
Logitech G502 Hero
Mousepad
Audio
Other
Optical Drive
Operating System
Win 7 Pro 64bit
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Audio
Optical Drive
LG DVD R/W
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Mouse
Mousepad
Audio
post #5 of 9 (permalink) Old 03-08-2019, 04:44 PM - Thread Starter
gavros777's Avatar
I'm thinking to add 1 or 2 nocuta fans on the shelves where the hdds will be blowing air from the front to the back.
My problem now is i dont know what is the best way to mount them, can you guys recommend me some ways?
post #6 of 9 (permalink) Old 03-08-2019, 05:14 PM - Thread Starter
gavros777's Avatar
I found these mounting brackets.
https://images-na.ssl-images-amazon....L._SL1005_.jpg
I have couple 140mm noctua fans i hope it supports them as the picture shows only 120mm.
By the way the legs should face where the fan blows air or where it pulls air?
post #7 of 9 (permalink) Old 03-08-2019, 05:31 PM
toolmaker03's Avatar
Rep: 90 (Unique: 68)
well as for building a open build, I have done a real large one. I would suggest spending more time on exactly how this could be built before deciding on what products you will use to build this. here is my own build I hope it gives you some great ideas for your own build.
https://www.overclock.net/forum/62-p...c-cooling.html
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #8 of 9 (permalink) Old 03-09-2019, 09:29 AM - Thread Starter
gavros777's Avatar
Thank you for the advice and that's an amazing open monster build you made there!
post #9 of 9 (permalink) Old 03-09-2019, 11:44 AM
thanks, if you have any questions, or would like a detailed explanation, on how I did something, let me know.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
