Noise Reduction/Cancelation Mods - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 04-21-2019, 11:10 PM - Thread Starter
MonarchX's Avatar
Rep: 129 (Unique: 90)
I noticed some people add custom foamy soft materials around their tempered glass to reduce noise. I think they add them to insulate the case as much as possible.
Questions:
1. Does it actually help in reducing noise?
2. Can I do something similar with my case? Would it help me? I have 2 front (Corsair) + 1 bottom (Noctua) intake fans, then 2 top (Noctua) + 1 back/rear (Noctua) blow out fans. I think side doors are the only ones that I can insulate and I am not sure if it would help enough to be worth the hassle...
3. What supplies, materials do I need and where can I get them?
4. How do I do it?
The Machine
(17 items)
Core i7 8700K
ASUS Z370 ROG Maximus Hero X WiFi
EVGA GeForce GTX 1080 Ti Classified Kingpin
Corsair Dominator Platinum
Western Digital Black
Optical Drive
LG WH12LS39 12x BD
Corsair 850W Gold
Cryorig Universal R1 Dual Tower, 4x Noctua 140mm case fans
Corsair Graphite 760T
Operating System
Windows 10 x64 LTSC 1809-17763
LG 32GK850G-B
Keyboard
Corsair K70 Rapidfire
Mouse
Logitech G903
Mousepad
QcK
Audio
ASUS Xonar DGX w/ UNi Xonar Low-latency drivers
Other
Xbox One Afterglow & Dual Shock 4 Controllers
Other
i1Display Pro colorimeter, i1Pro 2 spectrophotometer
MonarchX is offline
post #2 of 5 (permalink) Old 04-22-2019, 10:57 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 960 (Unique: 592)
https://www.amazon.com/SilverStone-2.../dp/B0040JHMH6
you're still going to have sound leakage from your intakes/exhausts and obviously you can't put it there. would make more sense to just run a lower/slower fan curve.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 16GB
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #3 of 5 (permalink) Old 05-03-2019, 05:15 PM
Rep: 1 (Unique: 1)
Questions:
4. How do I do it?
Silent cases are not silent, not when it comes to performance (unless you have an overkill cooler or very big case for efficient parts), and noise dampening materials do not make it quieter, they just reduce the high pitch noise. You want quiet or silent. Start by reducing or eliminating noise sources.
Since I'm on a very similar path and at about 70% success (work in progress), ill give you some tips.
You want to get a very good airflow case. If it's tiny, make sure it has a breathbale PSU shroud and make sure you have it clean (tuck everything behind the motherboard). Recomendations: corsair air 540, Meshify C/s2, phanteks p600s, cm h500 among many others.
HDD and stock GPUs (even third party ones) are a pain in the ass. So you need to eliminate the HDD and mod the heatsink of the GPU with 120mm fans or buy a cooler like accelero or morpheus. For the CPU, get a massive air cooler like the ones that Thermalright sells, and make sure to run its fan and the case fans at 600-800rpm.
If you have an Intel highly oced CPU, delid and use LM or top paste if you are not comfortable with LM
Also. In the question 2, you give some details about fans, so i get that you think they are the most important. The most impactful thing is the case design. Fan placement mathers a lot but if the case is garbage, doesn't matter where you place the fans.
Shenhua is offline
post #4 of 5 (permalink) Old 05-03-2019, 05:28 PM
April 2020
keikei's Avatar
Rep: 309 (Unique: 236)
Before you start buying stuff, go into your bios to see if it supports fan speed. It should. Tinker with that a bit and see how much, if any, improvements you observe.
PCMR
(17 items)
RYZEN 1700
ASROCK TAICHI X370
RADEON VEGA VII
G.SKILL Ripjaws V Series 16GB (2 x 8GB) DDR4 3200
WD Red 4TB NAS Hard Disk Drive - 5400 RPM (x2)
8TB Seagate Barracuda Hard drive internal 3.5" (x2)
SAMSUNG 860 EVO Series 2.5" 1TB
EVGA SuperNova 1300 G2
Noctua NH-U14S (CPU COOLER)
Cooler Master JetFlo 120mm Blue LED Fan (X6)
LIAN LI PC-V760B
Operating System
WINDOWS 10 64
Dell UltraSharp UP2718Q - LED monitor - 4K - 27"
Keyboard
VORTEX POK3R WHITE EDITION
Mouse
LOGITECH G305 WIRELESS GAMING MOUSE
Audio
Sennheiser HD 598 Cs Headphones
Other
Real Arcade Pro. 4 Kai Modded
keikei is offline
post #5 of 5 (permalink) Old 05-03-2019, 06:01 PM
8051's Avatar
Rep: 21 (Unique: 15)
This UK article discusses sound reduction techniques for industrial applications (some of them might be applicable to PC's):
http://www.hse.gov.uk/pubns/top10noise.pdf
8051 is offline
