Case Fans Help What are good these days. - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 08-16-2019, 11:55 PM - Thread Starter
meridius's Avatar
Rep: 0
Hi all,
I am after 2 case fans one 120mm and one 140mm for a NZXT H510i case as exhaust fans. I have been looking at the Noctua NF-S12A & NF-A14 PWM Chromax fans, are these any good.
I have not bought fans in years as this is my forst build in about 10 years and bought a H510i case and read that this case is a waste of time with intakes and needs good echaust fans. The fasn i was looking at are the Noctua but are there any better fans or are these about the best you can get, I was also looking at the NF-F12 but was told there more a heatsink or rad fan than a case fan and not to use them.
Now i am not to bothered about RGB fans but i am thinking about it as i never had a Window case before but not to sure if RGB fans are any good or better than the Noctua.
so the question is what do i need to look for can, any help would be great
thanks
meridius is offline
post #2 of 12 (permalink) Old 08-17-2019, 01:34 PM
NewUser16's Avatar
Rep: 45 (Unique: 30)
I have 5x NF-S12A chromax in my S8S. Absolutely the best fans I have ever used, dead silent even at 12v, I run them at 5.5v yet! pushing huge amount of air
NewUser16 is offline
post #3 of 12 (permalink) Old 08-17-2019, 01:47 PM
The last VRM burner
Rep: 28 (Unique: 15)
RGB - either ML series or Noctuas + Phanteks Halos. If budget is not an issue, then go for Noctuas, if you want to spend the least money then Arctics P series is a way to go. But judging from Gamers Nexus video, H500/H510 is a waste of time completely.
PC for all
(20 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
KHX24C11T3K2/16X 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
SeaSonic Focus Plus 750W
Raijintek Tisis lapped+ Thermal Grizzly Kryonaut
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent
Mouse
SteelSeries Rival 310
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #4 of 12 (permalink) Old 08-17-2019, 02:02 PM
Overclocker
JackCY's Avatar
Rep: 339 (Unique: 240)
Check the Arctic thread if you want to know more.
Otherwise Arctic P12 PWM and P14 PWM.
Noctua S12 is a slow airflow fan so of course it's quiet lol. It will choke at any slight resistence such as case meshes, filters, poor openings behind angles etc.
JackCY is offline
post #5 of 12 (permalink) Old 08-17-2019, 02:39 PM
NewUser16's Avatar
Noctua S12 is a slow airflow fan so of course it's quiet lol. It will choke at any slight resistance such as case meshes, filters, poor openings behind angles etc.
Dealing with many different brands of fans this is just my humble opinion.
As far is Noctua S12 choking when facing restriction, not true. I have 2x 4 HDDs and these fans running at 5.5v and the amount of air you feel on the other side of HDD's which btw. are set the long way is almost as if there was no restriction. I agree, these fans are strictly case fans but tbh. they are doing great job even with restrictions.
Now! them being slower...they might be slower but the speed will have nothing to do with the amount of air they pushing. Noctua fans are $$ but if you compare many other fans they have to run much higher RPM to produce the same air Noctua fans produce at half the speed
post #6 of 12 (permalink) Old 08-17-2019, 03:07 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1099 (Unique: 636)
The best fans are likely either 120x38/32 or 140x38/32 server fans. The best "consumer" fan depends what you're using the fan for.
Arctic P120/140 fans are cheap and work "good enough." Bitfenix Spectre 120/140 fans are also cheap and "good enough" but they also have either LEDs or RGB. Noctua A12/A14, NB eLoops, and EK Vardars are popular for more money but are notably better.
that makes zero sense. a case with bad intakes needs to be fixed to have better intakes. adding a bunch of exhaust fans isn't going to fix a restrictive case, it's just going to make a bunch of noise.
same reason why I ditched my P400S, restrictive front panel and it had horrible temps even with two industrial Noctua iPPC-3000 fans as intakes.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #7 of 12 (permalink) Old 08-17-2019, 03:48 PM
486DX2 66
Serious_Don's Avatar
Rep: 293 (Unique: 131)
For the cheapskates of the world:
Rosewill RFA-120-BL occasionally go on sale for like $3 a pop on newegg. I believe there is a 140mm model too. I own about 20 of them and only had a couple of them fail after over 5 years of 24/7 use. They top out at 2000 RPM / 75CFM (rated) and are nice and quiet with a fan controller. Not bad luck for a sleeve bearing. Don't pay $12 or whatever they ask though, just wait for a sale. Great fan? no, but for $3 they're a steal. Cut the LED if you don't like em.
Another favorite of mine is the Delta AFB1212GHE-CF00 120x38mm. They're only $11 on newegg if you can deal with the "asia first" slow shipping. 5200RPM / 241CFM.. Make SURE you have a good controller, but nothing will touch those fans in price / performance IMO. They're the only performance fan I really bother with anymore and I have yet to have one fail or so much as rattle.
Can't hear my delta fans over my Death Metal crew
I Just Found Out My PCs Have A Power Button. Meh, Still Not Shutting Down Club Member #00001
In the beginning were the words and the words made the world. I am the words. The words are everything. Where the words end the world ends. You cannot go forward in the absence of space. Repeat.
HAF Baked
(16 items)
M-M-Monster Kill
3700x
Gigabyte X570 Aorus Pro Wifi
EVGA 980 Ti ACX
DDR4 3600 CamoRamo "Pook Edition"
MX500 1TB m.2 happy now pook edition
evga g2
h100i
Corsair 900D
Operating System
Windows 10
Operating System
Ubuntu 18.04
Asus XG35V
Keyboard
Corsair Strafe RGB
Mouse
Windows 95 compatible serial ball mouse (srs)
Mousepad
Gigabyte Ghost
Audio
Creative Sound Blaster X-fi titanium pro fatality edition
FX 8320
Asus
Sapphire Tri-X 290
Corsair Vengeance 1600
Corsair Forse LS SSD
Samsung Spinpoint F3
Western Digital Black
Optical Drive
Asus 24x DVD-RW
EVGA
CM Hyper 212 Evo
Cooler Master HAF 922
Operating System
Debian 9 & Win7
Asus VH236H
Keyboard
Ancient Dell Mechanical
Mouse
Corsair MX65
Mouse
Gigabyte Ghost Extreme Accuracy
Pentium III
Intel SE440BX-2
GeForce MX 440 AGP 8X
Viking PC133 SDRAM
Viking PC133 SDRAM
Western Digital Caviar
Western Digital Caviar 39000
Optical Drive
LG DVD/RW
Stock
Operating System
Windoze 98
Audio
Sound Blaster Pro2
Audio
Sound Blaster 16
Audio
Sound Blaster Live!
Serious_Don is offline
post #8 of 12 (permalink) Old 08-17-2019, 04:01 PM
delerious's Avatar
Rep: 8 (Unique: 8)
I'm surprised no one has mentioned BeQuiet Silent Wings yet.
delerious is offline
post #9 of 12 (permalink) Old 08-17-2019, 04:53 PM
D-EJ915's Avatar
Rep: 3 (Unique: 3)
Since you are interested in RGB and already have the "i" version you could just get the NZXT AER RGB fans. I replaced my noisy EK vardars with the stock X62 AER P models and they work just as well. Thermalright fans are nice as well and are 140mm with 120mm fan holes so you can get two of the same and use them in both positions assuming the 140 top still has 120mm holes like the S340.
Fans are one of those things that you can really get obsessed over but in the end it can be just a small difference between most options outside of the super cheap ones.
Kanna
Dark X299
(7 items)
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i9-9900X
EVGA X299 Dark
EVGA Geforce GTX 1080 Ti
G.Skill 4x8GB C14 3200MHz
Samsung Pro 840 250 GB
EVGA Supernova G3 1300
Phanteks PH-TC14PE
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #10 of 12 (permalink) Old 08-17-2019, 11:31 PM - Thread Starter
meridius's Avatar
Rep: 0
Hi all thanks for the input, I have been looking at a fre types now and got it down to this,
None RGB
Rear of Case Noctua NF-S12A Chromax
Top of case NF-A14 PWM Chromax
or
Rear of Case ML120 Pro
Top of Case ML140 Pro
For RGB
Rear of Case NZXT AER RGB 2 120mm
Top of Case NZXT AER RGB 2 140mm
I did look at the Corsair ML120 & ML140 RGB fans but i did not realise you needed a different fan RGB controller as i thought all RGB devices could work with each other, thats a pain. The controllers I would have are the NZXT and RGB Fusion 2 as i am thinking of getting a gigabyte Master x570 motherboard.
All the combos above are about the same price point as theres not much in it which would be better for cooling and noise levels.
I am not to sure which combo would have the best cooling and best noise level for the H510i case.
What do you all think ?
I did look at the Arctic P12 PWM - Pressure-optimised 120 mm fans but these are for static pressure more for heatsinks not case fans.
meridius is offline
