Phanteks Enthoo Luxe 2 - will it make a difference? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 10-06-2019, 02:52 PM - Thread Starter
Rep: 0
Hello Peoples,
I own a Phanteks EVOLV ATX mid-tower case. Brilliant case. Crap air flow.
2x Front intake fans - 140mm
1x Rear fan 140mm
2x fans in push on Corsair H115 2x 140mm in roof/top.
All fans noctua AF15s with 1500rpm max.
I knew when buying the Evolv ATX that it had poor airflow, still could not resist.
Putting my hand inside the case when its running, its hot. Even on a cold day, the air going into the case is not cool at all.
I am thinking of getting the Phanteks Enthoo Luxe 2 case. Lots of fans = good air flow - usually.
I think I just need a bigger case, my room temp is usually 20-23c most of the time.
Please note, never had a problem in my previous PC, TJ07 with an army of 120mm fans, it had 8 or 9 singing in unison at low RPMs.
Anyone migrated from Evolv to another case? What temps drops did you see?
Thanks,
B
bhoot is offline
post #2 of 11 (permalink) Old 10-06-2019, 03:42 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1095 (Unique: 634)
air going into the case isn't cool but you're in a cool room?
it's a case with a 90%+ solid front panel with tiny vents around the edge. I'd imagine it's better than the Lux but I can't see how it'd be anywhere in the neighborhood of good.
If cooling performance is what you're after and you have a Phanteks preference you should be looking at the P400A with the new mesh front (P400/P400S are terrible airflow cases, I ditched mine earlier this year) or the P600.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #3 of 11 (permalink) Old 10-07-2019, 11:01 AM - Thread Starter
Rep: 0
Hey Pook. P400A is a mid-tower case. Want a full tower, feel I need a case which can do the AIO cooling for now and full on custom double or triple rad WCing in the future or just go fan crazy. I looked at the Corsair/Cooler Master cases, did not find anything I liked. At the moment, cannot find anything as well made as the Luxe 2 under £200.
Air vents are much larger, case is actually bigger, a lot of fan mounts for 140mm, zero modding needed for fill and drain ports.
bhoot is offline
post #4 of 11 (permalink) Old 10-07-2019, 02:12 PM
9 Cans of Ravioli
The Pook's Avatar
the entire top and bottom of the P400 is mesh it still is one the worst cases for thermals. Vents on a portion of an otherwise solid front panel with dense mesh (and usually another foam dust filter behind that) don't flow well.
Gamers Nexus has a fairly competent case "benchmark" and any case with a solid or mostly solid front panel does poorly unless it has some other way to intake air (like the PC-011).
If you want full something bigger than a mid tower you could look into the Fractal Design Define/Meshify S2 or the Lian Li PC-011. The Define/Meshify S2 is sold as a mid tower case but I could probably put my P400S inside my S2 if I took the power supply shroud off.
You can likely get decent thermals with just about any case with enough radiators and high RPM fans, if you just want a case that looks good then go for whatever you want.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
Acer XF270HU
Dell E2311H
Keyboard
Mouse
Logitech G502
Audio
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
post #5 of 11 (permalink) Old 10-09-2019, 07:55 AM - Thread Starter
Rep: 0
I looked into the P400 and the entire Fractual range, all of these cases have the same issue. Not enough on offer.
Case needs to be able to handle a simple build with AIO to start with then transition to being able to deploy and 2x or 3x rad deployment, still keep all my HDDs/SSDs and expand storage as required or increase fan count.
Only the Corsair 1000D ticks all the boxes but is simply not worth the money with the Luxe2 is available, half the price and offers enough. Luxe2 it is.
bhoot is offline
post #6 of 11 (permalink) Old 10-09-2019, 08:20 AM
venom55520's Avatar
Rep: 203 (Unique: 182)
Gamer's Nexus actually did a review on the P400A mesh front panel and found significantly better results with a small variation between it and other cases in its class:
Actually beating the 011 dynamic.
I think it's dependent on the fan configuration. I did see that review by science studios:
that puts it in a less favorable light, but I have anecdotal experience (I just went from an h440 to a p400a) and I can say without a doubt that airflow is much improved with the same amount of fans.
Go Away
venom55520 is offline
post #7 of 11 (permalink) Old 10-09-2019, 08:25 AM
9 Cans of Ravioli
The Pook's Avatar
https://www.youtube.com/watch?v=ZfXQQZtD_SI&t=835s
https://www.youtube.com/watch?v=-6rzR2ZQ3cc
yep.
apparently P400A is too small for OP.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
Acer XF270HU
Dell E2311H
Keyboard
Mouse
Logitech G502
Audio
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
post #8 of 11 (permalink) Old 10-09-2019, 08:58 AM
Overclocker in training
ThrashZone's Avatar
Rep: 71 (Unique: 55)
Hi,
Missed the lingo
You're in push on top rad what is that exhaust or intake ?
I'd do intake on any rad personally.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #9 of 11 (permalink) Old 10-09-2019, 09:22 AM
venom55520's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
Missed the lingo
I concur, if the CPU is too hot, you should do intake for the rad at the front and see if that improves things. You might have positive air pressure though which means more dust. Also, look into getting better fans too, you'd be surprised at the difference that'd make.
Go Away
post #10 of 11 (permalink) Old 10-09-2019, 09:24 AM
I can count to potato
Fluxmaven's Avatar
Rep: 17 (Unique: 9)
You should definitely be able to achieve better temps in the Luxe 2 over the Evolv ATX. The front and top are still restricted with the solid panels, but the bottom and side offer filtered, relatively unrestricted flow. The only problem being that all of the possible 3.5" drive locations impede these fan locations. That said, if you use the 4x3.5" HDD mount on the bottom, you only give up one of these fan locations which leaves 6 of the less restricted fan options.
Fluxmaven is offline
