Lian Li PC-O11 XL Question - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 01-13-2020, 03:07 PM - Thread Starter
TMatzelle60's Avatar
Rep: 16 (Unique: 16)
Can the ROG Certified on the tempered glass panel be taken off on the PC-O11 XL?
TMatzelle60 is offline
post #2 of 13 (permalink) Old 01-14-2020, 01:33 AM
Darylrese's Avatar
Rep: 123 (Unique: 102)
I also want to know this because its ugly and ruins it IMO. I've read that its etched in so no way of removal that i can think of.
Darylrese is offline
post #3 of 13 (permalink) Old 01-14-2020, 03:49 PM
RichKnecht's Avatar
Rep: 6 (Unique: 6)
It can't be removed. I don't notice it at all anymore. Regardless, it is a great case.
Editing PC
(11 items)
7900X
Asus Rampage VI Extreme Omega
ASUS RTX 2060 Dual
Corsair vengence RGB 3466
Samsung 960 EVO 256GB
EVGA 1300W SuperNova Gold
EKWB PE360x2, XE360, Supremacy EVO RGB, Xres140 D5 RGB
Liam Li PC011 Air
Operating System
Windows 10 Pro 64bit
Dell U2412
BenQ 2700PT
RichKnecht is offline
post #4 of 13 (permalink) Old 01-15-2020, 10:39 PM
Kritikill's Avatar
Rep: 24 (Unique: 18)
It doesnt peel off. it seems to be painted, not sure if some Mineral Spirits or Muriatic Acid would take it off. If you use the acid be cautious and follow the warning label.
HAF Complete
(6 items)
Intel Core i7-9700K 3.6 GHz 8-Core Processor
Asus ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard
EVGA GeForce RTX 2070 SUPER 8 GB XC ULTRA GAMING Video Card
Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory
Western Digital Black NVMe 500 GB M.2-2280 NVME Solid State Drive
Cooler Master HAF 932 Advanced ATX Full Tower Case
Intel Core i9-9900K 3.6 GHz 8-Core Processor
MSI MPG Z390 GAMING PRO CARBON AC ATX LGA1151 Motherboard
Gigabyte GeForce RTX 2080 Ti 11 GB AORUS XTREME WATERFORCE Video Card
Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3600 Memory
NZXT H700i ATX Mid Tower Case
Kritikill is offline
post #5 of 13 (permalink) Old 01-16-2020, 01:57 AM
Darylrese's Avatar
The only thing that spoils the case to be honest. Why do they have to do stuff like this. Atleast make it a removable sticker
post #6 of 13 (permalink) Old 01-18-2020, 09:01 PM
Pinnacle Fit's Avatar
How much bigger is this than the O11 dynamic? I was able to fit a 240 and 360 in that.
Sent from my iPhone using Tapatalk
i9-9900k OC to 5.0GHZ @ 1.285V Delidded/Direct Die Cooled
Gigabyte Z390 Aorus Master
GTX 1080Ti FE
Lian Li O11 Dynamic, white
Pinnacle Fit is offline
post #7 of 13 (permalink) Old 01-28-2020, 07:04 AM
ChiTownButcher's Avatar
Rep: 43 (Unique: 36)
From what I know there is not a way to remove ROG certified. It can hold 3x 360 radiators depending on their thickness.
Self Proclaimed Gaming Nutt
ChiTownButcher is offline
post #8 of 13 (permalink) Old 02-04-2020, 07:47 AM
Rep: 12 (Unique: 9)
Yes it can be removed, but note that the removal is destructive. That means once it is off, you cannot put it back. It is pressed-on metallic film on the glass panel, you can take any single edge blade and scrape it off and it will NOT damage the glass. I just picked up this case for my new build (still in the planning stage) and the first two things I did was to move the De8auer plate to the back of the case, where I will never see it and to remove the ROG logo.
Note, the plate can be removed by heating with a handheld hair dryer to warm the adhesive and then taking a small wood wedge or plastic spatula and slowly prying the plate off after the adhesive is softened.
I suppose if you are very slow with the razor you could possibly remove the logo intact. But be aware the are separate press-on letters & images that make up the entire logo. I did not want to 'save' the logo so mine came up in pieces. Afterwards a simple cleaning with some glass cleaner and you would never have known that there was something stuck on that corner of the glass.
WheresWally is offline
post #9 of 13 (permalink) Old 02-04-2020, 08:02 AM
Rep: 12 (Unique: 9)
Yes, see above message.
See my reply to @TMatzelle60
It does peel off, just not by hand.
I agree it seems to be a great case for any type of custom loop, and the distribution plates available are really nice.
post #10 of 13 (permalink) Old 02-21-2020, 04:09 PM
criskoe's Avatar
Rep: 4 (Unique: 4)
I just removed it today with a flat razor. Same kind used to clean kitchen glass stove tops. LOL. New blade tho of course. It came off quite easy. No way i could of salvaged the logo tho to be re applied. It flaked off in small pieces. Honestly dont know why you would want to put it back on tho.
Something very interesting tho. Its completely removed now on my case. The glass is crystal clean. But if I fog up the area with my breath. The entire logo re appears! LOL. Its like some secret hidden message now. LOL. I re ran the blade over it a bit more and then applied some goo gone but still the logo re appears when you fog up the glass with your breath. LOL. Im not too concerned tho as its crystal clear otherwise.
criskoe is offline
