Spacing problem in posts (CONFIRMED) - Page 3 - Overclock.net - An Overclocking Community
Closed Thread
post #21 of 44 (permalink) Old 03-13-2019, 06:13 AM
Some call me... Bifford
BFRD's Avatar
I was really hoping that switching the stock WYSIWYG editor with CKEditor was going to work. This doesn't seem to be a tenable solution. I can get it installed and "working" but not well enough to publish. It is too big of a disconnect of the two systems to make CKE viable in a vB 3.8 environment. The visuals inside of the editor are in some cases completely different from what will be seen in the post (or preview).
So, I must look at different ways to fix the spacing issue. As of writing this post, I am unable to reproduce all of the issues being reported here. In fact, what I am seeing almost seems opposite. I am getting some CRLFs removed instead of added. Can someone please provide a simple step by step replication procedure for me? What browser with what plugins and in what configuration.
BFRD is offline
post #22 of 44 (permalink) Old 03-19-2019, 01:06 PM
Old to Overclock.net
Rep: 120 (Unique: 104)
I still get the spacing issue all the time, running FF + noscript + uBlock + Decentraleyes + HTTPS everywhere in enforcing mode. I am also completely blocking canvas drawing due to the fingerprinting protection I employ.
I only allow scripts from the first party domain overclock.net and allow .js from ajax.googleapis.com which gets captured by Decentraleyes which then serves me a locally hosted version of the library.
If I had to place my bets, the users experiencing the spacing problems are probably blocking scripts from this site. With my config above the site is 99% usable, only major problem seems to be the spacing issue when posting.
362436
(15 items)
AMD Ryzen 5 1600
Asus Prime X370-A AMD Ryzen AM4 DDR4
Gigabyte GeForce GTX 950
2x Corsair Valueselect 8GB 288 Pin DDR4 SDRAM DDR4 @ 2133
Corsair Force LS 2.5" 120GB SATA III MLC SSD
Optical Drive
Lite-On 24X SATA DVD/RW Optical Drive
Corsair RM550x 550W 80 Plus Gold
Noctua NH-L9A-AM4 Low-Profile
Antec NSK4100 Steel ATX Mid Tower
Operating System
Mint 18.2 x64
HP 24" LCD/LED 1920x1080
Keyboard
IBM PC-AT
Mouse
Logitech G5
Audio
Sennheiser HD650
Audio
Asus Essence STX II
xJumper is offline
post #23 of 44 (permalink) Old 03-19-2019, 01:59 PM
In VB's Basement
ENTERPRISE's Avatar
I no longer seem to have the issue with the spacing, I only run adblock. It could be a particular browser add in causing the issue somewhere along the line. If we cannot replicate soon, I will mark this down as a user end issue.
Need help with your account or something forum related ? Please use our Contact Us form
ENTERPRISE is offline
post #24 of 44 (permalink) Old 03-19-2019, 02:35 PM - Thread Starter
Waiting for 7nm EUV
tpi2007's Avatar
Rep: 898 (Unique: 504)
But you were able to replicate it last year. If it's extension related, is there any difference in your setup this year? Did you uninstall any extension you were using last year?
tpi2007 is offline
post #25 of 44 (permalink) Old 03-20-2019, 04:17 AM
In VB's Basement
ENTERPRISE's Avatar
No changes to the extensions. Browser updates yes, there have been changes on the site since this time that may have an effect. Not sure, but ultimately cannot replicate at this point in time, neither can BFRD.
post #26 of 44 (permalink) Old 03-20-2019, 04:50 AM
News Fiend
ryan92084's Avatar
TEST
TEST
TEST
TEST
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #27 of 44 (permalink) Old 03-20-2019, 04:54 AM
News Fiend
ryan92084's Avatar
Using firefox 65.0.2 (64-bit) and no active extensions my post above added several spaces. Method: quote a post typed TEST<enter><enter>TEST<enter><enter><enter>TEST<en ter><enter><enter><enter>TEST
edit: i see a version 66 is available so I'll retest. Quote wasn't required in above method and i don't know why it keeps adding a space in that one <enter>
edit4: retesting doing 1,2,3,4<enter>
test
test
test
test
test
edit5: still adds spaces
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #28 of 44 (permalink) Old 03-20-2019, 11:42 AM
In VB's Basement
ENTERPRISE's Avatar
Testing
Testing
Testing
Testing
post #29 of 44 (permalink) Old 03-20-2019, 11:44 AM
In VB's Basement
ENTERPRISE's Avatar
Testing
Testing
Testing
Testing
With Chrome Version 73.0.3683.75
post #30 of 44 (permalink) Old 03-20-2019, 11:44 AM
In VB's Basement
ENTERPRISE's Avatar
Chrome Test normal.
Closed Thread
You may not post new threads
