Unable to give trader rating. (CONFIRMED) - Overclock.net - An Overclocking Community
post #1 of 30 (permalink) Old 06-25-2018, 03:15 PM - Thread Starter
xxicrimsonixx's Avatar
Rep: 476 (Unique: 422)
Exclamation Unable to give trader rating. (CONFIRMED)
I don't know if it is just me, since the buyer was able to give me trader feedback for the same thread, but I keep getting the error: 'The deal URL is invalid!'
I would like to provide feedback for the transaction.
Also, I am unable to post attachments. I can either drag the file into the 'drag and drop file upload', in which it will display the image, but then close it immediately, without it uploading.
I can also select 'manage attachments' from the 'attach files' option under additional options. I can select the file, but when I hit upload, the file fails to upload.
The reason that I am including both issues in this single thread is that I cannot post the image of the trader feedback error. And also I had this issue previously when I tried making the marketplace thread in the first place, when I tried to upload images of the product. I had to upload the images to a third party, then post the images into the thread, rather than directly uploading to OCN.
Steam/Origin ID: xxicrimsonixx
i7 4930K
ASRock Fatal1ty X79 Professional
Gigabyte Aorus 1080ti SLI
16GB G. Skill Ripjaws Z
2x 250GB Samsung 840 Series SSD RAID 1
2x 3TB Seagate Barracuda 7200.14 RAID 1
Optical Drive
Samsung Burner w/ Lightscribe
Cooler Master Silent Pro 1200W Gold
Custom Watercooling
Cooler Master HAF 922 w/ Dust Filters
Operating System
Windows 10 Professional 64-bit
55" 4K Samsung Curved TV
Keyboard
Roccat Sova Mechanical
Mouse
Roccat Kone XTD
Audio
Glow Amp One > HD650
Audio
Yamaha Receiver + 5.1
Other
Xbox One Wireless Controller
xxicrimsonixx is offline
post #2 of 30 (permalink) Old 06-28-2018, 09:07 AM
In VB's Basement
ENTERPRISE's Avatar
We currently do not have the ability to upload or attach images on the site right now due to an ongoing technical issue.
As for the Trader Rating issue, please can you show me a screenshot of the error. Unfortunately you will need to use a third part image hosting service to do this.
Regards,
E
ENTERPRISE is offline
post #3 of 30 (permalink) Old 06-28-2018, 05:08 PM - Thread Starter
i7 4930K
Optical Drive
Custom Watercooling
Operating System
Keyboard
Mouse
Roccat Kone XTD
Audio
Audio
Other
post #4 of 30 (permalink) Old 06-28-2018, 05:11 PM - Thread Starter
Okay, I found the problem. When I copy the link it uses https.. The trader rating system only allows http, so I have to manually change https to http...
Is there any way to correct this? Or is this just how the system works?
i7 4930K
Optical Drive
Custom Watercooling
Operating System
Keyboard
Mouse
Roccat Kone XTD
Audio
Audio
Other
post #5 of 30 (permalink) Old 07-01-2018, 10:35 AM
In VB's Basement
ENTERPRISE's Avatar
Thank you for the follow up, looks like the feedback system just needs a small update to allow for HTTPS. Will escalate to the devs.
post #6 of 30 (permalink) Old 07-01-2018, 10:35 AM - Thread Starter
No worries, thank you!
i7 4930K
Optical Drive
Custom Watercooling
Operating System
Keyboard
Mouse
Roccat Kone XTD
Audio
Audio
Other
post #7 of 30 (permalink) Old 09-14-2018, 09:13 PM
michaelrw's Avatar
Rep: 49 (Unique: 29)
Hi, I'd just like to confirm that I have this bug too. Same exact situation that OP is reporting.
michaelrw is offline
post #8 of 30 (permalink) Old 09-15-2018, 12:16 AM
News Fiend
ryan92084's Avatar
Until the system is updated you'll need to remove the 's' from the https:// in the link and then it should work.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #9 of 30 (permalink) Old 10-29-2018, 06:55 AM
Yes
FaLLeNAn9eL's Avatar
Rep: 143 (Unique: 116)
I've tried removing the 's' from the http in the URL but it does not seem to work for me.
Classy Glassy
(17 items)
Core i7 6700k
ASUS Maximus VIII Hero
RTX 2080 FE
Corsair Vengence RGB Pro
Intel 520 Series
Samsung 850 Evo
Seagate Baracudda
850W Silverstone Decathlon
EK M8G Monoblock
EK-Vector RTX 2080 RGB
Lian-Li PC-O11 Dynamic
Operating System
Windows 10 64-bit
2 x Dell U2414H
Keyboard
Filco Majestouch Tactile Click "Otaku" NKRO
Mouse
Logitech G900
Mouse
SteelSeries QcK Heavy
Audio
Cambridge Audio Magic DAC
FaLLeNAn9eL is offline
post #10 of 30 (permalink) Old 10-29-2018, 06:57 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 952 (Unique: 587)
I just got done leaving feedback and it worked fine.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(7 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill 16GB DDR4 4133
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mousepad
X-Ray XL 26" x 14"
Audio
SMSL SA50 + FiiO E10K
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
Audio
AudioSource LS100
Audio
Polk Audio PSW111
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
You may not post new threads
