[Official] Creative Sound Blaster Z, Zx & ZxR Series Club - Page 594 - Overclock.net - An Overclocking Community
post #5931 of 6043 (permalink) Old 05-26-2019, 02:30 PM
Windows 10 Gamer
Rep: 46 (Unique: 38)
Quote: Originally Posted by Vlada011 View Post
Can you tried this. Uninstall all Creative drivers and with Driver Cleaner Pro and Driver Sweeper, delete all files and folders with Creative nime in Program File and Program Data and regedit manual. Do that without connection to internet.
Spoiler!
Newer version of driver don't have them at all.
I copy driver from Sound Blaster ZxR DVD to PC and long time ago and use him only.
If you have some newer I could upload you from 2013.
Why, pray tell, would he need to do all that when the patch apparently worked. The patch also works for me every time this issue has happened.
So, I am not even sure as to why you would recommend something as extensive as what you describe above since he does not need to do it....
The Dark Knight
(25 items)
i7 4930k
ASUS Rampage IV Black Ed
EVGA GTX 1070 SC ACX 3.0
G.Skill Trident X Series 32GB (4 x 8GB) DDR3-2133
Samsung 840 Pro
Western Digital BLACK SERIES 7200RPM
San Disk Ultra II
Seagate 4TB Gaming SSHD
Optical Drive
LG Blu Ray 16x Multi Disc
EVGA G2 1000w Gold Plus
Swiftech H 240-X
Watercool Heatkiller IV Pro Clean Acrylic
Swiftech H 140-X
Watercool Heatkiller IV Pro Nickel/Black 1070
Phantom 820 Black
Operating System
MS Windows 10 Pro
Vizio 24" 1080p TV
AOC G2460PG 24" 1ms (GTG) 144 Hz Gaming Monitor, NVIDIA G-SYNC
Keyboard
Corsair K95 RGB
Mouse
Logitech G502 Proteus Core
Mouse
None
Audio
Sound Blaster Zx
Audio
Logitech z906 5.1 surround speaker system
Other
NZXT Hue+
Other
NZXT Grid+ V2
Madmaxneo is offline
post #5932 of 6043 (permalink) Old 05-27-2019, 01:00 AM
Vlada011's Avatar
Rep: 39 (Unique: 29)
Patch alone not work if Windows improve driver for Sound Blaster ZxR any more and he will do that during check of automatic updates.
And Do Not Include Drivers with Updates will not help. After that he will have 3 options, 2 with different newer Sound Blaster Driver and 3rd will be Sound Blaster Controller with driver from 2017-2018 newer then drivers. DTS and Dolby Ditigal Live Pack will gone from Control Panel and mess will start again.
That's way how work with me. I didn't tried 1-2 times and then give him advice. That's procedure I use from 2017 when I bought SBZxR.
Every time I tried something different but at the end on this way problem gone. But I must note that Creative behave specific with ASUS X99 Chipset.
Creative told me that. All purpose of that is to stop only Sound Blaster to update driver and controller and Windows Update to stay enabled.
Driver from DVD is only normal and working driver and somehow he work with even Windows 10. That was driver for Windows 7 from 2013.
If he install him or even newer bad official drivers from 2015....very soon in Windows Update History - Driver Updates he will see Creative Sound Blaster Controller driver 2017/2018/2019.
Vlada011 is offline
post #5933 of 6043 (permalink) Old 05-27-2019, 08:58 AM
Windows 10 Gamer
The patch worked for me and quite a few other people, people that have the ZxR. A local friend of mine had the same issue with his ZxR but when I gave him the patch it worked for him just fine. He hasn't had an issue since, and that was more than a year ago.
The Dark Knight
(25 items)
i7 4930k
Samsung 840 Pro
San Disk Ultra II
Optical Drive
Swiftech H 240-X
Swiftech H 140-X
Phantom 820 Black
Operating System
MS Windows 10 Pro
Vizio 24" 1080p TV
Keyboard
Corsair K95 RGB
Mouse
Mouse
None
Audio
Sound Blaster Zx
Audio
Other
NZXT Hue+
Other
NZXT Grid+ V2
post #5934 of 6043 (permalink) Old 05-31-2019, 11:46 AM
V1per's Avatar
Rep: 0
So it started acting up on me again a couple of days ago, reinstalled the sbx_fix.reg (without reinstalling the drivers) and restarted my PC and everything is working great again.
Not sure what changed (was playing Skyrim SE again when it happened) but reinstalling the patch seems to have worked.
Really wish Daniel K would fix these friggin' drivers for ZxR, without his drivers my X-FI would not work properly on win 10.
Here's hoping
ASUS ROG Crosshair VII Hero (Wi-Fi) X470, AMD Ryzen 7 2700X @ 4.3Ghz, 32GB G.Skill TridentZ RGB Series DDR4 @ 3200Mhz, ASUS ROG Strix RTX 2080 Super, Advanced, OC 8GB 256 Bit, Creative Sound Blaster AE-9 Audio Card / DAC, Intel 660p Series NVME 512Gb SSD, WD Blue 3D NAND 1TB PC SSD, DeepCool Castle 240RGB Liquid Cooler, EVGA SuperNova 220-G2-XR 80 Plus Gold 850 Watts, NZXT Sentry 3, Fan Controller, CM Storm Sniper Mid-Tower Case, XboX One Wireless Controller, Windows 10 Pro v1909 64 bit
V1per is offline
post #5935 of 6043 (permalink) Old 06-04-2019, 05:46 PM
Rep: 0
No way to work fine here, I tried everything I found in this thread but no success with optical connection in my sbz card.
sngbird is offline
post #5936 of 6043 (permalink) Old 06-07-2019, 01:02 PM
Rep: 0
I think I learned the way to deal with this stupid problem, the patch posted here works and prevents audio from cutting off over optical connection, but in headphone mode you can't leave dolby digital live/dts connect on combined with SBX Pro Studio because if you do that, channels eventually will change (even in HP mode) or you will get some crap static on your audio, I'm not sure if the same happens in speakers mode (still testing) but I think there is some incompatibility between audio decoders and SBX Pro Studio.
sngbird is offline
post #5937 of 6043 (permalink) Old 06-10-2019, 10:07 PM
The IT guy...
OrionBG's Avatar
Rep: 10 (Unique: 8)
Hey guys,
I might have stumbled upon a solution for the SBZ cracking/channel swap issues on Windows 10! With that "fix" I've got more than 3 hours yesterday of perfect 5.1 Dolby Digital Live sound and I'll continue testing for the next day or two to make sure it works properly. Before that "fix" I couldn't even get 10 minutes of proper sound.
BTW I'm running Windows 10 Pro 64bit v1903.
Will let you know how it goes.
Orion-TR4
(12 items)
Threadripper 1950x
Asrock x399 Taichi
EVGA 1080 Ti FE
Samsung PM961 Nvme SSD
Samsung 850 EVO SATA SSD
Intel 5400S SATA SSD
Corsair HX1000i
Custom Loop mostly EKWB
Lian-Li PC-O11 WGX ROG Edition
Operating System
Windows 10 Pro
Audio
Sound Blaster Z
OrionBG is offline
post #5938 of 6043 (permalink) Old 06-11-2019, 08:24 PM
Windows 10 Gamer
Quote: Originally Posted by OrionBG View Post
Hey guys,
The patch that has been listed in this thread multiple times (sometimes by me) has worked for me perfectly. I have had to re-install the patch on a few updates but I have not had to do it in a long time now. I currently do not have 1903 on my desktop yet though.
The Dark Knight
(25 items)
i7 4930k
Samsung 840 Pro
San Disk Ultra II
Optical Drive
Swiftech H 240-X
Swiftech H 140-X
Phantom 820 Black
Operating System
MS Windows 10 Pro
Vizio 24" 1080p TV
Keyboard
Corsair K95 RGB
Mouse
Mouse
None
Audio
Sound Blaster Zx
Audio
Other
NZXT Hue+
Other
NZXT Grid+ V2
post #5939 of 6043 (permalink) Old 06-12-2019, 06:44 AM
The IT guy...
OrionBG's Avatar
Rep: 10 (Unique: 8)
So here is a little story with a happy (for now) ending...
An year or so ago I finished my newest PC and the Sound Blaster Z was a part of it. The one in my signature.
All of this was put to work by everybody's "favorite" OS Windows 10. Aaaand the issues started...
Brand new platform (back then) there were BIOS issues, Driver issues, compatibility issues and of course the SBZ Dolby Digital Live issue... Somehow back then I was able to fix the issue and I had no issues with is until about 3 weeks ago when I got the 1903 Windows 10 update and also I updated my BIOS to the latest one. I tried everything... Clean reinstall of Windows, going back to the BIOS I had before, tried all available drivers and registry patches, HPET Enable/disable, I even contacted Creative's technical support, but all I was able to get from them for more than 10 days was several different versions of that same registry patch (just different values in the keys). At least they acknowledged that there is such an issue with some specific hardware configurations.
Two days ago while reading other posts and articles for that same issue, I clicked on a link that sent me to Microsoft's web site (Microsoft Update Catalog or something like it) there I saw all the Creative Sound Blaster drivers that were ever released on Windows Update. What caught my eye were the driver versions: for SBZ the ones they have are version 6.0.102.xx and 6.0.103.xx while the a lot newer drivers for the Sound BlasterX AE5 (the fancy one with the RGB) the latest version is 6.0.105.17.... Then a thought pop'd in my head... what if I can use those newer (supposedly made for Windows 10) drivers on the SBZ? It appears that both the SBZ series and the newer SBX AE5 are using the SoundCore3D Audio processing unit (or at least very similar versions of it).
At first I tried directly installing the driver on top of what I already had but Windows stated that there is no compatible driver in the folder and sent be packing...
After mentioning some mothers... I opened the INF from the SBX AE5 driver and the INF from the SBZ driver and oh miracle! Those had almost identical structure sans the hardware IDs and some additional things pertaining to what hardware is supported by the driver. Confidant in my skills (or lack of such) I copied all the relevant lines from the SBZ INF with the hardware IDs describing the Sound Blaster Audio Controller and the Sound Blaster Z Audio Device to the SBX AE5 INF and tried installing it again... That of course didn't work as after modifying the INF file, the Digital Certificate was now broken and Windows sent me packing again but this time I was prepared! I quickly rebooted to Advanced Startup Options and used F7 (or only 7) for Disable Driver Digital Certificate Enforcement (or whatever it was exactly).
This time the driver installed for both devices and asked me to reboot.
After reboot (and no BSOD which I expected to be fair) I still had sound! I went in device manager to check if the "new driver" is really installed and it was. Then I checked Sound Blaster's control panel and all the setting were back to their default ones (just like after you just installed the driver) I enabled DDL (5.1 was already selected by default) and oh sweet music for my ears everything was working!
It has been 3 days since then and I watched a lot of movies, Youtube and what not and there have been ZERO audio issues with DDL (no, distortions, no channel swapping, no audio cutouts).
Now for the part you've all been waiting for... DISCLAIMER
YOU ARE FOLLOWING THE STEPS BELOW AT YOUR OWN RISK!! I'M NOT RESPONSIBLE FOR ANY DAMAGE THAT YOU MAY CAUSE TO YOUR WINDOWS OS BY IMPROPER INSTALLATION OF THE DRIVER!!!
I HAVE TESTED THIS MOD ONLY ON MY SYSTEM AND IT WORKS FOR ME. THERE IS NO 100% GUARANTEE THAT IT WILL WORK FOR YOU!
The attached driver will only work properly on Windows 10 64bit (I did not bother with the 32bit part of the INF)
1. Download and install the newest available driver for the Sound Blaster Z (this is needed for all the software things like the Sound Blaster Control Panel, DDL, Speaker Setup and so on.) At this point you will have sound and you may even get up to 30 minutes of proper DDL before it begins to act-up... (If you already have the driver installed you can skip this step) Newest driver I have found is this one: LINK
2. Download and unpack the attached archive. Inside is the moded AE5 driver and the last registry patch that I was sent by Creative. Apply the registry patch.(not sure if it is needed but since I have already applied it before doing all this, it may be a part of the solution. Anyway it will not hurt anything to apply it)
3. Go to Settings>Recovery>Advanced Startup and click on "Restart now". Then click Troubleshoot>Advanced options>Startup Settings and click on Restart.
The system will reboot and will present you several options. Press F7 (or just 7) on the keyboard. This will disable the Digital Signature Enforcement and will allow the installation of the modded driver.
4. After the system loads, go to Device Manager and right-click on the "Sound Blaster Audio Controller". Select "Update Driver" then select "Browse my Computer..." On the next screen choose "Let me pick from a list....", then on the next screen click on "Have Disk" and find the folder you extracted the driver in. If you did it right you will be greeted with a single "Sound Blaster Audio Controller" option. Next and so on until the driver is installed. It will ask to reboot but not yet.
5.Still in Device Manager, right-click first on the "Sound Blaster Z" device and repeat the procedure from step 4. Now you can restart.
6. After reboot have completed, go to the Sound Blaster Control Panel (it should be in your taskbar) and check if 5.1 is selected and then enable DDL from the "Cinematic" tab.
7. Enjoy and report back if it worked for you.
Awaiting feedback...
Orion-TR4
(12 items)
Threadripper 1950x
Asrock x399 Taichi
EVGA 1080 Ti FE
Corsair HX1000i
Operating System
Windows 10 Pro
Audio
Sound Blaster Z
OrionBG is offline
post #5940 of 6043 (permalink) Old 06-12-2019, 06:47 AM
The IT guy...
OrionBG's Avatar
Rep: 10 (Unique: 8)
That patch also worked for me an year ago but things went South with the 1903 update. Only the above mod did it for me.
Orion-TR4
(12 items)
Threadripper 1950x
Asrock x399 Taichi
EVGA 1080 Ti FE
Corsair HX1000i
Operating System
Windows 10 Pro
Audio
Sound Blaster Z
OrionBG is offline
