[Official] Creative Sound Blaster Z, Zx & ZxR Series Club - Page 597 - Overclock.net - An Overclocking Community
post #5961 of 6043 (permalink) Old 07-16-2019, 08:17 PM
umeng2002's Avatar
Rep: 175 (Unique: 111)
I've always used my SBz with and external DAC. I have it purely for the DSP functionality.
AMD Ryzen 2700X
Asus Prime X470-Pro
EVGA GeForce RTX 2070 XC Ultra
TeamGroup T-Force 16 GB (2x8) Pro Dark (B-die TDPGD416G3200HC14ADC01)
ADATA XPG SX8200 Pro 512GB NVMe
Seasonic Focus Plus Platinum SSR-750PX
Corsair H80i (not V2 or GT)
LG 34UC80-B
Keyboard
Logitech G413
Mouse
Logitech G503 RGB
Audio
Creative SoundBlaster Z (OEM)
umeng2002 is offline
post #5962 of 6043 (permalink) Old 07-22-2019, 06:42 AM
EarlZ's Avatar
Rep: 27 (Unique: 25)
That would be via optical right? Can you share how you have your SBZ software configured as sometimes I can get lost and not get audio, what I have noticed is that the volume is is now determined under "What you hear" and DD-Live Encoder is needed for audio even on 2.0 / 2.1 mode ?
9700K / Gigabyte Z390 Master / Gigabyte 2080TI Gaming OC / 32GB G.Skill Trident Z RGB 3200Mhz CL16 / Samsung Evo 860 & 850 500GB / Creative Sound Blaster Z / Acer Predator X34P
EarlZ is offline
post #5963 of 6043 (permalink) Old 07-22-2019, 07:02 AM
umeng2002's Avatar
My setup is for headphones, so Windows is on default 5.1 configuration (so games and other software sends surround data to the card); but the SBz control panel is set to Headphones (so the surround data gets HRTF processed for headphone surround when enabled). Also, the "Play stereo mix to digital output" is checked under the Advanced Features panel.
For speakers, you don't need the encoder for stereo. But for surround speakers, you need to use an encoder since SPDIF is stereo only. "What you here" isn't needed for anything unless you want to record stuff... Maybe the encoders work off of the "what you here" feed, but I'm not sure.
If you use the encoder, you can't have your Mic App access disabled in the Windows 10 settings. I'm not sure if that "bug" ever got fixed, but last time I tried it, you couldn't globally disable mic access to Apps in Win 10.
AMD Ryzen 2700X
Asus Prime X470-Pro
LG 34UC80-B
Keyboard
Logitech G413
Mouse
Logitech G503 RGB
Audio
post #5964 of 6043 (permalink) Old 07-22-2019, 03:36 PM
EarlZ's Avatar
I'll give 'send stereo mix' a try, I will be running with a 2.1 system and will use the Topping DX3 Pro. By using digital stereo mix will that still allow me to use the DSP on the SBZ via optical?
I am not recording anything but I find it really strange that the volume is controlled under what you hear and the usual volume control just becomes an mute/unmute toggle.
EarlZ is offline
post #5965 of 6043 (permalink) Old 07-22-2019, 06:59 PM
umeng2002's Avatar
That's exactly what it's for.
I even have my "what you hear" volume muted since that can cause double audio in some situations. Your volume might be controlled by that since you haven't been using the "play stereo mix to digital output."
AMD Ryzen 2700X
Asus Prime X470-Pro
LG 34UC80-B
Keyboard
Logitech G413
Mouse
Logitech G503 RGB
Audio
post #5966 of 6043 (permalink) Old 07-23-2019, 12:43 AM
EarlZ's Avatar
I get the following results;
Speaker config on SBZ control panel is set to stereo
Play Stereo mix to digital output is ticked
No encoder
I get no audio with speaker selected as play back device but I do see the sound meter in windows move up and down and my Z5500 control pod is saying no digital data
Changing the encoder type to DD-Live / DTS gives me audio with What U Hear as the volume control.
Selecting Play Stereo mix to digital output seems to do nothing for me
EarlZ is offline
post #5967 of 6043 (permalink) Old 07-23-2019, 01:08 AM
umeng2002's Avatar
Make sure the SPDIF-Out volume is unmuted and all the way up in the Mixer panel. The SPDIF device cannot be disabled since it's being use to output the audio. make sure your speaker system is set to PCM and not DTS or DD.
AMD Ryzen 2700X
Asus Prime X470-Pro
LG 34UC80-B
Keyboard
Logitech G413
Mouse
Logitech G503 RGB
Audio
post #5968 of 6043 (permalink) Old 07-24-2019, 04:45 AM
Vlada011's Avatar
Rep: 39 (Unique: 29)
I think it's time to move from SBZ series to AE Series?
Vlada011 is offline
post #5969 of 6043 (permalink) Old 07-24-2019, 06:48 AM
vf-
vf-'s Avatar
Rep: 5 (Unique: 5)
What a throwaway society.
vf- is offline
post #5970 of 6043 (permalink) Old 07-24-2019, 07:50 AM
umeng2002's Avatar
the Sound Blaster Z still works fine. Besides, how does the headphone surround of the AE series compare to the SBz line?
I got a SBz OEM from ebay for $30 years ago. I don't think creative makes a cheap AE card.
AMD Ryzen 2700X
Asus Prime X470-Pro
LG 34UC80-B
Keyboard
Logitech G413
Mouse
Logitech G503 RGB
Audio
