Suggest New Computer Speakers (My Left M-Audio AV-40 Speaker Quit Working) - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 06-07-2013, 10:38 AM - Thread Starter
RoddimusPrime's Avatar
Rep: 89 (Unique: 77)
I have been getting a little tired lately of my Klipsch Pro Media 2.1 setup. It is decent for sure, but perhaps not the absolute best audio quality as I became used to my M-Audio AV40 speakers. The AV-40's while lacking in bass and it's relevant frequencies were great for audio quality and how clean the audio came through.
They both are going through my Xonar Essence STX. Which does a good job.
However, my left AV-40 speaker busted and for some reason simply will not work anymore. I tested switching lines and speakers, and it's just that speaker that won't produce audio. Not sure why. So I am now using my Klipsch Pro 2.1 setup.
What I would like to do now is aim for a 2.1 setup. Two quality speakers. Plus perhaps add a Dayton, HSU, or Velodyne sub. But, I am not sure how my soundcard would handle that as it does not exactly have an option for a base hookup unless I am mistaken (am I?).
My computer is also hooked up to my TV. So occasionally I will put whatever I am watching on the big screen.
Secondly, if I am going to get a decent 2.1 setup, I thought about trying to achieve the ability to have my TV able to use the speakers as well. The only way I know how that would work is by using a receiver. I would want that receiver to have two audio out options that can function independently. So if I want to watch TV while working/gaming on my PC with audio I can. I don't think I need an external DAC by any means.
So yes, I want to play both music and movies through these future speakers.
My budget? Around $300 for the computer speakers and then a reasonable price for the sub. A receiver would have to be quality, but cheaper. As long as it served my needs functionally, I would be satisfied.
My main goal would be able to figure out a new set of speakers and how I can hook up a sub with them.
It does not bother the wolf how many the sheep may be.
RoddimusPrime is offline
post #2 of 3 (permalink) Old 06-07-2013, 10:50 AM
Rep: 609 (Unique: 499)
You could try to fix the speaker that went out.
Audio setup: Xonar Essence ST into Niles SI-275 amplifier driving CSW Tower II speakers paired with M&K MX-70 subwoofer. Headphones: DT880 Pro 250ohm
Mygaffer is offline
post #3 of 3 (permalink) Old 06-07-2013, 12:15 PM - Thread Starter
That won't give me a 2.1 setup, and a sub doesn't seem to be an option with these unless I hook it up to a receiver.
Would not even know what to look for if I opened the speaker up.
