How to get the most out of my ATH-M50 headphones - Page 2 - Overclock.net - An Overclocking Community
post #11 of 17 (permalink) Old 07-13-2014, 08:31 PM
smithydan's Avatar
Rep: 94 (Unique: 84)
You can go over to head-fi to get the best possible info on these, tons of it, from modding the eq-ing
There is also a procedure or method used before doing anything with the headphones to get the 'true' output, this is to let them 'burn in' for a period of them, which is usually playing a diverse set of music to work in the drivers, usually a good set of hours. People recommend up to 100 hours whilst some will do 40-75.
Just a side note, the m50s comes with a straight cable and the m40x is the same thing but comes with two removeable cables, straight and coiled in case you wanted to change.
smithydan is offline
post #12 of 17 (permalink) Old 07-13-2014, 09:15 PM - Thread Starter
Twitch Streamer
Aesthethc's Avatar
Rep: 104 (Unique: 79)
Yeah i saw that forum maybe ill read some things off there to get some more information to learn.
Wait, burn in period? Really? This, ive never heard of. And when you mean drivers, you mean like physical hardware "drivers"? not like the drivers from software right?
And what do you mean, the M50 and M40x is the same? I have a bunch of cables here though, is there any advantage besides the cable issue?
i7-3930k 4.5GHz | EVGA GTX 1080Ti | 1440p 144hz IPS | Cooled by EKWB
PU:BG & Twitch - FarmerMeoow
Aesthethc is offline
post #13 of 17 (permalink) Old 07-13-2014, 09:56 PM
kkit0410's Avatar
Rep: 2 (Unique: 2)
That burn-in thing..
I am not audiophine but i think if you uses daily, you don't have to do that.
unless you got 10 pair of headphones and "Ain't nobody got time for dat"
kkit0410 is offline
post #14 of 17 (permalink) Old 07-13-2014, 10:02 PM - Thread Starter
Twitch Streamer
Aesthethc's Avatar
Yeah ill be using this daily so im bound to go through the burn in period regardless if it exists or not rolleyes.gif
post #15 of 17 (permalink) Old 07-18-2014, 06:36 AM
smithydan's Avatar
Yeah, physical drivers, the little 'speakers' in the headphones.
The m50 and m40x are the same just that the m40x has detachable cables, a coiled and a straight cable. No cable issue just that coiled cables are heavy and can be a nuisance sometimes.
post #16 of 17 (permalink) Old 07-19-2014, 10:30 AM
musicPC's Avatar
Rep: 88 (Unique: 82)
Well, not all of us notice difference or improvement after some good hours of use. Don't pay much attention to that, just enjoy.
musicPC is offline
post #17 of 17 (permalink) Old 05-22-2020, 12:53 PM
Rep: 0
Filter 1: ON PK Fc 31 Hz Gain 2.0 dB Q 1.41
Filter 2: ON PK Fc 62 Hz Gain 2.1 dB Q 1.41
Filter 3: ON PK Fc 125 Hz Gain -3.7 dB Q 1.41
Filter 4: ON PK Fc 250 Hz Gain -3.0 dB Q 1.41
Filter 5: ON PK Fc 500 Hz Gain 5.1 dB Q 1.41
Filter 6: ON PK Fc 1000 Hz Gain -1.5 dB Q 1.41
Filter 7: ON PK Fc 2000 Hz Gain -0.1 dB Q 1.41
Filter 8: ON PK Fc 4000 Hz Gain 0.9 dB Q 1.41
Filter 9: ON PK Fc 8000 Hz Gain 1.4 dB Q 1.41
Filter 10: ON PK Fc 16000 Hz Gain -4.0 dB Q 1.41
splitnerve is offline
