SoundBlasterX G6 Mic Input is... Terrible? - Overclock.net - An Overclocking Community
post #1 of 69 (permalink) Old 10-02-2018, 06:03 PM - Thread Starter
Cyph3r's Avatar
Rep: 212 (Unique: 186)
So I recently got a SoundBlasterX G6 - I've been using a Vmoda boom pro mic with my onboard sound previously which honestly, it sounded pretty good.
However, the G6 mic input in comparison sounds horribly compressed and "thin"?
I've made a comparison recording, G6 recording first, onboard mic input afterwards. Is it just me or does the onboard mic input sound significantly better? Am I missing something? Surely a £130 device should perform better than onboard audio in every aspect.
Click to Listen
Both recordings are completely untouched in anyway. 100% input volume and 20db boost on both inputs.
Meshify C
(16 items)
Intel i7 8700k
ASRock Z370 Taichi
Asus ROG 1080 Ti Strix
Team Dark Pro 16GB DDR4 3600MHz
Samsung 850 Evo 1TB
Seagate Barracuda 4TB
Corsair RM850i
Noctua NH-D15S
Fractal Design Meshify C
Operating System
Windows 10 Home
Sony KDL-40HX853
Keyboard
Coolermaster Quickfire Rapid TKL
Mouse
Logitech G403 Wireless
Audio
Sennheiser HD558
Audio
Philips Fidelio X2/00
Audio
Creative Sound BlasterX G6
Cyph3r is offline
post #2 of 69 (permalink) Old 10-02-2018, 06:19 PM
PC Gamer
oxidized's Avatar
Rep: 24 (Unique: 23)
Wow pretty interesting. I mean they sound too much different, are you sure it's untouched? The G6 recording sounds like is kinda filtered, like the noise suppression is enabled and disabled in the onboard audio chip.
I own a G5 and wanted to sell this to get a G6, but won't do that if it sounds that "bad". Which program did you use to record anyway?
oxidized is offline
post #3 of 69 (permalink) Old 10-02-2018, 06:30 PM - Thread Starter
Cyph3r's Avatar
I swear on my life I haven't touched the recordings - recorded straight into Audacity (same project and track) and exported out to MP3.
My friend on Discord pointed out that my mic sounded different so I investigated and lo and behold the G6 is producing this weirdly compressed nonsense.
I can't see any settings relating to the mic input in the G6 software apart from the input volume and boost. I've sent this over to Creative tech support aswell and I'm really hoping they'll tell me there's something wrong with my unit and it's not supposed to be like this.
If this is just how it is, then I'll be returning it to them.
Meshify C
(16 items)
Intel i7 8700k
ASRock Z370 Taichi
Samsung 850 Evo 1TB
Corsair RM850i
Noctua NH-D15S
Operating System
Windows 10 Home
Sony KDL-40HX853
Keyboard
Mouse
Audio
Sennheiser HD558
Audio
Audio
Cyph3r is offline
post #4 of 69 (permalink) Old 10-02-2018, 06:46 PM
PC Gamer
oxidized's Avatar
Alright then, well i see your point, i wouldn't buy a 150€ audio card to have my mic sound like that.
Anyway it's not completely ruled out there's something going on at drivers level or even more possibly with the soundcard panel, which could be "forcing" the noise suppression on, i mean that really sounds like a noise suppressed mic.
oxidized is offline
post #5 of 69 (permalink) Old 10-02-2018, 06:51 PM - Thread Starter
Cyph3r's Avatar
Anyway it's not completely ruled out there's something going on at drivers level or even more possibly the sound panel could be "forcing" the noise suppression on, i mean that really sounds like a noise suppressed mic.
That was my first though that there was some echo/noise suppression that was enabled by default on the G6... but there's no option for it anywhere.
I've heard that the Sennheiser GSX1000 has forced processing on the mic input which causes a similar issue and can't be disabled which is one of the reasons I went with the Creative because they're usually pretty good at opening all the options up on their control panel.
Guess I just have to wait and see what Creative tech support says.
Meshify C
(16 items)
Intel i7 8700k
ASRock Z370 Taichi
Samsung 850 Evo 1TB
Corsair RM850i
Noctua NH-D15S
Operating System
Windows 10 Home
Sony KDL-40HX853
Keyboard
Mouse
Audio
Sennheiser HD558
Audio
Audio
Cyph3r is offline
post #6 of 69 (permalink) Old 10-02-2018, 06:58 PM
PC Gamer
oxidized's Avatar
A guy i know tried the GSX, mic audio was meh at best, so i can see what you refer to, it could probably be some kind of "bug" or maybe still have to add the toggle...Who knows...
Yes please, i'm really interested in that, i'd be really glad if you kept this up to date!
oxidized is offline
post #7 of 69 (permalink) Old 10-02-2018, 07:03 PM - Thread Starter
Cyph3r's Avatar
I do hope it's something they can fix.
I tried a few more things, I went into the Windows mic properties for the G6 mic input, on the advanced tab there is a tick box that says "Allow extra signal processing by the sound device". I got excited and disabled it - there's no difference unfortunately.
I then though I'd try the G6 direct mode - but the mic input completely dies in direct mode?! Another complaint to Creative...
Meshify C
(16 items)
Intel i7 8700k
ASRock Z370 Taichi
Samsung 850 Evo 1TB
Corsair RM850i
Noctua NH-D15S
Operating System
Windows 10 Home
Sony KDL-40HX853
Keyboard
Mouse
Audio
Sennheiser HD558
Audio
Audio
Cyph3r is offline
post #8 of 69 (permalink) Old 10-02-2018, 07:08 PM
PC Gamer
oxidized's Avatar
Have you tried updating firmware and software already? Seems like there a couple of different version of software, and a newer firmware on the support website
oxidized is offline
post #9 of 69 (permalink) Old 10-02-2018, 07:10 PM - Thread Starter
Cyph3r's Avatar
Yep updated the firmware as soon as I got it because the software prompted me too. Also got the latest version of the software (I got the G6 in hand yesterday).
After using the spectrum analysis in Audacity, it's quite easy to see why the G6 sounds worse:
SoundBlasterX G6 Mic Input:
Onboard Audio Mic Input:
All of the low end is completely rolled off and everything after ~8000Hz is just cut off entirely. What the hell Creative?!
Meshify C
(16 items)
Intel i7 8700k
ASRock Z370 Taichi
Samsung 850 Evo 1TB
Corsair RM850i
Noctua NH-D15S
Operating System
Windows 10 Home
Sony KDL-40HX853
Keyboard
Mouse
Audio
Sennheiser HD558
Audio
Audio
Cyph3r is offline
post #10 of 69 (permalink) Old 10-02-2018, 07:15 PM
PC Gamer
oxidized's Avatar
Jeeeeeeez, well that actually looks like a filter, let's hope it is one, i'm not actually sure my voice sounds like that on the G5, i'm currently using one of those smartphone headsets, so the built-in mic isn't really test-bench stuff, although it sounds alright according to the people i chat with.
Also, pardon the ignorance, which program did you use to give you that nice spectrum? I kinda curious to see what my mic "looks" like.
oxidized is offline
