PCIe card help please, similar to auzentech prelude - Page 2 - Overclock.net - An Overclocking Community
post #11 of 19 (permalink) Old 02-16-2019, 04:46 PM - Thread Starter
Dunan's Avatar
Rep: 20 (Unique: 19)
Quote: Originally Posted by acquacow View Post
Best audio these days for PCs is with an external USB DAC. You get power and data isolation and much cleaner D2A conversion, plus amplification if desired.
Don't go internal, there's way too much noise inside your case.
I would have to be able to link it to the 4.1 setup I have, and from what I understand the external USB DAC is for headphones? I don't really know though, I this is the first time in at least 8 yrs that I've looked at audio devices for PC's. I already have a headphone amp on the desk, but I don't use headphones nearly as much as I used to.
Skyrim fans!!
Check out Redoran Guard's Skyrim Battles!!
Custom characters and battles from ES lore!
Dunan is offline
post #12 of 19 (permalink) Old 02-16-2019, 05:01 PM
Tiihokatti's Avatar
Rep: 262 (Unique: 212)
Make sure you are using proper source material (5.1 preferably). Also make sure that you are not using stereo upmix on the old setup.
Honestly the 4.0 speaker setups are museum stuff these days, there are no audio materials available for it and the closest kind of material is 5.1. But you would still be missing the LFE soundtrack as there is no separate subwoofer channel.
Just a reminder: YouTube is not good for surround sound testing. The 5.1 support was added only recently and even then there are hurdles to make it work correctly.
Ppl should learn to add more info to their posts when they ask for help...
OCN Anime/Manga Club
[Official] OCN Headphones and Earphones Club
Tiihokatti is offline
post #13 of 19 (permalink) Old 02-16-2019, 06:11 PM
Rep: 455 (Unique: 387)
The problem for me is I can't check that 4.1 Youtube because I don't have the hardware anymore. I suffered the same fate as you @Dunan Up until Christmas I had the Essence ST, but no PCI on the new board so it's just sitting there (along with a USB TV tuner that still accepts all UK channels but no driver). I ended up ditching surround, got a USB dac/amp with headphone and line out and will eventually replace my ageing 5.1 reciever with a stereo amp.
I'm not sure ASUS is in quite the same league as Auzentech though, at least in the driver department, I doubt a new STX will support any more configurations than your onboard - Probably a better chance with the OMEGA eCLARO but that's only a wild guess though. I don't think flexibility is catered to the way it used to be. I'd be 100% certain before getting anything.
Do you get sound from the rear when you use the test function in the Windows speaker settings?
If you're thinking about a soundcard it might be better to stick with the onboard you have and update your powered speakers instead, I haven't had to buy PC speakers for as long as you though, doubt I can be much help.
Darren9 is offline
post #14 of 19 (permalink) Old 02-16-2019, 06:52 PM - Thread Starter
Dunan's Avatar
Some of the reviews I've read about the Asus is that it's pretty high quality components and is supposed to be on par or surpass the prelude, but I'd have no real way of knowing unless I hear it myself. Apparently that is Asus's audiophile card. The eCLARO I was looking at as well, because from one of the amazon reviews there was a person in my exact same situation - 4.1 klipsch/auzentech (not prelude, I forget the model) setup, and cant get the rears to work on the motherboard audio. He commented that the klipsch indeed will work with the eCLARO so if if the Asus wouldn't work, the eCLARO would be the choice.
When I run the test sounds through either the windows sound or realtek control panel, they come thru all speakers and can test each speaker individually. It's not the source material that is the issue, I was playing resident evil 2 remake, and I still got nothing out of the rears while on the PC with the auzentech, everything comes out of all speakers as it should.
Anyone have any opinions on the HT OMEGA eCLARO? It's probably not on par with the Asus but its got to be better than a sound blaster.
Skyrim fans!!
Dunan is offline
post #15 of 19 (permalink) Old 02-16-2019, 07:32 PM
Not a linux lobbyist
rluker5's Avatar
Rep: 49 (Unique: 37)
Quote: Originally Posted by Dunan View Post
Hey all, I have an auzentech prelude 7.1 PCI card in my old system, and love the sound but am having a hard time finding a PCIe replacement of the same quality. I'm currently looking at a few options like the ASUS Sound Card Essence STX II or the HT OMEGA eCLARO, with the outputs on the eCLARO being very similar to the auzentech, which would seem to be easier to use with my old Klipsch 4.1. As of right now, I cant get the rear speakers to work with any onboard audio regardless of the onboard setting (quadrophonic, etc).
The Asus has RCA outputs on the card I believe and a 4pin connection and that's where I run into issues with that card.
Do you guys have any suggestions I can try or how I can get the Asus to work with the Klipsch 4.1?
If you can't find an acceptable replacement, and have case space, and don't mind the ungainly appearance, they do sell pcie to pci adapters: https://www.amazon.com/Sintech-PCI-E...gateway&sr=8-8
L5
(17 items)
Lea2
(11 items)
L7
(11 items)
5775c
Maximus VII Hero
Aorus 1080ti Waterforce
16 Gb Gskill Trident @ 2400,cas10,1.575v
8 Gb Gskill Trident @ 2400,cas10,1.575v
1Tb Team ssd
seagate barracuda 3T
Optane 900p 480G OS
Optical Drive
Asus BW-16D1HT
EVGA Supernova 1300 G2
Cooler Master MasterLiquid Pro 120 (cpu)
2 140mm case fans, 2 120mm
Fractal Design R4 (no window)
Operating System
W10 64 pro
panasonic TC-58AX800U
Audio
Focal Elear, Nova 40, 598se, HE4xx, DT990pro w b.boost earpads
Audio
SoundbasterX AE-5, onboard
4770k
Asus Z87 Deluxe
Fury Nitro
8Gb klevv urbane 2133
ROG Raidr 240Gb pcie
1Tb WD blue
Pc Power&Cooling silencer Mk2 950w
Deepcool Lucifer V2
DIYPC P48-W
Operating System
W10 64 pro
40"tv
4980hq
Asus H81T/CSM
8Gb 1600 samsung
Samsung 850 evo 120gb
Skyvast 90w brick for hp pavilion something
SilverStone Tek Super Slim
SilverStone Tek PT13B
Operating System
W10 64 pro
24" samsung 1080p
Keyboard
Logitech K400+
Other
Intel wifi ac card and noname antennas
rluker5 is offline
post #16 of 19 (permalink) Old 02-17-2019, 10:42 AM - Thread Starter
Dunan's Avatar
Well I tried some sound comparisons with the onboard audio on the MSI board vs the auzentech and it's really no comparison, the auzentech is much cleaner and clearer sounding and now I'm really anxious to try something else.
I guess it comes down to the eCLARO or the Asus, does anyone have experiences with either and have an opinion on which one is better?
Skyrim fans!!
Dunan is offline
post #17 of 19 (permalink) Old 02-17-2019, 11:41 AM
Overclocking Enthusiast
ozlay's Avatar
Rep: 279 (Unique: 221)
EVGA NU?
In Loving Memory Of Kassandra
Kaby
Rikka
(9 items)
Intel I5-7600k
Asrock Z270M Extreme 4
Titan X
Gskill Royal
970 Evo
Optane 900p
Seasonic Prime Snow
enthoo evolv matx tempered glass
Operating System
windows 10 pro
ozlay is offline
post #18 of 19 (permalink) Old 02-17-2019, 12:17 PM - Thread Starter
Dunan's Avatar
Quote: Originally Posted by ozlay View Post
EVGA NU?
Haven't heard of it, researching now. I just need it to work with the promedia 4.1's. I was about to take the plunge on the eCLARO but I'll check out this card first.
Edit: checked out the EVGA, it's only a stereo card. I think I'll stick with the eCLARO for now as the one as I do more research.
Skyrim fans!!
Dunan is offline
post #19 of 19 (permalink) Old 02-18-2019, 10:46 AM - Thread Starter
Dunan's Avatar
I went ahead and got the eCLARO, it seemed to be the best choice for the 4.1 promedia. It probably won't be as good as the prelude but I don't need it to be. Thanks everyone for your help!
Skyrim fans!!
Dunan is offline
