Small 2.0 speaker setup for computer - Page 4 - Overclock.net - An Overclocking Community
post #31 of 43 (permalink) Old 08-16-2019, 06:13 PM - Thread Starter
To The Game
Chargeit's Avatar
Rep: 290 (Unique: 197)
Well, that will do it. Was able to move my ups and place the speakers on their sides behind the monitor. Still sound good. Have since placed the ups at a more secure angle.
Chargeit is offline
post #32 of 43 (permalink) Old 08-16-2019, 06:16 PM
I can count to potato
Fluxmaven's Avatar
Rep: 17 (Unique: 9)
Quote: Originally Posted by Chargeit View Post
The stands kill desktop space no doubt.
The two side monitors are the same 21.5" 1080p monitors. They lack mounting locations on the rear. I had to rig up the one in portrait to be mountable by adapting the stands connection with an L bracket (found instructions on youtube). Luckily I did buy a second in case I ever decided to do them both that way.
The height of the center monitor is correct. The top of a monitor should be at eye level for proper comfort. Distance wise it's at arms length from my sitting position. I do think I could get away with rising it up enough to put speakers under it if it came to that though.
Yeah I'm down for suggestions for monitor mounts that can take a 34" uw. I'm not 100% sure I want to deal with mounting my monitors right now, but, it's something I look into from time to time.
It's annoying that not all computer monitors have VESA mounting. Every user I support at work gets a dual monitor mount with matching monitors. I usually just reorder the same ones, but they eventually get discontinued and I have to find something else.
As for monitor height, I'm fairly tall so most people's setups look a little low to me.
I don't have any firsthand experience with mounting a big UW since all my stuff is either 16:9 or 16:10. The mount I linked in my last comment looks like it should work, but I am not sure without double checking the measurements of all your monitors. Someone in the reviews section has a 34" ROG Swift with dual 21.5s but they are both in portrait. IDK if it has enough adjustment to push that left side out far enough to keep that monitor in landscape orientation.
Fluxmaven is offline
post #33 of 43 (permalink) Old 08-16-2019, 06:17 PM
Martin778's Avatar
Rep: 15 (Unique: 15)
JBL LSR305P MK2's are extremely hard to beat for the price. Truly a different league than any Logitech / Creative or similar computer speaker setup.
Core i9 9900K @ 5.2 || EVGA Z390 DARK || 2x8GB G.Skill TridentZ RGB 4600 C18 @ 4266 C17 || GPU: EVGA Kingpin RTX2080Ti @ 2130MHz || Samsung 970PRO 1TB + 860EVO 2TB || Lian Li O11 Dynamic White || Corsair AX1600i || Screen: LG B8 OLED 55 and LG 34GK950F
Corsair H150i PRO + Noctua NF-A12x25
Martin778 is offline
post #34 of 43 (permalink) Old 08-16-2019, 06:28 PM
Fluxmaven's Avatar
Rep: 17 (Unique: 9)
Unfortunately those would physically be too large for OP's setup unless they decide they are OK with speaker stands/wall mounting them. I agree that they are a nice sounding option though. I am listening to my JBL 306p MKII's right now
post #35 of 43 (permalink) Old 08-16-2019, 06:30 PM
Martin778's Avatar
Yep, I've seen he went with BOSE. As much as people bash on BOSE's home cinema speakers and their older particle-board shoeboxes like the 301's, their computer speakers and headphones are decent, especially for their size.
Moms got herself a Soundlink Revolve BT speaker and you would not believe how much punch it has, albeit the mids are still hollow and tinny.
post #36 of 43 (permalink) Old 08-16-2019, 06:33 PM - Thread Starter
To The Game
Chargeit's Avatar
Yeah sucks these can't be mounted out the box. They're pretty nice monitors. Were fairly cheap, 1080p, 21.5" ips glossy.
Last time I looked into mounting my current displays the conclusion was the best way to do it would be to mount each on its own arm.
_______________________________________________
I'm going to have to look into the weight distribution. I can tell I shifted that ups's weight. Feels like the desk has picked up a little movement when typing. Before it was stable since I mounted it to the wall to cope with everything I have on it (used to have 2 large speakers mounted to the rear edges). Basically I think the main weight of the ups is beyond the legs of the desk making it very back heavy. The ups weighs 25 lbs.
*Might have to make a shelf for the ups or something.
Chargeit is offline
post #37 of 43 (permalink) Old 08-16-2019, 06:41 PM - Thread Starter
To The Game
Chargeit's Avatar
Yeah at first I wasn't too impressed but switching from youtube to amazon music made a huge difference in their sound quality. They're sounding pretty good with what I listen to which is mainly 90's alternative.
Chargeit is offline
post #38 of 43 (permalink) Old 08-16-2019, 06:42 PM
Rep: 455 (Unique: 387)
Some big comfortable headphones would fit in there nicely, and can sound better than little desktop speakers
Darren9 is offline
post #39 of 43 (permalink) Old 08-16-2019, 06:59 PM - Thread Starter
To The Game
Chargeit's Avatar
I can't do them. Usually I can't stand any headphone that covers my ears. For co-op gaming I picked up a wireless pair of sony ps4 gold headset which I've been happy with. Most earphones I've tried that covered my ears made me too hot and claustrophobic.
Chargeit is offline
post #40 of 43 (permalink) Old 08-17-2019, 04:25 PM
D-EJ915's Avatar
Rep: 3 (Unique: 3)
For your speaker positioning you could try putting some stands behind the monitors for them (could stack books / boxes for testing) and angle them at your ears (usually want tweeter pointing at ear level for best sound). You don't have a ton of space but if you moved that UPS you could probably fit something there. Anyway just an idea to try out.
Kanna
Dark X299
(7 items)
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i9-9900X
EVGA X299 Dark
EVGA Geforce GTX 1080 Ti
G.Skill 4x8GB C14 3200MHz
Samsung Pro 840 250 GB
EVGA Supernova G3 1300
Phanteks PH-TC14PE
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
