New speakers for my main PC - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 08-26-2019, 03:02 AM - Thread Starter
Phantomas 007's Avatar
Rep: 4 (Unique: 3)
On my main system I have a 2.0 set CREATIVE GIGAWORKS T40 SERIES II.I'm thinking to go ahead and replace this set with something better. I'm between the soundbar Creative Sound BlasterX Katana and the Creative T4 2.1 speakers. What do you think it's better choice ? Until now never have a soundbar and i'm close to get the Katana.
Thanks you
NZXT S340 White / Intel i7 4770k / Corsair Hydro H60 / Asus Maximus VI Hero C2 / Kingston Hyper X Beast 4*4GB 2400MHz / Sapphire Radeon HD 7950 3GB Vapor-X / Samsung 830 256 GB / Storage 3TB /
Phantomas 007 is offline
post #2 of 12 (permalink) Old 08-26-2019, 03:20 AM
Leopardi's Avatar
Rep: 17 (Unique: 17)
Neither, the T4 is clearly inferior to T40 Series II with the tinny satellites. The bass isn't that great either with only 6.5" subwoofer. Wouldn't recommend USB soundbars either.
Edifier S350DB would be an upgrade. Logitech and Creative are not offering options if you want to go from low end systems to something mid tier or better.
Leopardi is online now
post #3 of 12 (permalink) Old 08-26-2019, 03:41 AM
Graphics Junkie
UltraMega's Avatar
Rep: 29 (Unique: 25)
Well you won't really hear the left an right channels separately with a sound bar, but otherwise they are fine for the price.
The reason we have sound bars now is because TVs got smaller and thinner and generally have pretty crappy speakers as a result, so sound bars became a popular way to upgrade your TV speakers without much effort. If you're not trying to keep things as simple as possible, you will probably get more bang for the buck with more traditional speakers vs a sound bar. That said, most sound bars use optical cables and there can be some benifit to that depending on your setup. If you are running HDMI to your TV and then have the audio going from your TV to your speakers, you will be 100% digital which completely eliminates any need for a sound card of any kind.
There are a lot of ways to setup speakers with a TV and even more with a computer and it's hard to say what's best without knowing your budget, your setup, and how much you care about sounds quality vs simplicity.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #4 of 12 (permalink) Old 08-26-2019, 11:04 AM - Thread Starter
Rep: 4 (Unique: 3)
Thanks you but as I said it's for my main PC and about 80% games, 20% music. I don't see movies on PC.On my TV i have a home cinema with Yamaha 7.1 receiver and Jamo 5.1 Speakers.
post #5 of 12 (permalink) Old 08-26-2019, 11:17 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1071 (Unique: 629)
get an amp and a pair of bookshelf speakers. will sound better than any soundbar (and if you plan on doing "80% gaming" I wouldn't even consider a soundbar) or powered 2.0 set and it'll give you the ability to upgrade/add a sub later if you want.
even something like a ~$30 Lepai LP-2020A+ and a pair of ~$60 Micca MB42X will sound better than a comparable pair of powered speakers.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #6 of 12 (permalink) Old 08-26-2019, 12:08 PM
Custy
Rep: 12 (Unique: 8)
Rocklin is offline
post #7 of 12 (permalink) Old 08-26-2019, 03:10 PM - Thread Starter
Rep: 4 (Unique: 3)
The EDIFIER S530 it's worst or just older of 350 ?
Also,any comment about Razer Leviathan ?
post #8 of 12 (permalink) Old 08-26-2019, 04:52 PM
robert c james's Avatar
Rep: 2 (Unique: 2)
On the Cheap https://www.parts-express.com/dayton...undle--300-650
Better speakers without amp https://www.parts-express.com/restoc...am--88-300-651
These have great reviews although you will want a sub https://www.parts-express.com/dayton...pair--300-4560 ( review from audioholics https://www.audioholics.com/bookshel...d-mk442-review )
Cheap 2.1 amp with enough power for a desktop system https://www.parts-express.com/restoc...ut--88-310-308
robert c james is offline
post #9 of 12 (permalink) Old 08-26-2019, 05:07 PM
maestro0428's Avatar
Rep: 8 (Unique: 8)
Powered monitors are nice as the amp is built in. They are also usually designed for near field listening. I have a pair of Presonus e4.5s connected to a Schiit Audio Modi 3 D/A converter (this bypasses the PCs built in sound chip and removed the noise associated with it). Love my set up and don't plan to upgrade any time soon. For the money, its the best Ive heard.
Join [email protected] and save lives!
maestro0428 is offline
post #10 of 12 (permalink) Old 08-27-2019, 04:03 AM - Thread Starter
Rep: 4 (Unique: 3)
I'm not a expert with the audio system but I cant's understand why you said katana it's not a nice choice. Before I create here the thread I had see plenty of videos on youtube and read many reviews. The product has very good critics and also it's a product that has awards. So I cant understand solutions with cheap (Chinese) amp and speakers in price $60-70 will offer better sound than the Creative katana. The only alternative choice for me it's the Edifier but because of the size of this speakers it's a reason also in the past I had withdraw from my choices and got the T40 II.
