Vega 56 coil whine through JBL LSR 305? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 10-21-2019, 04:59 PM - Thread Starter
Synoxia's Avatar
Rep: 7 (Unique: 5)
My computer specs are below, i power those monitors through a douk 1796 DAC. Anyone can figure out why this coil whine only happens when there's a GPU load and why it's audible through monitors?
How can i fix this?
Thank you.
(i am still uploading the video)
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
G-Skill Tridentz OC 16 gb 3800 c14-16-17-16-32-48
EVGA G3 Gold
Noctua D15
Phanteks Enthoo pro TG
Operating System
Win 10 1903 build 18950 64bit
Viewsonic XG2401
Keyboard
Fnatic RGB Cherry mx brown
Mouse
Logitech G Pro Wireless 950 dpi
Mousepad
Artisan ZERO Fx
Audio
JBL305
Synoxia is online now
post #2 of 11 (permalink) Old 10-22-2019, 07:43 AM
Tiihokatti's Avatar
Rep: 260 (Unique: 210)
Groundloop. Almost every imaginable issue with studio monitors in PC environment is caused by it, grounded speakers are simply not designed to be used with a grounded PC.
Try out the external PSU-mode that the DAC has, it could help with the issue. If it doesn't help then GLI (ground loop isolator) or a new optical DAC is the only way forward. There's also the ghetto-mod where you use electrical tape to tape out the grounding prongs, but I would recommend using it only for troubleshooting purposes.
Ppl should learn to add more info to their posts when they ask for help...
OCN Anime/Manga Club
[Official] OCN Headphones and Earphones Club
Tiihokatti is offline
post #3 of 11 (permalink) Old 10-22-2019, 12:50 PM - Thread Starter
Synoxia's Avatar
Rep: 7 (Unique: 5)
https://www.amazon.it/Isolator-isola...4&sr=8-2-fkmr0 Would this suffice? Using it between fostex and the DAC.
Douk1796 doesn't seem to have an external psu mode. Wouldn't it increase audio lag since too many connections before audio source?
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
EVGA G3 Gold
Noctua D15
Operating System
Viewsonic XG2401
Keyboard
Mouse
Mousepad
Artisan ZERO Fx
Audio
JBL305
post #4 of 11 (permalink) Old 10-22-2019, 01:05 PM
amorello's Avatar
Rep: 3 (Unique: 2)
I can't view the video, but did have audible hissing sound. It annoyed me so much for so long, was trying to sell speakers.
Then tried these and they work perfectly!
3-Prong to 2-Prong Adapter Grounding Converter
Either buy those adapter, or take pliers and pull out the 3rd ground prong, or change the cable if you have extra laying around that are 2 prongs.
The adapter fixed the problem personally
amorello is offline
post #5 of 11 (permalink) Old 10-22-2019, 01:59 PM
Tiihokatti's Avatar
Analog audio signal in an audio cable travels at the speed of light. No, there won't be any latency as long as we are talking about analog signal.
The only downside would be the possible degradation of the audio signal if the GLI is low quality.
post #6 of 11 (permalink) Old 10-22-2019, 02:44 PM - Thread Starter
Synoxia's Avatar
Rep: 7 (Unique: 5)
A quality GLI you can recommend?
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
EVGA G3 Gold
Noctua D15
Operating System
Viewsonic XG2401
Keyboard
Mouse
Mousepad
Artisan ZERO Fx
Audio
JBL305
post #7 of 11 (permalink) Old 10-22-2019, 03:07 PM
I can count to potato
Fluxmaven's Avatar
Rep: 25 (Unique: 10)
I had ground loop issues with my JBL 306P MkII's. I didn't like the idea of removing the ground pin so I picked up a cheap Behringer hum destroyer. Was originally just going to use it to test that such a device would fix the issue, and then upgrade to a higher quality unit. Ended up just keeping the Behringer. It has been working great for about 9 months now.
https://www.amazon.com/Behringer-HD4.../dp/B000KUD2G4
Darling
(19 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
TridentZ B-die 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
Basic Geil 2133 4x2GB
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig C7
Maingear Shift
Fluxmaven is offline
post #8 of 11 (permalink) Old 10-25-2019, 05:56 PM - Thread Starter
Synoxia's Avatar
Rep: 7 (Unique: 5)
Reviews say it's gonna distort lower frequencies
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
EVGA G3 Gold
Noctua D15
Operating System
Viewsonic XG2401
Keyboard
Mouse
Mousepad
Artisan ZERO Fx
Audio
JBL305
post #9 of 11 (permalink) Old 10-25-2019, 09:34 PM - Thread Starter
Synoxia's Avatar
Rep: 7 (Unique: 5)
I've done some testing and found out that if i connect my headphones to the DAC i do not get ANY noise, but with the JBL (to the same DAC) i am.
Does this mean i have bad cables o that i have to rma both JBLs?
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
EVGA G3 Gold
Noctua D15
Operating System
Viewsonic XG2401
Keyboard
Mouse
Mousepad
Artisan ZERO Fx
Audio
JBL305
post #10 of 11 (permalink) Old 10-26-2019, 01:04 AM
Fluxmaven's Avatar
I gave it a chance despite the mixed reviews. I don't have any issues with distortion. I run balanced TRS cables between everything and am running off a Focusrite Scarlett 2i4.
The headphones don't have the issue, because they aren't plugged into a separate power outlet... The ground loop issue occurs when two or more devices are connected to a common ground through different paths.
You can confirm that it is a ground loop hum by removing the ground from the monitors. Cheapest way like mentioned above is just pull the ground out with pliers. Or get some adapters. Can probably find them even cheaper at your local hardware store.
https://www.amazon.com/GE-Polarized-.../dp/B00B7PK1TC
Darling
(19 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
GTX 1080 FE
WD Black SN750
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Keyboard
Mouse
Glorious Model O
Mousepad
Audio
Audio
Focusrite 2i4 Gen2
Audio
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
WD Blue 3D m.2
Corsair AX760
InWin D-Frame Mini
i7 6700
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig C7
Maingear Shift
