What tweeters are some good tweeters? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 20 (permalink) Old 02-18-2020, 09:33 PM
Tjj226 Angel's Avatar
Rep: 506 (Unique: 335)
Everyone else is right, but I would also go one step further and say that replacing your tweeter is probably a waste of time and money.
Tweeters don't magically blow for no reason (despite what a lot of people think). There could be a larger problem that caused the tweeter to blow and the replacement tweeter might not last.
There are so many better speakers you can buy for cheap, that you would be better off just upgrading your speakers.
Tjj226 Angel is offline
post #12 of 20 (permalink) Old 02-20-2020, 05:21 AM - Thread Starter
Epicnoob's Avatar
Rep: 1 (Unique: 1)
i have tried to mail edifier and no answer for more than 2 days now.. i dont know what to do , i really love how these speakers sound and they were not cheap for me. i cant find any replacement tweeters online i dont know what to do
LE: also i have no ideea what specs should i search for online as replacement tweeters. For example if i dont find the exact Wattage tweeters will i put in danger my soundcard from my pc or anything like that that would burn stuff from my pc ? Or i can actually have a replacement of tweeters that are alike these not the same but alike and be all good? i dont seek to have the exact sound.. i just want to have tweeters again
Epicnoob is offline
post #13 of 20 (permalink) Old 02-20-2020, 06:17 AM
TriWheel's Avatar
Rep: 15 (Unique: 15)
I just wanted to ask, if the OP was to replace his speakers entirely, what happens to the old ones?
It's a rhetorical question, but I am trying to highlight the uncounted costs of consumerism.
I realize that probably most of you don't give a second thought about where your trash goes and the long term effects of our garbage mountains, but for somebody like me, it is a primary consideration when it comes to repair or replace.
Sometimes the easy way isn't the best way in the long term.
OP: I would take this question to a hifi forum, surely the expertise and knowledge there would surpass what is available on this forum.
Be honest, behind the facade of those things, the real priority is just screwing everyone over in the name of obscene profit & delaying any kind of backlash as long as possible. That's the real world.
Phenom II X6 1090T
Gigabyte MA790FXT-UD5P
XFX R9 290+AC Kryographics+Aktiv XCS
G.Skill Flare 16000 7-9-7
Gifted Samsung 850 Evo
Optical Drive
Pioneer 18X DVD-R
Seasonic S12+ 850W
Lian Li A77B
Operating System
Server 2012 R2
Yamakasi Catleap 2B
Mouse
Razer Lachesis
Audio
Auzen Prelude
TriWheel is offline
post #14 of 20 (permalink) Old 02-20-2020, 04:17 PM
Here is my rhetorical answer. Turn it into a bird house. Honestly, if you take out the drivers, speakers do actually make decent bird houses. I have gutted a few larger speakers for my cats to play in. At the end of the day, speakers are just wooden boxes, so finding a use for dead speakers isn't particularly hard.
And I am actually on the other hifi forums. I make my own speakers, design my own amplifiers, and the whole 9 yards. And no, the hifi forums wouldn't say anything different because the problem is the same.
We know almost nothing about the tweeter in question. We know its a 13mm (1/2 inch) silk dome tweeter rated at 4 ohms according to the speaker data sheet. We don't know the tweeters sensitivity. We don't know the frequency response. AND we would have to find a tweeter with a similar wave guide and mounting holes so that the OP could slap it back in the speaker without any issue.
You just can't slap any old tweeter in this thing and have it work.
The only thing I can think of is that maybe someone might have a similar speaker up on ebay that you can use for parts. You can also check the tweeter to see if there are any part numbers on it.
post #15 of 20 (permalink) Old 02-22-2020, 02:58 PM
D-EJ915's Avatar
Rep: 13 (Unique: 12)
In addition to what angel said above you should replace both tweeters at the same time if you do get a model that is different from the stock one as they will sound pretty different otherwise.
Kanna
Dark X299
(7 items)
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i9-9900X
EVGA X299 Dark
EVGA Geforce GTX 1080 Ti
G.Skill 4x8GB C14 3200MHz
Samsung Pro 840 250 GB
EVGA Supernova G3 1300
Phanteks PH-TC14PE
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #16 of 20 (permalink) Old 02-22-2020, 03:07 PM
Meep
Gilles3000's Avatar
Rep: 327 (Unique: 234)
If you still want to give it a shot anyway, dayton audio has some very affordable options:
https://www.parts-express.com/dayton...4-ohm--275-104
Worst case you're out $18 for both speakers, worth the shot if you like tinkering.
Gilles3000 is offline
post #17 of 20 (permalink) Old 02-24-2020, 01:03 AM
They won't mount to his speakers correctly, I already looked into those tweeters along with the other 4 ohm tweeters on partsexpress.
Thats part of the problem. If his tweeters were just a simple tweeter, then at least we could find a random cheap tweeter he could try. However his tweeters have a waveguide with a 4 screw mount. To make matters worse, I can only imagine that the hole for the tweeter is probably larger than usual, so a regular tweeter might not even have a chance to mount correctly even if you are willing to drill new holes.
I am passively searching on aliexpress and some other chinese supplier sites to see if maybe there is a driver that looks similar to the stock tweeter. I can't even find anything remotely similar so far.
post #18 of 20 (permalink) Old 02-24-2020, 02:45 AM
Meep
Gilles3000's Avatar
Yeah, it'll need modification to get it to fit properly for sure. Pretty much why I ended it with "if you like tinkering", as that's the only reason to even attempt to "fix" them.
I mean, the logical thing to do if you want a proper functional set is to sell them for "Parts or repair" and get a new pair, as I've seen the drop below €70 quite regularly.
post #19 of 20 (permalink) Old 02-24-2020, 05:01 PM
ah, I was thinking more along the lines of tinkering with the crossover which will almost certainly be necessary.
post #20 of 20 (permalink) Old 03-04-2020, 12:06 PM
Taking it Easy
aaronman's Avatar
Rep: 308 (Unique: 251)
I know I'm late to the party but if you really have nothing to lose why not just spend a few bucks and see what it sounds like? I dunno about everybody else but I have a local electronics parts store here that has all different kinds of random off brand drivers for 5 bucks all the way to 200 bucks. I've built entire speakers that sounded pretty good (A/B tested against some 200 dollar polk speakers and my friends thought mine sounded better) with like 30 dollars worth of woofers and tweeters. Don't think that you have to get the EXACT tweeter model to still make them sound close enough. He's definitely not trying to monitor reference material with his Edifier system.
I miss $250 GPUs that could still play everything.
The Studio
(14 items)
Plex Media Server
(11 items)
Core i5 6500
Asus ROG Maximus VIII Ranger
Sapphire Radeon R9 290
2x 8GB GSkill Ripjaws DDR4-3000
1TB SATA SSD
XFX 750W BE
CM Hyper 212 EVO
Azza Solano
Dual HP 20" 1680x1050
Keyboard
Velocifire Wireless Brown Mech Switches
Mouse
Logitech G400
Audio
Tascam US-1800
Audio
JBL LSR305
Audio
Sennheiser HD600
AMD FX-6300
ASUS M5A99FX PRO R2.0
Sapphire Radeon HD 5450
12GB GSkill DDR3-1600
Western Digital Red Pro 8TB
120GB SATA SSD
Corsair 850W
Thermaltake Big Typhoon
Antec
Operating System
Ubuntu 16.04 LTS
Audio
lol
aaronman is offline
