What would you suggest for a set of $500 Headphones? - Overclock.net - An Overclocking Community
post #1 of 55 (permalink) Old 05-29-2020, 09:41 PM - Thread Starter
Random Eventer
Skye12977's Avatar
Rep: 85 (Unique: 75)
I currently using a set of Audio Technica ATH-M40x's that I picked up from Amazon back in November of 2015. In April of 2019, I got the Bluetooth adapter for the headphones and they are now my dedicated Bluetooth headset.
For gaming, I'm using the HyperX Cloud Revolver S headset, which I'm not a big fan of sound-wise, but I wanted to pick myself up a dedicated headset.
The reason why I'm here is that I'm wanting to step up the audio quality of my wired headphones:
1. The ATH-M40x's were never loud enough on their own, I ended up buying a cheap headphone amplifier and it did the trick.
https://images-na.ssl-images-amazon....AC_SL1000_.jpg
2. The ATH-M40's are now my Bluetooth headphones.
3. The HyperX Cloud Revolver S headset audio quality just isn't cutting it.
Ideally, I'd like to get a set of headphones and then some type of clip-on mic, but that's not a priority.
*I'm wanting to spend around $500 on headphones or setup that doesn't include a mic.*
My audio is coming directly off my motherboard, which is an Asus Z370-A.
Does anyone have any suggestions or would you be able to help guide me towards what I'm looking for?
My HeatWare
Main Computer
(7 items)
i7-8700
Asus Prime Z370-A
Asus GTX 1080 Strix
Corsair Vengeance LPX 16GB DDR4 DRAM 3000MHz C15
Crucial MX300 525GB SSD
Corsair AX760
Scythe Fuma Rev. B (SCFM-1100)
Skye12977 is offline
post #2 of 55 (permalink) Old 05-29-2020, 10:05 PM
NewType88's Avatar
Rep: 5 (Unique: 3)
I'm about at the end of my audio journey.
I'd recommend either new or used HD6XX and a JDS Labs Atom. Should pay no more than $300.00 for that setup.
NewType88 is offline
post #3 of 55 (permalink) Old 05-30-2020, 12:05 AM
Still kinda lost
Awsan's Avatar
Rep: 122 (Unique: 92)
There are infinite possibilities when it come to audio, there are some stuff that are just plug and play and you will enjoy no matter what you like.
Fast and easy? HD6xx + Modi 3 (Maybe check the SMSL models too) + JDS atom then Add a modmic (USB is not bad but the 5 is the best version and is barely available anywhere)
If the cans are used mainly for gaming you can cut cost by skipping the modi and the atom by getting the Fulla 3 (Which will add a mic 3.5mm for your mic)
Me personally play a lot of FPS and love to listen to EDM, What I did was got an AD900x for gaming (Amazing sound stage and imaging) with a modmic 5 and a Beyerdynamic custom studio for music (All running through modi 3 and an atom)
So what I would recommend, the Modi 3 + Atom combo is $200 and is one of the best bang for your buck audio upgrades.
The modmic after personal usage (Used the 4 and the 5 and the Uni) are easy to use sound great and the modularity was key for me.
Headphones are the tricky part, you do you, check around read what peoples "opinions" are and make the purchase based on what you like.
Can recommend some options if you tell me what kind of music you listen to + If the gaming part is more about the single player experience (Immersion) or the multi player experience (Imaging and soundstage)
Godzilla HAF red
(18 items)
The Son Of Godzilla
(18 items)
Ryzen 3950x
MSI MEG UNIFY X570
EVGA RTX 2080 SUPER GAMING BLACK
G.Skill Trident NEO 32GB 3600mhz
Sabrent Rocket 4.0 1TB
WD blue 2tb SSD
Seasonic Prime Ultra Titanium 650w
Nh-D15 Chromax
CM H500
Operating System
Windows 10 pro
LG24GM77-b
Keyboard
Corsair K95 platinum
Mouse
Logitech G502 SE
Mousepad
Red Gear
Audio
AD900x
Audio
Beyerdynamic Custom Studio
Audio
Schiit Modi 3
Audio
JDS ATOM
Intel Core i7 Extreme 2920XM/Intel Core i7 2860QM
P180HMx
AMD Radeon HD 6990M
AMD Radeon HD 6990M
Samsung
Samsung
Samsung
Seagate 750GB 7200RPM
Optical Drive
Blu-Ray reader
300W+8 cells battery
Sager Cooling + CM SF-19 USB 3.0
SagerNP8180
Operating System
Windows 7 Ultimate X64
18.4 1920x1080 Glossy 16:9 Plastic covered
Keyboard
Gigabyte wirless
Mouse
Gigabyte wireless
Mouse
Table
Audio
ultrasone pro 550 + FiiO E7++ on board 5.1 sound system
Awsan is offline
post #4 of 55 (permalink) Old 05-30-2020, 02:40 AM
Retired Staff
Farih's Avatar
Rep: 109 (Unique: 90)
Beyerdynamic DT770 Pro 80ohm, Fun V-shaped sound with pretty good sound stage for a closed can, Nice bass.
Beyerdynamic DT990 250ohm, Fun V-shaped sound with good sound stage, also a nice impactful bass. (open back)
Beyerdynamic DT880 250ohm, More balanced sound, ok sound stage (semi open back)
Sennheiser HD600, great imaging, nice balance... little bass
Sennheiser HD650, great imaging, great balance, a little more "meaty" then the HD600
Grado SR80E, good imaging, good soundstage, good mids, good (maybe to crisp) highs, shallow bass... Great for Rock/Bleugrass/Country
Audioqeust Nighthawk (standard edition) Super fun sound, great imaging, good soundstage, good bass... overblown mid-bass though BUT once you EQ it become's just Amazing! (for its price) after EQ: Deepest bass that will rumble your head like no tomorrow with great balanced mids and highs, can go extremely loud with no distortion. (would absolutely pick these headphones if you don't mind to EQ them, if you don't want to EQ i would pass on them) (can give you the EQ settings to)
Have personal experience with all these headphone's, others i have experience with are sadly not in your price range
For Dac/amps something like been suggested before
1st PC >>> Ryzen 3700x @ PBO OC - 16GB 3800mhz CL16 - 5700XT @ 2150mhz
2nd PC >>> Intel I5-4790K @ 4,7ghz - 16GB 2133mhz - RX570
3rd PC >>> FX-6300 @ 4,5ghz - 8GB 1866mhz - GTX960
4th PC >>> Dual Core E5700 - 2GB 800mhz - HD6670
Main PC
(25 items)
AMD Ryzen 3700X
Asus Gaming TUF X570
Sapphire RX5700 XT Nitro+ Special Edition @ 2150mhz
G.skill Ripjaws 16GB 3800mhz 16-16-16-36
Samsung 256GB NVME
Samsung 860 EVO 500GB
Seagate 3TB 7200rpm
Seagate 3TB 7200rpm
Corsair RMI 1000W
Scythe Fuma Triple Fan
Lamptron Fan Controller
5x Corsair AF120
Corsair AIR540
Iiyama 1440p
Keyboard
Logitech G413 Silver
Mouse
Logitech G403 Wired
Mouse
Razer Naga Trinity
Mousepad
A big one
Audio
Oppo Sonica DAC (modified)
Audio
Lehmann Linear headphone amp
Audio
AKG K812
Audio
Sennheiser HD650
Audio
Audio
Beyerdynamic DT770
Audio
Focal Elear
I5-4790K @ 4,7ghz
Asus Z97 Pro Gaming
Sapphire RX570
16GB G.E.I.L Black Dragon 2400mhz
Samsung 860 EVO 256GB
Seasonic 500W
Scythe Fuma 2
Farih is offline
post #5 of 55 (permalink) Old 05-30-2020, 06:40 PM - Thread Starter
Random Eventer
Skye12977's Avatar
The music I listen to is all over the place, but having a better quality lower-end bass would probably be more of what I'm looking for. It could be EDM, Rap, 'viking' type music, classical, or even someone just play an instrument like the hurry-gurdy. It all depends on what I'm doing or even what game I'm playing.
Gaming can range from basic COD multiplayer or Arma 3 multiplayer where I'm the type to turn up the volume so I can hear people walking/moving around, to a racing game where I could be in the mood to listen in the in-game music or just turn the music off and listen to the game itself.
I believe I'm going more for the mid to low end for the music I listen to.
For open-back vs closed-back headphones, how much of a difference is there when it comes to others hearing the music I'm listening to or noise-canceling if someone was blaring music/video games/movies down a short hall in the living room?
-I've never used open-back headphones so I'm unfamiliar. My closed-back headphones aren't marketed as noise-canceling, but they do a well enough job at blocking noise that isn't coming from my computer.
My HeatWare
Main Computer
(7 items)
i7-8700
Asus Prime Z370-A
Asus GTX 1080 Strix
Corsair AX760
post #6 of 55 (permalink) Old 05-30-2020, 07:11 PM
sultanofswing's Avatar
Rep: 5 (Unique: 5)
Open back everyone will hear your music so they are not "public" friendly.
For "personal" space Open backs generally are better.
I'm using Sennheiser HD660s running off a Topping A50 Amp and so far I really like it.
Works great in gaming and the 660s have pretty good imaging so locating players in games based off sound is a non issue.
[email protected] GHz - 0 AVX @ 1.300v w/ Heatkiller Block + Delid | EVGA X299 Dark | Kingpin 2080ti with Bykski Block on water. | 3 XSPC 360's and 1 XSPC 480 | 32gb Corsair [email protected] | 1TB NVME/1TB Sata SSD | Seasonic Prime Platinum 1200 | Phanteks Enthoo Elite | Viewsonic XG-2703-GS | Windows 10-says pro but seems like an amateur
sultanofswing is offline
post #7 of 55 (permalink) Old 05-30-2020, 07:12 PM
r/wallstreetbets degen
elucid087's Avatar
Rep: 11 (Unique: 9)
The AKG Q701's are amazing if you want something with a large soundstage, and at that price point you're not going to find anything better. The HD600/660S are safe choices.
You're going to need an amp to drive all those listed (and possibly a dac if noise is present). The Objective2+ODAC is a great piece of kit for somebody on a tight budget. You can find one used for dirt cheap.
Enthoo Evolv TG :: Maximus X Hero :: i7-8700K :: H115i PRO RGB :: Trident Z RGB 32GB :: AORUS GTX 1080 Ti :: Samsung 960 EVO M.2 1TB :: Dell AW3418DW :: Sennheiser HD800S :: RME-ADI 2 FS
elucid087 is offline
post #8 of 55 (permalink) Old 05-30-2020, 08:19 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1434 (Unique: 726)
Fidelio X2! Or wait for the X3 to launch, they were rumored to launch "early 2020" and some reviewers got samples but so far they're MIA.
X2 (and X3) are semi-open though, I don't really have a closed headphone recommendation. I've got M50X and they are no where near what a $100 (ish) pair of headphones should sound like and even with aftermarket pads they're annoyingly uncomfortable.
motherboard will drive them (X2/X3) fine, they're both only 30 ohm. I run mine off my Schiit Hel and it's overkill, but I mostly just bought it to have a physical volume and mic input knob. It VASTLY improved my mic sound quality, headphones sound about the same as it did off my motherboard.
fairly entertaining review when they were $300, they're ~$150 nowadays:
Fidelio X2 even with the Schiit Hel should still leave you with ~$100 left in your pocket too, or you could go for something cheaper than the Hel (like the FiiO E10K) and save another $100. I ran a E10K before I got my Hel
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is offline
post #9 of 55 (permalink) Old 05-30-2020, 08:33 PM
Stock is too casual~
Veii's Avatar
Rep: 112 (Unique: 59)
+1 on the Fidelio X2HR
Although taste will vary, whatever headphone you pick
Check it's actual raw accuracy on
https://github.com/jaakkopasanen/Aut...master/results
Oratory's measurements are more accurate - and retune them
Unlike passive and active studio speakers, which follow a room frequency response and unified "correct" tuning
IEMs and Headphones doesn't
Soo i strongly suggest to retune your gear, be it just to make 10$ bucks sound better or fix even up to the Sennheiser HD6xx or AKG's set
Keep in mind, whatever headphone/iem you pick
To also factor in that the good ones ~ now including the HiFiMAN Sundara, will leak
Soo you might want to consider the Wireless Mic route with a set of lavalier + mini amp/dac
Wireless gear remains to be overpriced, and halfway useless
Because you need to not only include the cost for the wireless transmission license (100-150$ for AptX HD) or have luck with Sony LDAC support/MQA even
but then also add in the cost of a mini amp and mini dac
Mini everything, will result in mini signatur with mini price
~ keep that in mind on every wireless gear you buy, factor at least 200+ alone for the wireless part without the speakers included
To headphones/iems
low impedance ones usually are your better bet, but these are hard to drive and sensitive
Get a clean usb dac - and no, pcie ones are not a good one ~ often even on board ones are better while still noisy
With very sensitive gear you can even hear usb soundcards noise, not to speak about on board ones
Sundara's are great tbh, but they need a good build around them
And they need dacs from XYZ company, which can impedance match
High current output is often a waste, neverless what dac company you decide to go for ~ their amp has to be clean and has to impedance match
The jump is most of the times 120-150$ when you compare sound quality on it's own
Fidelios are for 150ish $ right now, Sundara starts at 350
There are way to many options to list them, it depends on what you listen to and you need to focus on your chains
Because even a well painted poopi signal, remains a poopi signal at source ~ neverless how clear you reproduce and paint it
SiSandra Inter-Core Bandwith 14nm Ryzen global #1 | Twitter
Personal Records
RAM > Viper Steel @ 3466C14 (64.2ns) & Alt | Hynix-MFR 3333CL14 (72.5ns) & Alt
GPU > Gigabyte 970 G1 @ 1595|1900 (Hynix) | RX 580 Red Devil GS @ 1620|2200 (Micron)
CPU > TR 1950X [email protected]1.2v & [email protected]1.365v[105Mhz FSB](3.23Beta)
#Main: 1700X [email protected]1.365v1.73Ghz IMC CL14 (64.2ns)」+ Dark Rock 3 | X370 Taichi 1.0.0.3 ABBA by The Stilt | Viper Steel [PVS416G400C9K]| Gigabyte 970 G1 | Samsung 850 Evo
Veii is offline
post #10 of 55 (permalink) Old 05-30-2020, 09:30 PM - Thread Starter
Random Eventer
Skye12977's Avatar
https://www.youtube.com/watch?v=_y2ZZxcBZ88
Any input on the Schiit Fulla instead of the E10k?
To headphones/iems
The X2HR's seem pretty good and they would seem to hit all of my points based on the review here:
I'm a push to talk guy, so having the mic pick up the headphones isn't a big deal.
They would also put me well within the budget.
It also uses a genic 3.5m so an inline mic would also fit in easily.
My HeatWare
Main Computer
(7 items)
i7-8700
Asus Prime Z370-A
Asus GTX 1080 Strix
Corsair AX760
