GTX 750 Ti mining - Page 15 - Overclock.net - An Overclocking Community
GTX 750 Ti mining
post #141 of 1291 (permalink) Old 03-02-2014, 05:28 PM
gfgrimm's Avatar
Rep: 0
Originally Posted by UNOE View Post
In Windows you have to keep Chrome open for some reason while mining to get cards at 99% load.
I tried this (WIndows 8.1 x64)...and saw no difference whatsoever. I was able to get ~320kH/s with a single 750Ti loaded in a x16 slot no problem. Thanks for the tip, though.
gfgrimm is offline
post #142 of 1291 (permalink) Old 03-02-2014, 06:12 PM
HardwareDecoder's Avatar
Rep: 142 (Unique: 106)
Yeah if anyone knows how to edit the core / mem clock in bios so that I can use linux that would be amazing.,
HardwareDecoder is offline
post #143 of 1291 (permalink) Old 03-02-2014, 08:47 PM
Americonfusion's Avatar
Rep: 4 (Unique: 3)
Running 5 EVGA FTWs
H81 Pro BTC, G1830, 4gb ram, Windows 7, powered risers
--no-autotune -l T5x24 -H 2 -m 1 -i 0
Card overclock specs cpu clock/mem clock
GPU 1 +28/+528
GPU 0,3 76/660
GPU 2 60/660
GPU 4 90/690
No bios flashing or anything.
About 1555 khs across all 5, stable and running great, highest temp is 53c.
Sorry, no wattage figures yet, I ordered a killawatt and it will be here wednesday. May try Bios flashing and see if it helps at all but Im pretty pleased with where it is at now. I've ordered several different 750tis for comparison,
3x PNY GeForce GTX 750Ti OC VCGGTX750T2XPB-OC
2x ASUS GTX750TI-OC-2GD5
2x MSI 750 Ti 2GB GDDR5 OC, TWIN FROZR - N750TI TF 2GD5/OC
I want to see the best hash I can get out of the 750tis without the PCIe connector.
The one card that is hashing higher is the one that is plugged into the 2.0x16 slot. I've seen another guy test this and you do see a ~10-15 khs drop using x1 versus 2.0x16 or 3.0x16.
http://i.imgur.com/744vmFe.jpg
Americonfusion is offline
post #144 of 1291 (permalink) Old 03-02-2014, 08:51 PM
gfgrimm's Avatar
Rep: 0
Originally Posted by Americonfusion View Post
Running 5 EVGA FTWs
GPU 1 +28/+528
GPU 0,3 76/660
GPU 2 60/660
GPU 4 90/690
I would love to be getting that hash rate with five of my six cards... I think the only setting I haven't used that you're using is -m 1....
What is the point of --no autotune if you're also already providing the kernel config?
gfgrimm is offline
post #145 of 1291 (permalink) Old 03-02-2014, 08:54 PM
Rep: 4 (Unique: 3)
I don't know, its just kind of stayed there since I started working on my config. I just started mining and using cudaminer 2-3 days ago so Im still figuring out some things.
post #146 of 1291 (permalink) Old 03-02-2014, 08:56 PM
@americonfusion why are you running so many copies of cudaminer? just curious, can't one copy be run for all cards or no?
post #147 of 1291 (permalink) Old 03-02-2014, 09:13 PM
Rep: 4 (Unique: 3)
Yes you can run one copy but this way if a card crashes the others keep hashing uninterrupted or if I want to tune and tweak on one card I can keep running the other 4 while I do it. It's not any harder to run 5 instances over one, just a little copy and pasting of bats and its easier to see the specific output of each card at quick glance.
post #148 of 1291 (permalink) Old 03-02-2014, 09:18 PM
yeah it seems like cudaminer is way behind cgminer in terms of usability.
post #149 of 1291 (permalink) Old 03-02-2014, 09:35 PM
gfgrimm's Avatar
Rep: 0
Could you please share your GPU-Z tabs for one of these cards while it's running? I cannot get a card to go past 230kH/s when it's connectied via a x1 to x16 powered USB riser in Windows 8.1 x64
gfgrimm is offline
post #150 of 1291 (permalink) Old 03-02-2014, 09:36 PM
I don't have any yet biggrin.gif my first one comes tomorrow. The other 24 I ordered are coming some time this week.
