GTX 750 Ti mining - Page 16 - Overclock.net - An Overclocking Community
GTX 750 Ti mining
post #151 of 1291 (permalink) Old 03-02-2014, 09:37 PM
gfgrimm's Avatar
Rep: 0
Originally Posted by Americonfusion View Post
Yes you can run one copy but this way if a card crashes the others keep hashing uninterrupted or if I want to tune and tweak on one card I can keep running the other 4 while I do it. It's not any harder to run 5 instances over one, just a little copy and pasting of bats and its easier to see the specific output of each card at quick glance.
Could you please share your GPU-Z tabs for one of these cards while it's running? I cannot get a card to go past 230kH/s when it's connectied via a x1 to x16 powered USB riser in Windows 8.1 x64
gfgrimm is offline
post #152 of 1291 (permalink) Old 03-02-2014, 09:38 PM
gfgrimm's Avatar
Rep: 0
Originally Posted by HardwareDecoder View Post
I don't have any yet biggrin.gif my first one comes tomorrow. The other 24 I ordered are coming some time this week.
gfgrimm is offline
post #153 of 1291 (permalink) Old 03-02-2014, 09:56 PM
Americonfusion's Avatar
Rep: 4 (Unique: 3)
http://i.imgur.com/0VYCQuM.jpg
I just downloaded gpuz to do this, I now see that the TDP is limiting me and will be flashing the bios tomorrow probably.
Americonfusion is offline
post #154 of 1291 (permalink) Old 03-02-2014, 10:04 PM
gfgrimm's Avatar
Rep: 0
If you need help flashing the BIOS to lift the TDP limit, let me know.
So this performance is achieved with the cards running connected to a powered USB3 x1 to x16 riser cable? Could you also please share the first GPU-Z tab? I'm interested to know what the state of your PCIe bus.
I for the life of me, can't get anything above 240 KH/s with a x1 riser right now. Going nuts...
gfgrimm is offline
post #155 of 1291 (permalink) Old 03-02-2014, 10:15 PM
Rep: 4 (Unique: 3)
They are all on 1x-16x powered ribbon risers
post #156 of 1291 (permalink) Old 03-02-2014, 10:37 PM
Partol's Avatar
Rep: 34 (Unique: 29)
That screenshot shows power consumption at only 90.4% of TDP.
1397MHz at 1.168V is very nice.
I spent some time moding my bios and went from
1215-1228MHz at 1.062-1.068V
to
1268MHz at 1.062-1.068V
+250 memory
298-299 khash/s
I am focusing on efficiency and stability and not max OC.
Would love to know all your overclocks because it may help me to OC higher.
Partol is offline
post #157 of 1291 (permalink) Old 03-02-2014, 10:44 PM
Rep: 4 (Unique: 3)
to
+250 memory
298-299 khash/s
Didn't notice I got it at 90%, it was bouncing between 97-99 most of the time.
core/memory
1398/1695 ~322khs
1388/1644 ~312khs
1370/1659 ~309khs
1393/1680 ~314khs
1369/1614 ~307 khs
The first one is the one that is plugged into the 2.0x16 slot the rest are in x1 slots so you can really see the difference there.
post #158 of 1291 (permalink) Old 03-02-2014, 11:28 PM
gfgrimm's Avatar
Rep: 0
Thank you!
For lack of better ideas, I'm swapping out Windows 8.1 x64 for Windows 7 x64 to see if there is any difference. I know that at least 2-3 people with 5+ GTX 750 Ti's have achieved 300+KH/s per card concurrently on Windows. I haven't been able to figure out the differences between my setup and these other people yet. I know that using Ubuntu 12.04, I do see better performance/scaling when running the cards concurrently.
I just tried two different systems running Windows 8.1 x64 with a GTX 750 Ti plugged into a x1-x16 USB3 riser assembly. Both perform consistently bad.
gfgrimm is offline
post #159 of 1291 (permalink) Old 03-03-2014, 12:54 AM
UNOE's Avatar
Rep: 128 (Unique: 116)
yeah it seems like cudaminer is way behind cgminer in terms of usability.
Yeah no backup pools make it not worth doing a farm with. Can't use betarigs, api, or backup pools.
I have it at 310 on each card. I can do 325 to 340. But with random crashes a day apart. So it's just better to keep then under voted a little and do 310 from me.
I'm using 90% power target.
UNOE is offline
post #160 of 1291 (permalink) Old 03-03-2014, 02:30 AM
Freekers's Avatar
Rep: 8 (Unique: 5)
Thanks for the tips and pointers guys! With your help, I managed to optimize my system even further in terms of power usage: I removed the –H 1 flag, undervolted my CPU (-0.100V compared to stock) and played around in the BIOS and now my power usage is as follows:
Complete System Power Usage
Idle without 750TI installed: 30W
Idle with 750TI OC +135/+635: 34W
Load with 750TI OC +135/+635: 112W
I.e. the 750TI OCed uses 112-30 = 82W under load
For a 6 card setup that would be 6x82 + 30 = 522W, let's say 530W. That’s a difference of 590-530 = 60W compared to before. Nice!
I’m now getting 320 kh/s which is slightly lower than before but still not bad. I have to run Chrome as well, else I get around 300 kh/s.
I’ll be getting my risers this Wednesday if all goes well. Then I can update you with the real world numbers.
Thanks!
post-flame-small.gif Intel i7 920 d0 @ 4Ghz :: At stock volts, on air, with HT enabled post-flame-small.gif
:::: CPU-Z Validation proof.gif ::::: 500x LinX Stable proof.gif ::::
Freekers is offline
