GTX 750 Ti mining - Page 19 - Overclock.net - An Overclocking Community
GTX 750 Ti mining
post #181 of 1291 (permalink) Old 03-03-2014, 05:22 PM
Retired Staff
cam51037's Avatar
Rep: 162 (Unique: 105)
Well I just purchased another MSI 750 Ti today, hopefully I'll get around 315KH/s per card when everything is set up perfectly. Now I'm just waiting on the risers and I should be good to go. smile.gif
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/f/18042/distributed-computing-general"><span style="font-size: 12px;"><strong><em>CHECK OUT THE DISTRIBUTED COMPUTING SECTION FOR ALL THE INFO ON BITCOIN AS WELL AS OTHER CRYPTOCURRENCIES! </em></strong></span></a></div><span></span><p style="text-align:center;"><span> </span></p><span></span><p style="text-align:center;"><span style="font-size:12px;"><a href="https://pgp.mit.edu/pks/lookup?op=get&amp;search=0xEFFBC2817A4C2195" target="_blank">My PGP Key (KEY ID: 7A4C2195)</a></span></p></div></div>
cam51037 is offline
post #182 of 1291 (permalink) Old 03-03-2014, 05:22 PM
HardwareDecoder's Avatar
Rep: 142 (Unique: 106)
Originally Posted by AlphaC View Post
HardwareDecoder , the 6-pin is going to provide more stable power than a "made in china" PCI-e riser with some solder, hot glue, and maybe a capacitor wink.gif. The safe allowable wattage really depends on the wire gauge used by the riser. I'm pretty sure cam wasn't trying to be snarky.
As far as the AMD motherboards go it's iffy. Some people have reported issues with decreased hashrate compared to running them on the board , the cudaminer dev conjectured that it's because of added resistance of PCI-e risers to the Northbridge
Chrome with a flash game open forces the GPU to go into 3D mode
Nvidia has a bad habit of trying to save power (throttle) even when a 100% non-3D load is on it.
ccRicers , it's worth it if you can get the GTX 750 Ti for cheaper than $170 if your power is expensive.
Gigabyte GTX 750 Ti update
http://www.reddit.com/r/litecoinmining/comments/1zfx90/issues_optimising_gigabyte_gtx_750_ti_2gb_oc/
user then got 290+ kh/s using 32 bit cudaminer
reasoning: http://www.reddit.com/r/dogemining/comments/1zek7b/the_x86_version_of_cudaminer_always_give_me/cft3ta2
hey good info the 32bit ver gave me another 10 khash I'm at 305 now
HardwareDecoder is offline
post #183 of 1291 (permalink) Old 03-03-2014, 05:24 PM
ccRicers's Avatar
Rep: 72 (Unique: 66)
Originally Posted by ivanlabrie View Post
Agreed, it's my board of choice...either that or the asrock oc formula, if the z87x goes OOS.
Sounds cool. About to pull the trigger on the purchases- I found some of those OC boards going for $160, and my other cards are still on auction, but I can't wait! I will buy two graphics cards at first and then the other two with the next paycheck.
ccRicers is offline
post #184 of 1291 (permalink) Old 03-03-2014, 06:27 PM - Thread Starter
⤷ αC
AlphaC's Avatar
Rep: 900 (Unique: 590)
ZOTAC DUAL fan model (ZT-70602-10M) is available at SabrePC for $157.99, I'm not sure how good of a retailer they are
http://www.sabrepc.com/zotac-zt-70602-10m-geforce-gtx-750-ti-oc-2gb-graphic-card.html
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is online now
post #185 of 1291 (permalink) Old 03-03-2014, 06:54 PM
Americonfusion's Avatar
Rep: 4 (Unique: 3)
Those are like the worst of the overclocke cards, 1046mhz core clock? That is weak. I would save my money for something else.
Americonfusion is offline
post #186 of 1291 (permalink) Old 03-03-2014, 08:11 PM
ivanlabrie's Avatar
Location: Buenos Aires, Argentina. Land of the obscenely expensive hardware
Rep: 350 (Unique: 189)
I've seen some Zotac results and they were really good, stock clocks don't mean much.
ivanlabrie is offline
post #187 of 1291 (permalink) Old 03-03-2014, 08:13 PM
Rep: 4 (Unique: 3)
Most of the Zotacs Ive seen struggle to crack 300khs
post #188 of 1291 (permalink) Old 03-03-2014, 08:29 PM
ivanlabrie's Avatar
Yeah, they pull off some good scrypt jane and keccak numbers though...
https://bitcointalk.org/index.php?topic=167229.msg5441080;topicseen#msg5441080
I'd go with the msi oc one without 6 pin, more convenient psu wise...
post #189 of 1291 (permalink) Old 03-03-2014, 08:47 PM
Done
fleetfeather's Avatar
Rep: 260 (Unique: 203)
Can't remember what has been said about this card yet, but is the evga superclock 750 Ti worth buying? Can't find any info on a 6pin connection, or the components used
Project mATX #003 | JP Artisan Advent (Prototype)
(15 items)
5775C (4.2)
VII Impact
1080Ti Hybrid
Ballistix LP 2x8GB (2133 9-10-9-24 T1)
XP941 256GB
Ultra II 960GB
Prime 650w
D15
FD Nano S
Operating System
10
XB271HU
Keyboard
K-Type (Halo Clears, Cherry Stabs)
Mouse
G303
Mousepad
Artisan Hayate
Audio
Audioengine D1 + Beyer DT250/80 + Modmic 5
fleetfeather is offline
post #190 of 1291 (permalink) Old 03-03-2014, 08:51 PM
Rep: 4 (Unique: 3)
Yes it is, it has no 6 pin and will get 300+khs for you.
