GTX 750 Ti mining - Page 23 - Overclock.net - An Overclocking Community
GTX 750 Ti mining
post #221 of 1291 (permalink) Old 03-05-2014, 04:00 AM
sec0nd2n0ne's Avatar
Rep: 0
Hello guys... Newbie here, I'm planning to build mining rig. I just want some experts help here.
Is A88X-G45 a good mobo for mining?
Which GPU should I get?
ZOTAC GeForce GTX 750 Ti 2gb/128bit
OR
ZOTAC GeForce GTX 750 Ti OC 2gb/128bit
OR
MSI GTX 750Ti Twin Frozr OC Ed 2gb/128bit
sec0nd2n0ne is offline
post #222 of 1291 (permalink) Old 03-05-2014, 04:20 AM
dEBASERpIX's Avatar
Rep: 0
Hi
Just wanted to share my experience with an MSI N750TI TF 2GD5/OC.
I'm using CPU +135 / MEM + 635 with bios mod for power target limit and I am getting around 315-320khash/s
OS is W7 x64, cudaminer is latest x86 version with -m 2 -l T5x24 -i 0 -H 2 and chrome webbrowser is running.
If anyone is able to get higher hashrates please post your settings.
dEBASERpIX is offline
post #223 of 1291 (permalink) Old 03-05-2014, 04:58 AM
ivanlabrie's Avatar
Location: Buenos Aires, Argentina. Land of the obscenely expensive hardware
Rep: 350 (Unique: 189)
OR
OR
I'd go for the Msi one personally...the board choice, not so sure. You want good pci-e bandwidth, I'd pick a board with multiple 16x slots and run without risers or at least make sure risers don't have ridiculously long cables since that will slow you down.
Originally Posted by dEBASERpIX View Post
Hi
ivanlabrie is offline
post #224 of 1291 (permalink) Old 03-05-2014, 05:10 AM
Rep: 0
Thanks! But what other mobo would you recommend that could run 5 or 6 750ti?
post #225 of 1291 (permalink) Old 03-05-2014, 06:07 AM
ivanlabrie's Avatar
Easy, z77 gd65, z87 g45, z87x-oc (no risers, yay), z87 oc formula (same), z87 pro, z77x-ud3h, 990fx gd65 maybe.
post #226 of 1291 (permalink) Old 03-05-2014, 06:19 AM
The Z87 OC and OC Formula is a little overkill.
TheLAWNOOB is offline
post #227 of 1291 (permalink) Old 03-05-2014, 06:20 AM
GWAMM
Rep: 127 (Unique: 112)
You'd need water cooling and bracket modding to run 5-6 cards on any board without risers though.
I personally got the ASRock H81 Pro BTC. It's cheap and has all the slots needed as long as you're using risers, but price and availability depends on where you live, as usual.
GUIDE: Monitor/Display controls via Windows! Brightness, contrast, etc. (DDC/CI)
I play games. In addition to my PC, I own a cosy collection of consoles including GBC, PSX, GBASP, PS3, GCN, X360, NDSiXL, Xbox, PS2, Wii, Dreamcast, PSP and PS Vita.
HothBase is offline
post #228 of 1291 (permalink) Old 03-05-2014, 07:06 AM
ivanlabrie's Avatar
Again, risers...risers here cost 450 pesos each, and they make you lose hash rate with nvidia cards.
The z87x-oc is 4000 pesos, and the h81 pro btc costs 100 pesos less.
Price difference just isn't worth it when you factor in the cost of risers.
I know it's a particular case scenario but risers are a pain in the arse if you work with a gazillion rigs and these cards are perfectly capable of running stacked without over heating cause of the low tdp.
post #229 of 1291 (permalink) Old 03-05-2014, 07:51 AM
Americonfusion's Avatar
Rep: 4 (Unique: 3)
At stock, nah, try ocing the memory, your settings are fine.
You could try to return and exchange them maybe? I'm looking hard at the Msi gaming oc without 6 pin, it's really convenient that it has excellent memory chips and can run off whatever psu you got.
For my main rig though, I'm not sure what to pick since my pci-e slots don't have auxiliary molex/pci-e power for the slots. (x79-ud3)
I'm sure it can take the abuse, if it supports 4 gpus out of the box anyway, but not 100% sure.
You won't get much more out of that PNY card, I heard they don't do as well as the msi gaming oc or zotac cards. Those seem to be the two best so far. As well as the Galaxy gc and the Asus Dcu (technically, although the report I saw of the Asus one was a bit disappointing compared to the Zotac).
Its interesting that you say the MSI has superior memory because the one user here running MSI and Zotac found that the memory doesnt overclock well and it delivers subpar khs. Any card that cant give 300+khs stable isnt worth the time or money. I'll find out tonight I guess, I have 3xPNY OCs, 2 MSIs and 2 Asus cards coming in to do some comparisons with, already have 5 EVGA FTWs. Contemplating getting some of the other 2 EVGA cards to see if they can match my FTWs output.
Americonfusion is offline
post #230 of 1291 (permalink) Old 03-05-2014, 07:57 AM
GWAMM
Sure, but sec0nd2n0ne requested a board that could run 5-6 cards, which implies the use of risers. Like I said, price varies and I don't know the situation in the Philippines, but the H81 Pro BTC should cost about a third of the GA-Z87X-OC's price in most places.
HothBase is offline
