Wireless Disconnecting Constantly - Overclock.net - An Overclocking Community
post #1 of 25 (permalink) Old 10-12-2013, 02:57 PM - Thread Starter
Senior Moderators
pioneerisloud's Avatar
I just now got set back up with my rig. biggrin.gif Problem is, I'm living with roommates, and they have told me I'm not allowed to run a CAT5e wire. So I'm stuck with wireless.
I have 2 rigs (one mine, the other is theirs that I'm working on).
Both rigs are wireless. One has a generic PCI Wireless N adapter, the other has a TP-Link Wireless N PCI Adapter. I've also tried a Netgear Wireless N 300 adapter (USB). All wireless adapters show the same problem.
The router is a Netgear WNDR3400.
The problem:
Whenever I do any sort of download at all, even just Windows Update, the machine (either one) gets fully disconnected, from the router even. No internet and no network at all.
The only solution I've found is to disable the adapter and reenable it. When I do this, everything comes back and works as it should.
What can I do to resolve this issue? It's really annoying having the rigs disconnecting every 5-10 minutes.
EDIT:
They also randomly disconnect at various times throughout the day without doing any sort of downloading as well.
Intel Core i7 2600k @ 3.4GHz
MSI B75MA-E33
MSI RX550 4GB
8GB GSkill Sniper DDR3-1600 @ 667, 9-9-9-24
Intel 330 128GB SSD
Crucial MX100 256GB SSD
Toshiba 3TB HDD
Antec VP450
No fans except GPU and PSU
Dell Beige Box (mATX)
Operating System
Windows 10 Pro x64
Hanns G 23"
Keyboard
Redragon 10keyless
Mouse
Logitech USB Optical Mouse
Mousepad
Onn Mousepad
Audio
Diamond Edison 2.0
Intel Xeon E3-1245 @ 3.4GHz
Gigabyte Z68AP-D3
Nvidia GeForce GT310
4x8GB Corsair Dominator DDR3-1600
Sandisk Ultra 128GB SSD
320GB Seagate 7200.10
Toshiba 3TB x8 RAID6
Rosewill Green 630w
CoolerMaster Hyper 212+ Evo
NZXT Source 210
Operating System
Windows 10 Pro x64 / Hyper-V
Other
Adaptec 5805 SAS RAID Controller
pioneerisloud is offline
post #2 of 25 (permalink) Old 10-12-2013, 03:00 PM
bombastinator's Avatar
Rep: 186 (Unique: 139)
sounds like intrference. try a differernt wifi channel if you can or get closer to the base statiion
bombastinator is offline
post #3 of 25 (permalink) Old 10-12-2013, 03:01 PM - Thread Starter
Senior Moderators
Well the router was originally set to "Auto" channel. I have changed it to Channel 7. No difference yet anyway. Same issue. Not sure what channel was auto though.
MSI B75MA-E33
MSI RX550 4GB
Intel 330 128GB SSD
Toshiba 3TB HDD
Antec VP450
Operating System
Windows 10 Pro x64
Hanns G 23"
Keyboard
Redragon 10keyless
Mouse
Mousepad
Onn Mousepad
Audio
Diamond Edison 2.0
Gigabyte Z68AP-D3
Rosewill Green 630w
NZXT Source 210
Operating System
Other
post #4 of 25 (permalink) Old 10-12-2013, 03:04 PM
if you got a phne with wifi you could check around and see which frequencies are clear. wifi analyser is the android one. I had this same problem recently.
post #5 of 25 (permalink) Old 10-12-2013, 03:04 PM
deepor's Avatar
Rep: 470 (Unique: 317)
You can also experiment with the height of all devices involved. That worked for me once. Put the router somewhere on a top shelf instead of on the ground. See if you can get an antenna with a cable for the PCIe card and move that around.
deepor is online now
post #6 of 25 (permalink) Old 10-12-2013, 03:08 PM - Thread Starter
Senior Moderators
I'll give that a try and report back. What's funny is that my phone works flawlessly....even further away than the rigs are. My main rig gets 10Mb/s / 4Mb/s according to speedtest. This is with nothing going on. With my phone, I get 40 / 4. So something is definitely not right. The other rig gets closer to proper speeds of 25 / 4 (we're paying for 30 / 4).
EDIT:
It's reporting I have a -65dB signal. There's something on Channel 3 and Channel 11 already, both are around -90 to -80dB.
I've already moved the router about 2 feet closer (as far as I could), and I put it up on the highest shelf in that area (about 5 feet off the ground). Didn't help any. I can't move the computers....there's no room except on the floor.
MSI B75MA-E33
MSI RX550 4GB
Intel 330 128GB SSD
Toshiba 3TB HDD
Antec VP450
Operating System
Windows 10 Pro x64
Hanns G 23"
Keyboard
Redragon 10keyless
Mouse
Mousepad
Onn Mousepad
Audio
Diamond Edison 2.0
Gigabyte Z68AP-D3
Rosewill Green 630w
NZXT Source 210
Operating System
Other
post #7 of 25 (permalink) Old 10-12-2013, 03:26 PM
deepor's Avatar
On that PCI adapter on one of your computers, the antennas are screwed in and can be removed. There are alternative antennas and cables and stands and things like that.
Before you go and look into something like that, you could for now just do an experiment with your PC, move the whole PC around in the room, put it on a table, things like that, to see if you can get a good connection. If it's possible to get a good connection, you could then see what kind of antenna or cable etc. to buy.
post #8 of 25 (permalink) Old 10-12-2013, 03:28 PM
your phone has much more advanced systems in it. Most router auto systems start at either the top or bottom and go up or down till they find something they can get a signal through with. In a wifi conjested area it frequently means everyone winds up on one end or the other. Worse than useless.
post #9 of 25 (permalink) Old 10-12-2013, 03:28 PM - Thread Starter
Senior Moderators
The thing is, I seem to have decent enough signal strength (4/5 bars).
It turns out Channel 7 was the best channel. -60dB to -66dB.
Would a cement floor possibly be causing this issue, since the rigs are on the floor? My room used to be a garage, so under the carpet is just cement.
MSI B75MA-E33
MSI RX550 4GB
Intel 330 128GB SSD
Toshiba 3TB HDD
Antec VP450
Operating System
Windows 10 Pro x64
Hanns G 23"
Keyboard
Redragon 10keyless
Mouse
Mousepad
Onn Mousepad
Audio
Diamond Edison 2.0
Gigabyte Z68AP-D3
Rosewill Green 630w
NZXT Source 210
Operating System
Other
post #10 of 25 (permalink) Old 10-12-2013, 03:38 PM
I was thinking he could do that with the phone, but a laptop may be a bit more accurate. A signal booster on the machine and base station is another option. The FCC limits wifi signal output, but booster systems can often exceed FCC specs. If it's a desktop that doesn't move a directional antenna is also possible. making cantennas is a good excuse to eat pringles if you're not normally allowed to have them like me hannibalsmiley.png
