Can a motherboard cause network dropping? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 06-19-2019, 12:39 PM - Thread Starter
ADHDadditiv's Avatar
Location: Outside your bedroom window.... You gunna finish that milk?
Rep: 178 (Unique: 135)
Ok so I know this is more of a question about a motherboard rather than networking, but I feel like I'm going to get a better answer over here.
So I have been getting random ping drops for about a year now. What will happen is my computer will randomly lose connection for a second (or multiple), then sometimes come back with poor speeds. I am connected wirelessly (cannot hardwire), I'd mention my wireless card but I've tried 3 different cards and one usb stick so its not really relevant. Since I've had these issues (they're getting much much worse as of late), I've done 2 complete formats, changed from HDD to SSD to NVME, changed my overclock (lowered the voltage/clock for summer), changed GPU's and gone through 3 different cases. I'm thinking I either have a bunk motherboard from factory (the system is only 2 years old at this point) or maybe bad RAM? I dont think its the second one.
So basically what I'm wondering is, can my motherboard be screwing with my ability to receive internet signal?
If it matters, I have a ryzen 5 1600 and an X370 Asus Prime-plus board.
ADHDadditiv is offline
post #2 of 11 (permalink) Old 06-19-2019, 01:06 PM
Turtle Rig Fan
aDyerSituation's Avatar
Rep: 99 (Unique: 71)
Definitely. Reinstall your network drivers.
DyerLIVE
(15 items)
i7 7820x 4.7 ghz, 3.0ghz mesh
X299 ASUS ROG Strix-E
1080 Ti
32gb 3800mhz 16-17-16-37-1T trfc 400 (Model F4-3600C16Q-32GTZKK)
Samsung 860 EVO 1TB
Intel 730 240GB
Intel 530 240GB
EVGA 750w G2
DeepCool Castle EX 360mm
Fractal Meshify S2 White
Operating System
Windows 10 Pro
AOC G2460PF 24” 144hz
Keyboard
Logitech G610
Mouse
Logitech G203
Mousepad
Steel Series XXL
aDyerSituation is offline
post #3 of 11 (permalink) Old 06-19-2019, 01:13 PM
sudo apt install sl
Rep: 191 (Unique: 131)
Have you tried a PCIe network adapter? Curious if it's something to do with the USB controller. Did you also try both USB controllers? The ports from the chipset along with the Asmedia controller?
Silent
(20 items)
Core i9 9900K... CoffeeTime! @ 5.1Ghz w/ 1.36v
Maximus VIII Formula
Titan RTX @ 2100Mhz/2075Mhz
TeamGroup Xtreem 32GB 3200Mhz CL15
HP EX950 2TB
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
EK-Vector RTX RE Ti - Copper + Plexi
Thermaltake Core X5 Tempered Glass Edition
Operating System
Solus Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is offline
post #4 of 11 (permalink) Old 06-19-2019, 04:43 PM - Thread Starter
Done 2 fresh installs of windows with all new drivers. Also I do that on the regular, no change.
I have only had any real "success" with my PCIE network adapter, it was a bluetooth/wireless combo unit that came with a real old motherboard. Its the best one ive used so far. Have a cheap TP-link pcie card as well which was exactly the same but slower. Also tried a D-Link USB one. All have the exact same symptoms.
post #5 of 11 (permalink) Old 06-19-2019, 06:47 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 736 (Unique: 388)
I'd assume your nic is damaged, & try a PCI nic.
Add me on Steam, same name
skupples is offline
post #6 of 11 (permalink) Old 06-19-2019, 07:47 PM
Overclocker
JackCY's Avatar
Rep: 363 (Unique: 260)
You're trying to figure out wireless packet drops? While using mobo's integrated WiFi and even tried several other WiFi cards and USB sticks? It's probably your router or ISP then.
Why not get a wired connection to your router to test?
And why not get an AP that you connect to via cable and this AP then connects wireless to your far main router that has ISP/WAN connection. Why bother with wireless cards and USB sticks.
JackCY is offline
post #7 of 11 (permalink) Old 06-20-2019, 08:49 AM - Thread Starter
I actually thought about getting an AP, just keep forgetting to find one. Any suggestions on cheap ones?
I was also thinking about getting a new motherboard for ryzen 3xxx which is why I'm trying to figure out if it's a motherboard problem. Good excuse to replace it ahahaha
post #8 of 11 (permalink) Old 06-20-2019, 09:41 AM
Overclocker
JackCY's Avatar
I don't buy network devices almost at all and the cheap from ASUS are OK after a bit of research. If you need crazy WiFi speeds then it gets expensive fast and better devices are needed. And then how much traffic do you have because that quickly turns from home use to business use and price goes up exponentially.
You can have a cheap plastic router or get some expensive Cisco Meraki what ever they rebranded now along with having to pay them for the software running on it.
There are mesh solutions as well now.
Ubiquity, Netgear and many other brands.
Would likely avoid TPLink, Zyxel etc. the pure home use brands that barely get any decent device to market.
JackCY is offline
post #9 of 11 (permalink) Old 06-20-2019, 10:00 AM
Vermin Supreme 2020
skupples's Avatar
second take - run cable, if still persists, replace modem/router. NIC's tend to actually die, not just falter.
skupples is offline
post #10 of 11 (permalink) Old 06-20-2019, 10:42 AM - Thread Starter
Still can't run a cable. I'm not using the NIC at all if I'm running a PCI/USB wireless solution as well. Well at least I shouldn't be. My board shouldn't have any built-in wireless crap at all as it's not a wireless board.
I'm gunna try and get a cheap AP and run a cable to it to see if I still have issues. If I do, only things I have left to replace are motherboard and cpu ahahaha.
Tags
dropping , internet issue , internet problem , motherboard issue
