Powerline With Central Web Management - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 08-16-2019, 11:14 AM - Thread Starter
Linux Lobbyist
parityboy's Avatar
Rep: 272 (Unique: 213)
I have a set of Zyxel powerline adapters and I'm looking to replace them as part of a network-wide overhaul. However, what I would really like is a set of powerline adapters where I can manage the entire powerline network from a single console.
Do any powerline adapter manufacturers support this feature? What about other things like SNMP?
Additionally, I'm curious as to if there is third-party firmware for Powerline Adapters (the equivalent of Tomato or DD-WRT)?
Thanks.
Ryzen
(16 items)
Ryzen 7 1700
Gigabyte GA-AB350M Gaming 3
Sapphire Pulse Vega 56
Corsair Vengeance LPX CMK16GX4M2B3000C15
Corsair Vengeance LPX CMK16GX4M2B3000C15R
Samsung 970 Pro
Samsung 850 EVO
Samsung 850 EVO
Storage Array
Seasonic PRIME 1000 Ultra
AMD Wraith Spire
Fractal Design Arc Mini R2
Operating System
KDE Neon 18.04 LTS
Dell UltraSharp U2414H
Keyboard
Dell SK-8185
Mouse
Logitech Trackman Wheel
parityboy is offline
post #2 of 2 (permalink) Old 08-25-2019, 09:59 PM
Talon720's Avatar
Rep: 6 (Unique: 6)
Thanks.
I know the extollo communications has a web interface you can sign into and change some things and monitor speeds see whats connected and it had more than than the tp-link app which just showed the connection speed. I dont know though if adding the powerline wifi mesh adapter to what I have adds more options or not. Also, I'm currently using the extollo lanplug 2000 and it has the option to add the una adapter which is wifi or when using more than 1 creates a mesh network . I looked for a while to see if there was anything with custom firmware but there wasn't.
Case Labs s8 w/ped| 5820k | RVE10 | Gskill Trident z 3200cl14 | 3x 290x ref | Evga P2 1600w | custom loop; 3x d5 pumps w/ek revo dual + ek x-top csq tops| Heatkiller 150mm tube res | EK rve10 monoblock + 3x Ek gpu blocks | Radiators; 2 Ek XE 360mm, 1 BlackIce 360 gtx + 240mm gts, Alphacool 360mm st30 w/ vardar fans | Aquaero 6 XT
Talon720 is offline
Tags
ddwrt , powerline , snmp , tomato
