Restricting access on wifi/ethernet - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 10-14-2019, 08:30 PM - Thread Starter
Rep: 111 (Unique: 88)
Hey guys,
so I want to restrict wifi for someone in my apartment, as well as restrict them from connecting an ethernet cable to my router as well. They have access to my room so my question is, are there any wireless routers out there that don't have any lan ports to connect to besides from the modem to the router? Thank you.
nitrousflash is offline
post #2 of 10 (permalink) Old 10-14-2019, 09:21 PM
Rep: 37 (Unique: 36)
you could probably make something like a mac address whitelist and only put your nic on there.
i'm no it expert though
yo
nzgroller is offline
post #3 of 10 (permalink) Old 10-14-2019, 09:42 PM - Thread Starter
Thank you. Would creating a mac address whitelist also let me restrict internet access even if someone is using ethernet? That question is for anyone reading.
post #4 of 10 (permalink) Old 10-14-2019, 10:27 PM
771on775 user,Complainer
schuck6566's Avatar
Rep: 99 (Unique: 63)
MAC address filtering works on both wifi & wired.
schuck6566 is offline
post #5 of 10 (permalink) Old 10-14-2019, 10:40 PM - Thread Starter
SWEET! thank you! any tutorials on how to do this that you recommend? I'll also need a new router in the $100-150 range if you have a suggestion.
post #6 of 10 (permalink) Old 10-15-2019, 08:45 AM
schuck6566's Avatar
https://www.lifewire.com/enabling-ma...-router-816571
I regret buying my netgear nighthawk router if that's any help.(the r6700 v3) software on it sucks,& apps are the same. My old linksys had better options in the firmware in my opinion.(ability to place game consoles into DMZ's for example or prioritize them)
post #7 of 10 (permalink) Old 10-15-2019, 09:00 AM
Destrto's Avatar
Rep: 80 (Unique: 63)
Yea basically what they've said. Create a whitelist on your Modem. You could also, depending on your modem capabilities, disable the unused ethernet ports. But the whitelist would also take care of that because it would still have to verify the mac address whether the device is hardlined or wireless.
EK Club XCrossXFire ClubX
-OCN Water Cooling Club-
Destrto
AMD FX-8370
MSI 990FXA-Gaming
AMD PowerColor RX 580
G.Skill - Ripjaws X Series 16Gb
G.Skill - Ripjaws X Series 16 GB
Samsung 850 500Gb
Seagate 3 Tb
Raidmax Vampire 800 Watt
EK-Suprema​cy MX CPU ​Block
XSPC 240mm​ Radiator
EK-XRES 140 DDC 3.2 PWM Elite
HBT Gravity6
Destrto is offline
post #8 of 10 (permalink) Old 10-15-2019, 09:22 AM
DzillaXx's Avatar
Rep: 553 (Unique: 389)
You never want to put anything on a DMZ. That is nothing more than Lazy.
The Nighthawks for more about performance than features. They are a little bland on the software side, but they make up for it with stability and performance. If you want feature packed look at the Asus Wifi units, they have a bunch of un needed features for a home wifi unit.
The Features OP wants is best gotten from a enterprise level devices like the Unifi AP units. Honestly Unifi is the way to go, it is the only thing I use at home and for clients/work. You can pretty much do anything, and because I use VLANs they are a must as Home units simply lack those features. A Unifi AP and either a cheap Edge router or even a low power pfSense box would do you just fine. Or even just a cheap old wifi router with the wireless turned off. Just be warned that it may be a little much for a beginner, but a great learning tool.
DzillaXx is offline
post #9 of 10 (permalink) Old 10-15-2019, 09:47 AM
I can count to potato
Fluxmaven's Avatar
Rep: 25 (Unique: 10)
MAC whitelist is definitely a good option.
Haven't bought a new router in a while, so I don't have any specific recommendations. I'm also a fan of Unify, but it may be overkill for your needs. I have had good luck with running DD-WRT on Netgear routers though. This replaces their clunky featureless interface with one that offers pretty much anything a simple home network would ever need.
Darling
(19 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
TridentZ B-die 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
Basic Geil 2133 4x2GB
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig C7
Maingear Shift
Fluxmaven is offline
post #10 of 10 (permalink) Old 10-15-2019, 08:45 PM - Thread Starter
Thanks guys, so the consensus is a mac whitelist. Now I just need any router that's compatible with my modem. I miss these forums you guys are awesome. Repping everybody in here soon.
