Speeds cap at 60mb/sec on 1G connection - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 01-19-2020, 01:28 PM - Thread Starter
Kazumi's Avatar
Rep: 33 (Unique: 28)
Hello all,
So I'm really confused right now and could use some help.
So I recently moved and got into a 1G area, which I immediately jumped on. The problem is, my PC is capping out at 60mb/sec. My laptop hits proper speeds, wifi proper speeds, and the ISP tech's unit all showed good data rates.
Yet my PC with a 1000mb/sec rated board can't break 70. I even went out and bought an adapter for my PCI-E slot to try and figure this out.
I'm stumped. Please help.
Edit:
I have proper Cat6 cables
I have verified board specs
I have tested that the hardware from ISP supports.
Kazumi is offline
post #2 of 10 (permalink) Old 01-19-2020, 01:51 PM
Rep: 0
shotround is offline
post #3 of 10 (permalink) Old 01-19-2020, 03:01 PM - Thread Starter
Kazumi's Avatar
Followed and that bumped me into 80mbps.
Kazumi is offline
post #4 of 10 (permalink) Old 01-19-2020, 03:29 PM
Rep: 0
mb? MB? Mb? sometimes one has to ask.
when you say laptop, do you mean that it was wired using cable from the pc?
is isp router wired ports rated for 1gbps? check configuration of router. mine allows switch speed settings, 1g, 100M, 10M, and auto.
anything between router and pc?
don't rule out bad cable. it got me several times at work.
post #5 of 10 (permalink) Old 01-19-2020, 04:08 PM - Thread Starter
Kazumi's Avatar
Mbps your standard for modern internet. We ain't back in Dial up anymore.
Laptop wired yes
Router between PC. Check it's also within spec and ISP tech replaced with known "good" unit for double assurance.
I've used 5 different 1G rated ethernet cables, including mini's from ISP. All have same issue.
Kazumi is offline
post #6 of 10 (permalink) Old 01-19-2020, 06:21 PM
Rep: 0
I assume you took the cable from pc and put it on the laptop. did you turn off laptop wireless when you did the speed test?
how are you testing? speedtest.net? make sure the test point at the other end is the same.
that's about all I can do to help.
post #7 of 10 (permalink) Old 01-19-2020, 06:28 PM - Thread Starter
Kazumi's Avatar
Done all that.
I'm pretty confident this is a settings issue, not hardware. But I can't figure out what..lol
Kazumi is offline
post #8 of 10 (permalink) Old 01-19-2020, 06:43 PM
Skitz0h's Avatar
Rep: 2 (Unique: 2)
Do you have a gigabit nic on your mobo?
Redvidia
(16 items)
9900K 5.1ghz 1.248v 4600mhz cache HT OFF
Asrock Z390 Phantom Gaming X
Gigabyte Aorus 1080 ti Waterforce Extreme
Corsair Vengeance RGB Pro 32GB 3200mhz @ 3400mhz 16-19-19-28 1.398v
Samsung Evo 750GB
5TB
Seasonic 750w Prime Ultra Titanium
EKWB Extreme 360
Thermaltake Tower 900
Operating System
Windows 10 x64 1903 Build
Acer Predator 27" IPS 1440p G-Sync
ASUS 27" 144hz 1440p
Keyboard
Razer Ornata Chroma
Mouse
Logitech g502 Hero
Mousepad
Razer Firefly
Audio
Astro A40 Mix-amp TR
Skitz0h is offline
post #9 of 10 (permalink) Old 01-21-2020, 06:12 PM
DaaQ's Avatar
Rep: 125 (Unique: 92)
Quote: Originally Posted by Kazumi View Post
Done all that.
Sounds like it.
You could try deleting the network adapter out of device manager and let windows reinstall it.
You're just nitpicking words now. I was talking about in terms of performance, those are the only measurements that matter. Not IPC or clock speed.
If Bulldozer came out of the box at 5 ghz and overclocked to 6 ghz on air, no one would have said it was a failure.
DaaQ is offline
post #10 of 10 (permalink) Old 01-22-2020, 04:43 PM
EniGma1987's Avatar
Rep: 342 (Unique: 252)
When you look at the status on your NIC, does it say you are connected at 1gbps, or 100mbit?
EniGma1987 is offline
