Skylake 6700K memory tests, speed vs latency - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 08-19-2015, 11:52 AM - Thread Starter
qwwwizx's Avatar
Rep: 23 (Unique: 22)
What is faster - 3000C15 or 2400C12 or 3200C16 or 2666C13 ?????
Conclusion so far:
1) 4 sticks are a lot faster than 2. (click 2 vs 4 sticks in the sheet below)
2) You need high frequency sticks, go for 3200+ even if they are CL16 or worse.
The reason for doing this and for you to read it
When ordering my 6700k, I tried to find some information on what kind of memory modules to get for optimal performance. I couldn't really find any usable information, so I decided to make some myself and share it.
Most high performance sticks out there suffers from lousy timings. High bandwidth on memory can be hard for an overclocked CPU so it was about to find spot with decent bandwidth and good latency or the other way around. In the end I want a fast 24/7 stable system.
I ended up with some Kingston 2666CL13 sticks. Not fast, but with ok latency and not too expensive in case of poor performance.
The good thing is that these sticks had a lot of unused potential, so I ended up overclocking and trying a lot of different timings. Now that I done all that, you can see my results and make your own conclusions.
Test
My tests are only done in XTU 6.0.2.2. All tests are done by changing bandwitdth and timing in bios, load windows, test 3 times in a row, back to bios and change settings etc. until I had the whole data-set.
Now you know what to expect. Enjoy and get some good sticks. You can also get my XTU profile from the red-line directly from hwbot using this link.
H2O - 6770K (XTU 1697)
[H2O] 6700K + MSI Z170 Titanitum 4.9 GHz (turbo boost, eist) - EK HF Supreme
[H2O] EVGA SC 980 - EK FC
[AIR] Samsung 950 Pro 512GB, Samsung SM951 512GB
[AIR] Ripjaws V (4x16GB) 3200 @ 14-14-14-35 2T
qwwwizx is offline
post #2 of 4 (permalink) Old 08-28-2015, 11:31 AM
ldsh's Avatar
Rep: 1 (Unique: 1)
Could the difference in speed be linked to the memory capacity? (I don't know How XTU is doing things).
I find it strange that the increase due to the usage of 4 stick is not a fixed percentage, the higher the frequency, the higher it benefit from the 4 sticks (instead of 2):
Freq Increase when using 4 sticks instead of 2
2666 => +6.67%
3000 => +8.37%
3200 => +9.04%
I also don't understand the big difference between the
3200 16 16 40 2 12000 1652
Of the first page test and the
3200 16 16 39 2 13000 1294
3200 16 16 39 2 13000 1411
What makes the first better than the two others?
ldsh is offline
post #3 of 4 (permalink) Old 08-29-2015, 02:13 PM - Thread Starter
qwwwizx's Avatar
2666 => +6.67%
3000 => +8.37%
3200 => +9.04%
I cant tell you the reason. I just did the tests and took notes. I ran each test 3 times in a row, no reboots, no new applications on system. Just testing, testing, testing, reboot, adjust, and redo. Everything in bios like speedstep etc. is on auto settings.
That was with 4 memorysticks, CPU OC at 4x 4.9Ghz, Cache at 4.7Ghz. The CPU is overclocked a lot, to be sure I not to saturate the CPU to early.
Thats on Skylake default clocks (CPU not overclocked), only playing with memory 2 sticks vs 4 sticks. This is what you should expect with normal sticks like g.skill 3200CL16 and no CPU overclock, if you get a pack with 2 sticks vs 4.
Page 1 was just to show how memory speed and latency should be prioritized.
Page 2 was to see if it made any difference using 2 or 4 sticks.
My conclusion was something like, get 4 cheap 3200 CL16 sticks. Then you dont need to tweak it further to get good efficiency.
qwwwizx is offline
post #4 of 4 (permalink) Old 08-31-2015, 12:05 AM
ldsh's Avatar
Rep: 1 (Unique: 1)
I firstly thought there was a specific XTU benchmark for ram, but it is a global score for the machine performance.
So the difference in CPU overclock makes logically a difference between the results of the two tables.
It may be interesting to also have some benchmark memory specifics (results like theses: http://www.maxxpi.net/pages/downloads/maxxmemsup2---preview.php ). What really change between 2 or 4 sticks may be clearer.
I would also been very interested on CFD benchmarks but the servers where the STARS Euler3D CFD one should be seems down.
ldsh is offline
