Overclocking X58 (Xeon X5675) - can't get decent speed out of HyperX T1 DDR3 - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 11-19-2018, 08:18 AM - Thread Starter
Rep: 0
Hi,
this is my setup:
Mobo: Asus P6X58D-E
CPU: Intel Xeon X5675
Cooler: Scythe Mugen 2
RAM: Kingston HyperX T1 DDR3 12GB (2x 3x2GB)
GPU: Gigabyte GTX770
PSU: Corsair AX850
Case: Silverstone Raven RV01
with these BIOS settings https://imgur.com/a/zoufIUK
My PC just can't get through POST.
(memok! shows overclocking failed and points me to BIOS)
I could have just call it a day, but the best I can get is ~1300 MHz. Which is ridiculous, because sticks themselves are rated up to 2000MHz (first picture).
I also had no idea when configured my sticks in BIOS, so these to facts suggest that I may have done something wrong.
Any ideas how to tweak this?
quarien is offline
post #2 of 11 (permalink) Old 11-19-2018, 08:33 AM
Mr.4way SLI
Moparman's Avatar
Rep: 191 (Unique: 171)
have you tested each stick 1 by one? also the Xeons might not like that high of mem with 6 dimms. I was only able to do 2000+ with 3 dimms on that board with my best X5680.
Moparman is offline
post #3 of 11 (permalink) Old 11-19-2018, 08:35 AM - Thread Starter
Rep: 0
When I'm back home I'll test one by one.
But assuming that I'd like to run with all my sticks... How much of a downgrade I'm looking at?
I've seen some reviews of my sticks, some guys got up to 21xx MHz. I'd be happy with 2000. Or even 18xx. But for now, even the posted setup with 17xx just crashes. Is it the downgrade I need to accept?
quarien is offline
post #4 of 11 (permalink) Old 11-19-2018, 08:39 AM
Mr.4way SLI
Moparman's Avatar
Can you take and post all bios screen shots of everything you have set for cpu and mem OC please?
Moparman is offline
post #5 of 11 (permalink) Old 11-19-2018, 08:56 AM - Thread Starter
Rep: 0
Can you access this link from the first post?
quarien is offline
post #6 of 11 (permalink) Old 11-19-2018, 09:34 AM
Mr.4way SLI
Moparman's Avatar
Push FSB more and lower the QPI that is an issue. The pic wouldn't load the first time so no idea why. Also some of the Xeons don't lie to push high clocks at the max multi so try for around 185fsb and 23 multi. Also bump the Vcore up a little more to like 1.34v and try that. You might need closer to 1.375-1.392v for 4.2+
Moparman is offline
post #7 of 11 (permalink) Old 11-19-2018, 09:59 AM
Regeneration's Avatar
Rep: 22 (Unique: 22)
* DDR timings tRFC and tRRD are too low. Use AIDA64 to read the XMP profile and enter the timings manually.
* 1.35v QPI/DRAM voltage is too much for Westmere.
* PLL voltage boost is useless on Westmere. Keep it on default.
* Set DDR command rate to 1T (if possible).
Regeneration is offline
post #8 of 11 (permalink) Old 11-19-2018, 12:25 PM - Thread Starter
Rep: 0
I've updated my imgur post with this screenshot from AIDA:
Assuming I'm aiming towards 2000MHz, should I go with 10-10-9-27 1.65..?
I'm not sure how to read these.
quarien is offline
post #9 of 11 (permalink) Old 11-19-2018, 12:54 PM
It is very simple.
post #10 of 11 (permalink) Old 11-19-2018, 03:02 PM - Thread Starter
Rep: 0
It feels like it is a good step, because I managed to get stable (yet hot) 4+ at CPU and 1800-ish in RAM.
However I have a problem with DRAM RAS# to RAS# Delay - it goes up to 7 DRAM Clock (not 8) and DRAM WRITE Recovery Time goes up to 15 DRAM Clock (not 19).
Currently I have also problems with balancing my BCLK and RAM.
I noticed, that the general rule of thumb is that my DRAM speed can't get past the third position.
So if I got 1333MHz with the base settings, and later apply some OC to the CPU I get ~1600MHz. And then it boots. I'm new into OC... is this normal behavior?
No matter how I'm shuffling I barely can scrape more than ~1800MHz. Does this look like the limit of filling up all memory slots on my motheboard?
And lastly, maybe it's the least important thing.
But with x23 multiplier, 4.2GHz and 1800 MHz RAM I can get barely up to 850cb in CinebenchR15. Is that also normal?
quarien is offline
