chance of overclocking corsair ddr4 ram with the same CAS latency as default? - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 04-02-2019, 03:30 PM - Thread Starter
alexander1986's Avatar
Rep: 0
hi, looking to buy corsair 2x8 gb ddr4 cl 16-18-18-36 3200mhz ram, model is CMK16GX4M2B3200C16 ,
I saw a dude overclocking these to 3500 mhz without changing the cas timings at all and with the default 1.35 volt, is this common or lucky?
Wondering if overclocking them to 3200-3600 with the default cas timings is realistic in other words for everyone, or depends on other things perhaps as motherboard/voltages for those system agent stuff in bios etc (forget what they are called exactly)
thanks
alexander1986 is offline
post #2 of 13 (permalink) Old 04-02-2019, 03:45 PM
Rep: 20 (Unique: 19)
Lucky.
3600 would usually require around c18 with the Hynix chips used in 3200c16 to get a decent OC with increased vdimm you want 3200c14 for Samsung b-die which can typically do about 3600c15 or 4000c17 with 1.4-1.45vdimm unless you get higher binned kit's using the same chips that do 3600c15 1.35v stock.
Dasa is offline
post #3 of 13 (permalink) Old 04-02-2019, 06:28 PM - Thread Starter
Rep: 0
Quote: Originally Posted by Dasa View Post
Lucky.
yeah, ive read about the samsung b-die and saw some g.skill kit cl14 3200 mhz with them, cost a fair bit more aswell I guess,
for a small OC you think going to 3333/3400 mhz from 3200 on the corsair kit mentioned earlier with hynix,
while keeping 1.35 v and 16-18-18-36 timings would be more realistic and easily attainable?
cheers
post #4 of 13 (permalink) Old 04-02-2019, 06:31 PM
With some extra v and some time spent tweaking you should be able to squeeze a little out of them especially if you take the time to tweak sub timings.
Dasa is offline
post #5 of 13 (permalink) Old 04-09-2019, 05:03 PM - Thread Starter
Rep: 0
hello again, wanted to ask basically same question but with bit lower rated kits and starting point, if we have lets say 3000mhz cl15 kit , think it was corsair vengeance 3000mhz 15-17-17-35 rated,
how easy/likely would it be to push them to say 3200mhz with same timings or better? like 16-18-18-36 or better? and so on, I guess your previous answer still applies but like,
how common of an OC is that or more specifically how rare would it be to see that fail, if you have an approximation?
cheers and sorry if silly question
post #6 of 13 (permalink) Old 04-09-2019, 05:43 PM
3000c15 and 3200c16 have about the same final latency so it is a bit of a side move and should be very easy to achieve but you will only gain a little more bandwidth.
There is also a fair chance your kit will hit 3600c18 but for 3600c15 you really need samsung b die.
When you divide frequency by cas 3000c15\3200c16\3600c18 all equal 200.
Dasa is offline
post #7 of 13 (permalink) Old 04-10-2019, 03:02 AM - Thread Starter
Rep: 0
I see but thats till only just the first cas value and no other timings, wouldnt really good/good timings (if you take time to dial in all or most of them) on 3000mhz easily beat bad/mediocre timings on 3200 for example? or the slight difference in frequency makes up for that anyway?
seems hard to determine this without actually testing but hard to do before buying
if we say like this, if you had to pick something for the same price, would you pick 3000mhz cl 15-16-16 or 3200mhz 16-18-18 ? and the 3200mhz is a fair bit more expensive even in this particular case?
because to me as a noob , the 3000 mhz cl-15-16-16 seems more likely to overclock well than the 3200 mhz 16-18-18, or is that a bad way of thinking?
appreciate the help !
post #8 of 13 (permalink) Old 04-10-2019, 03:26 AM
Overclocker in training
ThrashZone's Avatar
Rep: 47 (Unique: 37)
Hi,
Verify the C15 timings they seem off C15 should be 15-17-17-35 not 15-16-16.
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
Audio
Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #9 of 13 (permalink) Old 04-10-2019, 11:10 AM - Thread Starter
Rep: 0
Quote: Originally Posted by ThrashZone View Post
Hi,
ye it was just kind of an example I guess, should have just said cl15 above that post I did write cl15-17-17-17-35 though
post #10 of 13 (permalink) Old 04-10-2019, 04:56 PM
I think you would find that 3000c15 and 3200c16 are a similar bin of the same chips so both should reach a similar level once all sub timings have been tweaked on both kit's, if anything 3200c16 may be a smidgen higher bin.
Dasa is offline
