what should I buy, lower speed better timings or slightly higher speed worse timings? - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 04-10-2019, 03:08 AM - Thread Starter
alexander1986's Avatar
Rep: 0
if you had to pick between say 3000 mhz cl 15-16-16 and 3200 mhz cl 16-18-18, which one would you pick and why?
to me it feels like the first option would have more chance of overclocking reasonably, in the worst case to atleast same level of the other option so 16-18-18 should be possible,
and for a MUCH cheaper price in this current shop im looking at, so that seems it would make it a good choice imo?
what would you do and why? and also what speeds/timings would you go for on these options and what would you consider likely to hit,
and would you even need to change vdimm/vccsa/vccio at all on these small overclocks you think?
sorry for noob question but having real hard time deciding have tried researching ram overclocking a lot but the obvious choice here still not clear to me,
on a pretty tight budget aswell otherwise I'd just get better ram or samsung b-die or something
thanks anyway and cheers!
alexander1986 is offline
post #2 of 18 (permalink) Old 04-10-2019, 03:12 AM
Graphics Junkie
UltraMega's Avatar
Rep: 15 (Unique: 15)
It will make a very tiny difference either way. Ram speed has a pretty small impact on most things, including games. I'd just get the cheaper one. It's not worth investing much time or money into getting much past 3000mhz-3200mhz ram.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #3 of 18 (permalink) Old 04-10-2019, 03:13 AM
Not new to Overclock.net
TwoCables's Avatar
Rep: 6214 (Unique: 3521)
That depends on your CPU. Is it going to be an AMD CPU or an Intel CPU?
Loneliness is a good thing to share with someone.
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
i5-2500K @ 4.5GHz (1.368-1.384V fixed voltage)
ASUS P8P67 EVO B3 (UEFI ver. 1850)
MSI GTX 1070 Ti Gaming Titanium 8G
G.SKILL Ripjaws X 8GB (2 x 4GB) 1866MHz, CL9
250 GB Samsung 840 EVO (OS)
3 TB Toshiba P300 (D: drive)
Optical Drive
Samsung SH-S243N 24x DVD Burner
Optical Drive
Samsung SH-S203N 20X DVD Burner
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
AOC G2460PG (24" 1920 x 1080 144Hz G-SYNC)
Keyboard
Filco Majestouch 104-key Cherry MX Blues w/NKRO
Mouse
Intellimouse Optical (1.1A) 1000Hz polling rate
Mousepad
It's just a mousepad
Audio
X-Fi Titanium HD
Audio
Klipsch ProMedia 2.1 (with 16 AWG Monster Cable speaker wires)
TwoCables is offline
post #4 of 18 (permalink) Old 04-10-2019, 03:16 AM
404 Title Not Found
accskyman's Avatar
Rep: 196 (Unique: 188)
What motherboard/cpu?
Would likely influence the decision. Budget? There are deals to be had, if you are willing to buy used and watch the forums/ebay etc.
900D
(14 items)
5820k
MSI X99 S Plus
Powercolor 290x
F4-3000C15Q-32GRBB
512gb Samsung 950 Pro M.2
Seasonic 760w Platinum
custom loop
Corsair 900D
Operating System
Windows 10 x64
Asus VG248QE
Keyboard
Tesoro Durandal
Mouse
Moinix Naos 8200
Mouse
Razor Goliathus Speed
Audio
SB X-FI Titanium
accskyman is offline
post #5 of 18 (permalink) Old 04-10-2019, 03:17 AM
Overclocker in training
ThrashZone's Avatar
Rep: 48 (Unique: 38)
Hi,
Doubt it matters both would be hynix kits
C15 would be 15-17-17-35
C16 would be 16-18-18-36
3200C16 would be a little faster neither would likely oc very much higher than it's rated speed but both sets are cheap for a reason hynix kits.
https://benzhaomin.github.io/bdiefinder/
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
Audio
Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #6 of 18 (permalink) Old 04-10-2019, 04:07 AM
deepor's Avatar
Rep: 467 (Unique: 314)
Don't forget to translate the timings into real time when comparing. For example, 15 clock ticks at 3000MHz is the same actual time as 16 at 3200MHz:
15 / 3 GHz = 5 ns
16 / 3.2 GHz = 5 ns
deepor is offline
post #7 of 18 (permalink) Old 04-10-2019, 11:05 AM - Thread Starter
Rep: 0
thanks for the answers so far
intel 9600k on z390 I guess, I guess with ryzen it changes things a lot more and its more affected by ram speed and so on ?
as it looks now 9600k with a cheaper gigabyte z390 board because of the decent VRMs on those for overclocking cpu, not sure how good / bad they are for memory,
looks like 3000 mhz cl15 is good if I can find a really good price on them or else I think i'll just go for 3200 mhz cl16, would prefer to buy new parts at this moment also
post #8 of 18 (permalink) Old 04-10-2019, 11:10 AM
TwoCables's Avatar
Z390 AORUS PRO, I hope.
Anyway, yeah, with Intel, the timings are more important than the clock speed. With AMD, the clock speed is more important.
Hey, do you already have the 9600K? The reason I ask is, all of my research for my own upgrade plans tell me the 8700K is a much wiser purchase for gaming performance and overclocking.
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
post #9 of 18 (permalink) Old 04-10-2019, 11:23 AM - Thread Starter
Rep: 0
well in my region 8700k is a lot more expensive than 9600k, like +150 euro or something like that, half the price of a 9600k more or less, I was contemplating a 8700 nonclocked for a while since both the 8700k and 8700 run 4.3 ghz all core turbo stock if im not mistaken, and for me it would be plenty really, even overclocked the fps gains are not that huge with a rtx 2060 from what I can see in game benchmarks,
reason I also was thinking of the 8700 was because of hyperthreading but after looking at a LOT of game benchmarks it really seems the 9600k is more than enough and the fps difference in many games are single digit at most, sometimes dead even, so was thinking get 9600k save some money and spend that on rest of build, maybe in a year or two get a 9700k/9900k or something like that if needed..
settled with going for 9600k since it really seems like the sweet spot for my needs anyway :S
IDK
post #10 of 18 (permalink) Old 04-10-2019, 11:25 AM
TwoCables's Avatar
IDK
One thing you haven't seen yet then is how the frametimes are a little better on average with the 8700K, which can mean you won't notice as much 'sticking' or 'hitching' in games.
I dunno, it's just that in all my research, everything points to just these few words: do not buy the 9600K. The 8700K is much better. Even the 9700K has similar frametime performance issues to the 9600K. Something's not quite right with those CPUs...
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
XAslanX
