question about BCLK overclocking affecting memory overclocking - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 04-18-2019, 08:34 AM - Thread Starter
alexander1986's Avatar
Rep: 0
so lets say you have a locked cpu like the i7-8700 on a z390 board,
then you have a cl15 3000mhz 2x8gb ram kit, and lets say you successfully overclock the memory to 3400 mhz cl13
how would a slight bclk overclock on the cpu say to 102.5, to get 4.4 ghz all core turbo, affect the memory speed in this case?
would it likely make the memory fail a boot/post if it was at its limit prior to the bclk overclock?
and if so is there any way to change the memory multiplier to get back the 3400 mhz or close to it?
thanks for any help
EDIT: if I understand things correctly it would in this case make the ram run at 3485 mhz instead of 3400, which might fail a post/boot if ram was at
its limit prior to the bclk increase, I guess there is no way to separately adjust memory:bclk ratio to finetune it back to 3400 for example?
maybe I could set the memory speed preset down to 3333 mhz after the bclk increase, to get something like 3333+2.5% = 3416 mhz ?
or could try using the 3300mhz setting which would give 3300+2.5% = 3382 mhz?
or is that calculation wrong ? :S
alexander1986 is offline
post #2 of 5 (permalink) Old 04-18-2019, 10:24 AM
Memory Overclocker
Rep: 23 (Unique: 9)
Looks like same exact question I answered here: https://www.reddit.com/r/overclockin...ecting_memory/
[email protected] (-1 AVX offset) on ASRock Z390 Taichi with Noctua NH-D15 air cooler
CPU offset voltage of -25mv, runs VRVout 1.240-1.313V on full AVX load, 1.225-1.275V on non-AVX load
2x8GB [email protected] at 1.45V, G.Skill F4-3733C17Q-32GTZKK (XMP rated [email protected])
EVGA GTX 1060 6GB OC with Corsair RMx 750W power supply
Samsung 970 EVO 500GB NVMe boot SSD and four other drives all in a Fractal Design R6 Case
jfriend00 is online now
post #3 of 5 (permalink) Old 04-18-2019, 11:31 AM - Thread Starter
Rep: 0
indeed it is, small world
usually post questions at few different places atleast two or three, for cross reference and/or to get answers ASAP
seems like it should work fine anyway !
post #4 of 5 (permalink) Old 04-22-2019, 03:06 PM
Hardware Rep
GSKILL SUPPORT's Avatar
Rep: 6 (Unique: 6)
Same way you overclocked, so try a higher Voltage first to see if it can support the lower timings.. and if not work on increasing one at a time to see which will allow stability at the higher frequency. However, say you want to keep DRAM Voltage lower at say 1.35V, then you have no choice but to increase timings.
GSKILL SUPPORT is offline
post #5 of 5 (permalink) Old 04-22-2019, 03:11 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 970 (Unique: 597)
it's based off your FSB : DRAM ratio. Used to be called a divider in ye olde days but no one really says that anymore.
At 100 base clock with 3000 RAM it'd be 1:30. At 103 base clock with no other changes your RAM would be 3090.
I'm playing with base clock a bit now. I'm running 103.3 base clock and a 1:40 RAM ratio. Works out to 4135.
https://valid.x86.fr/jd4t23
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 16GB
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
