G.Skill Trident Z RGB 3200Mhz Overclocking Help - Overclock.net - An Overclocking Community
post #1 of 44 (permalink) Old 04-20-2019, 10:43 AM - Thread Starter
Sylencer90's Avatar
Rep: 0
So i've got my hands on a rather "cheap" opportunity to grab a Kit of those Trident Z RGB's (F4-3200C14D-32GTZR). I heard these have so called "B-Dies" which should handle a decent enough overclock.
Im completely unexperienced when it comes to overclocking RAM, regardless of which Type. Only did some OC on my GPU as well as my CPU.
Specs (will add more infos if needed):
Z390 Aorus Pro (F9 Bios)
i9 9900k @ 5Ghz | 1.3V /w Speedshift enabled | Simple OC, didn't go that far in depth - changed voltage and some easy settings.
CPU Cooling : Corsair H115i Pro /w 2x Noctua NF-P14s redux-1200 PWM mounted on. Running at ~800RPM. (Cpu Load Temp is somewhere between 50-60°C / while Rendering max. 75°C)
Asus Strix 2080 OC Gaming (+80 Core / +1000 Mem @ Stock Voltage) usually 50°C max is 60-63°C under Load / Idle 30~40°C
Ram @ Stock Settings 40-45°C (under Load) / Default XMP Profile
Case : Silent Base 801 - 3x Pure Wings 2 140mm (1x Front right under the Radiator, 1x Back & 1x Top) Running at 700RPM.
All OC on the CPU & GPU are stable and have been tested in a 8h Stresstest. No Issues there.
What im aiming for is a 24/7 ready OC. Which should obviously not hurt the Hardware at all.
I'd appreciate if some of you Overclockers would be so kind to give me some Tips maybe even Step-By-Step Guide on how to get some more Juice out of that Kit what i paid a good amount of money for. Even if it's minor or not even noticeable on a daily base.
Edit² : After doing some research i'd like to get my Ram on 3600 CL15. So if someone could suggest me some "failsafe" settings (secondaries and so on) on this, i'd really appreciate that.
Kind regards,
Sylencer90
My Rig
(17 items)
Intel i9 9900k
Gigabyte Z390 AORUS PRO-CF
Nvidia GeForce RTX 2080 Asus Strix OC
G.Skill Trident Z RGB (F4-3200C14D-32GTZR)
Samsung SSD 970 EVO 250GB M.2
Crucial MX500
Seagate Barracuda Compute
be quiet! STRAIGHT POWER 11 CM
Corsair H115i Pro
be quiet! Silent Base 801 tempered Glass Edition
Operating System
Windows 10 Pro x64
Asus VG248QE
Philips 227E4LHAB
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech G503 Proteus Spectrum
Mousepad
Corsair MM200
Audio
Wavemaster Moody
Sylencer90 is offline
post #2 of 44 (permalink) Old 04-20-2019, 01:31 PM
disintegratorx's Avatar
Rep: 5 (Unique: 5)
As far as your voltage goes, I'd pretty much keep that where its at and then focus on your VCCIN voltage compared to your processor and motherboard recommended OC by someone that has overclocked it, and try some lower timings or if you're going with higher speeds, see what it can handle with your already rated SPD, and I think with this DDR4, the TRRCD, or whatever it actually is, the one with the higher clocks above 700, you can probably turn those down a little bit, for example mine was set at 748 and I have mine tuned to a tea at 734. The secondaries unless you really can know what you're doing, I wouldn't mess with those. Also, I know that in the previous Gen you could change the read to pre lower, but I haven't been able to do that for this Gen, DDR4.
Sess
(16 items)
Intel i9 7900x
MSI X299 Gaming M7 ACK
MSI RTX 2080 Hybrid
G.Skill 4 X 8GB @ 4000Mhz CL16
Intel Optane 480GB PCIe x4
OCZ Vertex 4 128GB x 2 + 1 other
Optical Drive
DVD Burner
EVGA P2 1200w
EVGA CLC 280
Corsair Air Max 540
Operating System
Windows 10 Pro
Samsung 32" Quantum Dot LED 144Mhz
Keyboard
Razer Black Widow Ultimate 2017
Mouse
Razer DeathAdder Elite
Mousepad
Razer Destructor 2
Audio
Sound Blaster Titanium HD
disintegratorx is offline
post #3 of 44 (permalink) Old 04-20-2019, 02:24 PM
Avid Something-or-Other
shellashock's Avatar
Rep: 5 (Unique: 5)
To start, I recommend you read Magetank's DDR4 OC guide here: https://www.overclock.net/forum/1805...ing-guide.html
This gives the basics of memory settings, "safe" voltage ranges, when to make tradeoffs between frequencies and timings and the general order of memory OC operations.
Once you have read Magetank's guide and have an idea of what to expect, I would look at the official DDR4 24/7 stability thread here: https://www.overclock.net/forum/5-in...ty-thread.html
It is very important to make sure you are properly testing for memory stability in order to prevent silent (or not so silent) memory corruption during your overclocking escapades. You can find all kinds of anecdotes, best practices and obscure tips in this thread and is well worth skimming through. Do note that memory overclocking can have many failure points (too high frequency, too tight timings, too much/not enough VDIMM/VCCSA/VCCIO for desired settings, not enough vCore for combined CPU Cache + DDR4 OC, etc) and it is vital to detect any instability BEFORE you get 30 settings deep into an overclocking spree and cannot figure out how to stabilise your OC.
If there is anything you should take away from here, it is "Test one thing at a time, prove stability before moving on and ALWAYS backup your data before you begin memory overclocking!"
Finally, I have found this thread on HWBot by [email protected] very helpful for understanding relationships and general expectations for DDR4 memory settings: https://community.hwbot.org/topic/14...-motherboards/. I recommend that you treat this guide as a checklist for overclocking your memory; change one group of settings at a time, check if it is stable and how the changes impact performance and adjust accordingly.
In general, I highly suggest you don't blindly copy-paste numbers into your bios for each setting because differences in motherboards, memory sticks/ICs and even CPU IMCs can dramatically change what settings are even bootable; let alone stable. I would always recommend you take a look at what your mobo + memory XMP settings are and change from there.
EDIT: How much time are you willing to invest in overclocking your RAM? Even ignoring the time it takes to stability test, RAM overclocking can be very finicky and require dozens of changes before you find something that works; even when just playing with frequency, primary timings and tRFC.
shellashock is offline
post #4 of 44 (permalink) Old 04-21-2019, 03:45 AM - Thread Starter
Sylencer90's Avatar
Rep: 0
Thanks for the informative answer ! I was actually hoping someone would actually rock my specs since it's not that uncommon to use and maybe found out some decent settings which i could just copy.
My Rig
(17 items)
Intel i9 9900k
Crucial MX500
Corsair H115i Pro
Operating System
Windows 10 Pro x64
Asus VG248QE
Philips 227E4LHAB
Keyboard
Mouse
Mousepad
Corsair MM200
Audio
Wavemaster Moody
post #5 of 44 (permalink) Old 04-21-2019, 06:19 AM
Hardware Princess
Hydroplane's Avatar
Rep: 37 (Unique: 29)
Set voltage to 1.5v, set speed to 3600, leave the timings stock (14-14-14-34), worked for me
CHILLER DESTRUCTION
Build Log - White Voodoo
basic linux pc
(15 items)
Z390 Station
(11 items)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4600c20 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #6 of 44 (permalink) Old 04-21-2019, 06:56 AM
Overclocker in training
ThrashZone's Avatar
Rep: 132 (Unique: 85)
Hi,
Past 3200C14 speed can show diminishing results
Keep in mind ram oc'ing is a very good way to corrupt an os install
Make system images before attempting it.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #7 of 44 (permalink) Old 04-21-2019, 06:18 PM
Rep: 23 (Unique: 22)
Quote: Originally Posted by ThrashZone View Post
Hi,
True but overclocking 3200c14 XMP to 4000c17 still brings more performance to some programs than overclocking my 6700K from stock to 4.7GHz and 9900K having twice the cores is likely to be a fair bit more starved for memory.
A good way to avoid corrupting primary OS is to run Gsat in linux from a USB boot for preliminary testing and finish up with HCI once you have it dialed in which will focus more on the memory controller stability.
There is some good info here
Although a lot of it will likely go over your head and the article is aimed at AMD CPU this still has some great general info.
https://www.techpowerup.com/reviews/...locking_Guide/
Dasa is offline
post #8 of 44 (permalink) Old 04-22-2019, 07:39 AM - Thread Starter
Sylencer90's Avatar
Rep: 0
Doesn't it hurt the Mem running over 1.4v 24/7?
My Rig
(17 items)
Intel i9 9900k
Crucial MX500
Corsair H115i Pro
Operating System
Windows 10 Pro x64
Asus VG248QE
Philips 227E4LHAB
Keyboard
Mouse
Mousepad
Corsair MM200
Audio
Wavemaster Moody
post #9 of 44 (permalink) Old 04-22-2019, 07:43 AM
ThrashZone's Avatar
Hi,
Yeah 1.5v is on the extreme side
3600 might not even need 1.4 for 400Mhz.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #10 of 44 (permalink) Old 04-22-2019, 07:44 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1282 (Unique: 691)
The issue like with OCing anything is temps. Just make sure it has good airflow. 1.5v is safe for 24/7 and even ~1.9v is fine for benchmarking.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
