What's The Difference Between These 4 Sets Of Ram? - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 04-21-2019, 06:00 AM - Thread Starter
Aprojectile's Avatar
Rep: 1 (Unique: 1)
Okay, so I'm looking at these 4 sets of ram for my system upgrade I'm about to be doing. 2 of these sets are 3200MHz CAS14, and the other 2 are CAS16. But I'm just curious as to what the differences are between the matching sets. Like I know the 2 with CAS14 are different from the 2 with CAS16. Either way here are the sets of ram.
https://www.newegg.com/Product/Produ...82E16820232485
https://www.newegg.com/Product/Produ...82E16820232649
The above 2 are the CAS14. They look to be completely identical all around other than one of them has a X at the end of it's model name.
https://www.newegg.com/Product/Produ...82E16820232476
https://www.newegg.com/Product/Produ...82E16820232751
And these 2 are the CAS16 sets. And same thing with them, they look completely the same other than one of them has a X at the end of it's model name.
So I'm curious as to what the X stands for with them. Does all 4 of them use Samsung B-Die chips? Or does the X maybe represent that? Any help on this matter would be nice and appreciated!
Thanks!
Aprojectile is offline
post #2 of 8 (permalink) Old 04-21-2019, 06:13 AM
Overclocker in training
ThrashZone's Avatar
Rep: 71 (Unique: 55)
Hi no all don't have b-die
C14 is likely too have timings often show yes b-die 14-14-14/ 15-15-15/ 16-16-16 would like all be samsung b-die
loose timing like the last two kits 16-18-18/....are likely hynix or micron not all the desirable but can usually do the rated speed without many issues and save a little money in the process than expensive b-die.
This can make finding or confirming b-die easy
https://benzhaomin.github.io/bdiefinder/
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 8 (permalink) Old 04-21-2019, 06:14 AM
Hardware Princess
Hydroplane's Avatar
Rep: 25 (Unique: 22)
3200c16 is SK Hynix, 3200c14 is samsung B-die. Huge price difference, I know, but the 3200c14 will overclock much better. They can generally hit 4000+ on Intel platforms.
$180 isn't bad for the RGB 3200c14, I paid that much for non-RGB before, I might buy those lol
There is also 3200c15 B-die out there per the finder, around $155-160 for the 16gb set if you want to save $, also 3000c14 for $145
If you want RGB looks like these are the cheapest b-die for $165:
https://www.newegg.com/Product/Produ...D=3938566&SID=
CHILLER DESTRUCTION
Build Log - White Voodoo
Z390 Station
(11 items)
White Voodoo
(14 items)
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4133c16 1.5v
Samsung 970 Evo Plus 250gb
ancient silverstone 1200
HWLabs GTX 360 Rad (in RED)
3x EK Vardar 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Intel Core i9-7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
Gigabyte Aorus Waterforce WB 1080 Ti SLI 2037/6318 1.09V
Trident Z 32GB (4x8GB) 3200C14 @ 3800C16 1.50V
Samsung 960 Evo 1TB
EVGA 1600 T2
HWLabs Nemesis GTR 420+280 Rads
(7) Noctua NF-A14 iPPC-3000 PWM Fans
EK-XRES 140 Revo D5 RGB PWM
LD Cooling PC-V7 280/420
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
NEC PA271W 2560x1440
Keyboard
Razer Blackwidow Chroma V2
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #4 of 8 (permalink) Old 04-21-2019, 07:38 AM - Thread Starter
Rep: 1 (Unique: 1)
So the two C14 kits are Samsung B-Die, good to know! Now what about the difference between the two C14 kits? I can't seem to figure out what is different other than the model name ending with an "X" for one of the kits. I don't know if that "X" represents anything or not?
post #5 of 8 (permalink) Old 04-21-2019, 07:46 AM
ThrashZone's Avatar
Hi,
One of the C14 is tagged as compatible with AMD x399 systems.
Although it says also amd 370 didn't know that was an amd board :/
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #6 of 8 (permalink) Old 04-21-2019, 07:49 AM
Meep
Gilles3000's Avatar
Rep: 299 (Unique: 220)
The X version is supposedly more AMD(Ryzen/Threadripper) optimized, can't seem to find what they actually optimized about it though...
Gilles3000 is offline
post #7 of 8 (permalink) Old 04-21-2019, 07:53 AM - Thread Starter
Rep: 1 (Unique: 1)
Okay so the X just means it's meant to run better with AMD, got it. Well that answers all my question I had. Thanks for the quick replies everyone!
post #8 of 8 (permalink) Old 04-21-2019, 07:58 AM
ThrashZone's Avatar
Hi,
Always check the product on g-skill website
It will show the qvl = qualified venders list and make sure you mother board is listed on it before actually buying
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
