Please help with memory error CC - Overclock.net - An Overclocking Community
post #1 of 19 (permalink) Old 04-25-2019, 05:26 PM - Thread Starter
munternet's Avatar
Rep: 41 (Unique: 17)
I have a question no-one seems to be able to answer.
I have a friend with a Asus Maximus Extreme and 9900k and it gives error cc when he tries to boot his G.Skill RGB 4266 Ram.
G.SKILL Trident Z RGB F4-4266C19D-16GTZR 16GB (2 x 8GB) DDR4 4266Mhz CL19 1.4v
He has tried different combinations and numbers of these sticks, from 1 to 4 in different slots but still nothing. These are 2 sets of 2x8GB kits with consecutive serial numbers although the Asus qvl lists the 4x8GB kit. Either way I would have thought these the same sticks?
Does he need to enter some other settings? And if so how would he go about it?
The PC boots with all other ram that he's tried. (lower speed though)
Is there some way to get it to boot???
Any help would be greatly appreciated before he returns them
Cheers
9900ks
Asus Maximus XI Gene
EVGA 1080 Ti Superclock 2 Black
F4-4400C19D-16GTZSW
Samsung M.2 1TB 970 EVO Plus
Corsair HX1200i
EK 140D5 Pump, waterblocked CPU, Ram, GPU with 1 x 360mm and 1 x 420mm Radiators and Vardar Furious Fans
ThermalTake V51
Operating System
Windows 10 Pro
Asus PG349Q 34.1 inches 3440 x 1440 pixels @ 120 Hz
Keyboard
Corsair K95 RGB Platinum
Mouse
Logitech Gaming Pro Wireless
Mousepad
1000x500x3
Audio
Steelseries Siberia800 wireless Headset
8700k @ 5.2ghZ
Maximus X Hero
32GB 1xF4-4400C19D-16GTZSW & 1xF4-4400C19D-16GTZKK
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Asus Spatha Wireless Gaming
Mouse
Ligitech G602 wireless
Mousepad
1000mm x 500mm
Audio
i7-4770k
Asus Maximus VII Ranger
Gigabyte NVIDIA GeForce GTX980
G.SKILL Trident X 16GB 2 x 8GB 2400 Memory F3-2400C10D-16GTX
Seagate Barracuda 2TB
Optical Drive
LG DVD Rom
PSU Coolermaster V1000W
Custom Loop
Case Thermaltake V51 Full Window
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Thermaltake Poseidon Z
Mouse
Logitech G602
munternet is offline
post #2 of 19 (permalink) Old 04-25-2019, 05:33 PM
Graphics Junkie
UltraMega's Avatar
Rep: 56 (Unique: 51)
for speeds past 3600mhz, the kit matters more. Might be because you have two kits. Consecutive serial numbers doesn't matter as they were not tested together.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #3 of 19 (permalink) Old 04-25-2019, 06:54 PM
Nammi's Avatar
Rep: 6 (Unique: 6)
It's possible that the IMC on his 9900k is just not up to the task. Though I'd suspect it's most likely some bios settings that need some work, I run 2 sets of 2x8GB F4-4133C17D-16GTZR just fine on the aorus master.
Check if the bios needs an update, after that either load default bios settings or just set all the timings except the primaries to auto and make sure xmp is disabled. Manually set the memory speed to 4266, primaries to 19-19-19-39, DRAM voltage to 1.5V, VCCIO and VCCSA to 1.3V just to see if it boots.
Nammi is offline
post #4 of 19 (permalink) Old 04-26-2019, 04:35 PM - Thread Starter
munternet's Avatar
He updated the bios and tried running just one set at a time.
He has AI installed on windows and is running an overclock on the CPU through that. Maybe that messes with the bios as I understand some settings are grayed out. I haven't used it recently so I don't know?
Just to be clear, it won't boot with any settings he's tried so far.
9900ks
F4-4400C19D-16GTZSW
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Pro
Keyboard
Mouse
Mousepad
1000x500x3
Audio
8700k @ 5.2ghZ
Maximus X Hero
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Mouse
Mousepad
1000mm x 500mm
Audio
i7-4770k
Optical Drive
LG DVD Rom
Custom Loop
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Mouse
Logitech G602
post #5 of 19 (permalink) Old 04-27-2019, 11:58 AM
Nammi's Avatar
Rep: 6 (Unique: 6)
It's a T-topology mobo, so the best bet is to use all 4 sticks. As I've never used OC software, I'm not sure how much of a hindrance it could be. Might as well uninstall it for now.
By not booting do you mean that the pc gets stuck in memory training after applying settings in the bios?
Nammi is offline
post #6 of 19 (permalink) Old 04-27-2019, 12:47 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 612 (Unique: 504)
Go back to stock and use the Bios to overclock CPU first till stable and then manually enter the RAM speed and timings (I assume the mobo supports those speeds) and try overvolting the RAM as well. Tell your friend not to use software to overclock anything.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
PC-JMK5-Cool 5 Open Frame Case
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #7 of 19 (permalink) Old 04-27-2019, 03:47 PM - Thread Starter
munternet's Avatar
The q code display changes to different numbers for a while and then shows cc without the screen turning on.
The ram is getting returned and the supplier is going to help him get some suitable sticks.
Can anyone suggest 4 sticks of 4133+ MHz ram that have worked easily with the Asus Maximus XI Extreme? G.Skill seems to be the best priced locally.
Cheers
9900ks
F4-4400C19D-16GTZSW
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Pro
Keyboard
Mouse
Mousepad
1000x500x3
Audio
8700k @ 5.2ghZ
Maximus X Hero
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Mouse
Mousepad
1000mm x 500mm
Audio
i7-4770k
Optical Drive
LG DVD Rom
Custom Loop
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Mouse
Logitech G602
post #8 of 19 (permalink) Old 04-27-2019, 06:22 PM
Nammi's Avatar
Rep: 6 (Unique: 6)
Ok so it didn't pass memory training. Assuming that the sticks weren't faulty and the IMC isn't a dud, either some timings/settings needed a tweak or more volts to the memory controller, to the ram or both.
Anyway I hope your friend has more luck with another kit, as the frequency range that he's aiming for especially at 32GB is asking quite a lot from the IMC and is not guaranteed to work. He should expect that some tweaking can be required.
Nammi is offline
post #9 of 19 (permalink) Old 04-27-2019, 06:54 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1434 (Unique: 726)
Cheers
Pick something on the QVL. Look at both the motherboard's QVL and the RAM's QVL and make sure both are listed as validated. If it's on the QVL for both and it doesn't work, then it's faulty.
People blame the IMC far too often, it's almost never the issue.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is offline
post #10 of 19 (permalink) Old 04-27-2019, 09:04 PM - Thread Starter
munternet's Avatar
Hey thanks.
I read that out to my friend on discord and he said to say "thanks very much"
I see you have reached another 500 posts counting this one. Now at 15,500
9900ks
F4-4400C19D-16GTZSW
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Pro
Keyboard
Mouse
Mousepad
1000x500x3
Audio
8700k @ 5.2ghZ
Maximus X Hero
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Mouse
Mousepad
1000mm x 500mm
Audio
i7-4770k
Optical Drive
LG DVD Rom
Custom Loop
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Mouse
Logitech G602
