2x8Gb G.Skill B-die Write speed Problem - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 07-14-2019, 04:47 AM - Thread Starter
Rep: 0
Hi guys! I'm new here and also new to the Memory tweaking. Recently I've upgraded from Ryzen 1600 to Ryzen 3600 keeping the same motherboard (Gigabyte AX370 Gaming 3) and after using the AIDA64 Benchmark, I've noticed that my Memory Write speeds are almost twice as slow, something which didn't happen before. And looking other Benchmarks here, I see it is quite lower than expected for this memory.
Memory is using the X.M.P. profile @3200 (14-14-14-34). I've put everything on auto to make the screenshots.
Can you, please help me to find out what is gimping the memory? I will probably not OC the memory too much but at least I would like it to run normally.
I've tried to tweak the numbers manually for couple if hours (mainly the numbers which I've got from the DRAM Calclator) and allthough the Read went above 50k MB/s ... my writes stayed 1/2 ratio. Quite disappointing tbh.
Thank you in advance!
sadjoker is offline
post #2 of 12 (permalink) Old 07-14-2019, 06:00 AM - Thread Starter
Rep: 0
Got it working @3600... still Writing is ... quite low. The problem might be a combination of old AGESA (bad BIOS) and CPU.
sadjoker is offline
post #3 of 12 (permalink) Old 07-14-2019, 06:11 AM - Thread Starter
Rep: 0
Quoting another member of the forum saying: "It's OK, only 3900X/3950X will have same write speed [1 chiplet gets half the write speed]."
Welp, it seems I'm out of luck
sadjoker is offline
post #4 of 12 (permalink) Old 07-14-2019, 10:02 AM
toxick's Avatar
Rep: 2 (Unique: 2)
Hello,
I have the same issue on second system AMD Ryzen5 3600X (Before AMD Ryzen 5 2600X), ASRock Fatal1ty AB350 Gaming-ITX/ac(BIOS 5.70), G.Skill Trident Z RGB 16GB (2x8GB) DDR4 [email protected]????, MSI RX Vega 56 AIR Boost OC, Samsung 850 EVO 500GB, HDD WD Blue 2TB, 5400rpm,, Super Flower Leadex Silver 650W, Logitech G403, Logitech G103, Asus MG278Q)
I tried all possible settings in the past couple of days.
Name:	Issue memory Ryzen 3600X.PNG
AMD Ryzen 9 3900X | ASUS CROSSHAIR VII HERO | G.Skill [email protected] | Sapphire Radeon VII | Samsung 970 EVO Plus 500GB M.2 | WD-640GB SATA-II 7200RPM 16MB AAKS | WD 2TB SATA-II 64MB Caviar Green | Cooler Master MasterCase Pro 5 | Super Flower Leadex Gold 850W | Logitech G403 | Logitech G810 | BenQ XL2730 | Custom Loop-EKWB |
toxick is offline
post #5 of 12 (permalink) Old 07-14-2019, 10:27 AM
Overclocker in training
ThrashZone's Avatar
Rep: 186 (Unique: 111)
Hi,
With latency high doubt it will ever be good.
Thought latency was supposed to be improved in 3000 guess some tuning is in order.
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is offline
post #6 of 12 (permalink) Old 07-14-2019, 10:42 AM
The last VRM burner
Rep: 48 (Unique: 28)
My best bet is that latency is a trash mobo issue.
PC for all
(23 items)
i7 5775c @4.2GHz/3.8GHz
MSI Z97 MPower
Iris Pro 6200 1300MHz
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Front Arctic P14 PWM PST x2
Top Arctic P14 x2
Back Arctic P12
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mouse
Tiger Gaming Arc teflon mouse feet
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #7 of 12 (permalink) Old 07-14-2019, 10:55 AM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
It's because it's a single CCD chip (Ryzen 5 3600 and Ryzen 7 3700X are both 2 CCX , one CCD). On dual CCD chips it will have full memory write.
toxick , it's probably your memory subtimings
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #8 of 12 (permalink) Old 07-14-2019, 11:08 AM
Meddling user
gupsterg's Avatar
Rep: 786 (Unique: 360)
Zen2 has higher latency than Zen/Zen+. Perhaps later AGESA will give some gains, this did happen on Zen, even if not Zen+.
gupsterg is offline
post #9 of 12 (permalink) Old 07-14-2019, 11:37 AM
ThrashZone's Avatar
Hi,
About all i can make out is DramREF Cycle Time
Can't tell what DRam Refresh Interval is ?
70-80's is a lot of latency
Most Intel is 30-40's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
Keyboard
Logitech G710+
Mouse
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
post #10 of 12 (permalink) Old 07-14-2019, 11:39 AM
toxick's Avatar
Rep: 2 (Unique: 2)
Yes, you are right!
Because of that memory write bandwidth is half on CPUs with 1xCCD (<=8C) compared to Ryzen 5 2600X.
Elmor explains it in the link below:
https://www.overclock.net/forum/13-a...x470-x570.html
toxick is offline
