best bang for the buck RAM for Ryzen 7 3700X system - Page 2 - Overclock.net - An Overclocking Community
post #11 of 18 (permalink) Old 07-21-2019, 07:02 AM - Thread Starter
kevindd992002's Avatar
Rep: 85 (Unique: 67)
Well, let's consider that I'll also OC this system to a certain degree.
Sent from my SM-G950F using Tapatalk
kevindd992002 is offline
post #12 of 18 (permalink) Old 07-21-2019, 09:13 AM
rdr09's Avatar
Rep: 862 (Unique: 630)
The cpu has a club where you ask same question and get a better answer. For the RAM, if you will oc it, then it might be safer to go B-die. It is easier to work both Speed and Timing with this die.
https://www.overclock.net/forum/10-a...n-9-3900x.html
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #13 of 18 (permalink) Old 07-22-2019, 07:26 AM - Thread Starter
Quote: Originally Posted by TVRepairDubai View Post
Choosing the best AM4 board is vital in getting the most out of your new AMD Ryzen CPU – be that a first, second, or third-generation chip.
You don’t have to go for the latest X470 motherboard either, because the older 300-series boards from the likes of Asus, Gigabyte, MSI, and ASRock are still seriously capable, completely compatible, and a lot more affordable.
If anyone faces Tv issue connect
https://www.techsupportdubai.com/led-tv-repair
The Ryzen 7 3700X can reach those Core i7-9700K speeds if you give it some faster RAM to play with.
For example, AMD also sent me 16GBof G.Skill Trident Royal Z RAM, which has an XMP profile clocked all the way up to 3600MHz.
If anyone faces Tv issue connect TV Repair Dubai
Ok. Are you suggesting to not get the X570 boards?
post #14 of 18 (permalink) Old 07-22-2019, 07:30 AM
Jackie60's Avatar
Rep: 0
I'd get Ballistix Sport LT BLS2K16G4D32AESB 32 GB Kit (16 GB x 2) (DDR4, 3200 MT/s, PC4-25600, CL16, Dual Rank x8, DIMM, 288-Pin) Memory - Grey
B-die makes very little difference with Zen 2
Jackie60 is offline
post #15 of 18 (permalink) Old 07-22-2019, 07:40 AM
rdr09's Avatar
How much are those? Found it. About 220$.
I found this kit for 150$
https://www.newegg.com/g-skill-32gb-...82E16820232091
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #16 of 18 (permalink) Old 07-24-2019, 05:29 PM - Thread Starter
G.Skill F4-3200C14D-16TZR (B-die, 16GB) or F4-3200C16D-32GTZ (non B-die, 32GB) for a rendering machine with a 3700X? They're both at the $150ish range so I'm not really sure which to go with.
post #17 of 18 (permalink) Old 07-25-2019, 09:23 AM
Hardware Rep
GSKILL SUPPORT's Avatar
Rep: 6 (Unique: 6)
Depends how much memory you may use up at a time and how often, typically for that purpose it is best to go with more capacity as low available physical memory is worse than slightly lower performance memory.
GSKILL SUPPORT is offline
post #18 of 18 (permalink) Old 07-25-2019, 10:05 AM - Thread Starter
Right, that's what I went with. Thanks.
