best bang for the buck RAM for Ryzen 7 3700X system - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 07-17-2019, 04:37 AM - Thread Starter
kevindd992002's Avatar
Rep: 85 (Unique: 67)
So I'll be building an ITX system for my Sister which will be used for light/medium rendering (3D and other stuff).
Which RAM should I be getting? Initially, I plan on going with a 16GB kit that's around the 3600MHz CL14 range as that seems to have a good performace/price ratio and will help the 3700x a lot but would you guys recommend spending more for a 32GB kit? I'm all ears on this one.
Thanks.
My Rig
(14 items)
Intel® Core™ i7-8700K
ASUS ROG MAXIMUS X CODE
EVGA GeForce GTX 1080 Ti FTW3 GAMING
G.SKILL F4-3200C14D-16GTZKW TridentZ Series
Samsung 970 EVO NVMe (OS Drive)
Samsung 850 EVO
SeaSonic Platinum-760 (SS-760XP) Power Supply
Custom Watercooling Loop
Phanteks Enthoo Evolv ATX Glass
Operating System
Microsoft Windows 10 Enterprise
Dell S2716DG Gaming Monitor
Keyboard
Ducky Shine 3
Mouse
Roccat Savu
Mousepad
Steelseries Qck
kevindd992002 is online now
post #2 of 18 (permalink) Old 07-17-2019, 11:53 AM
Hardware Rep
GSKILL SUPPORT's Avatar
Rep: 8 (Unique: 8)
What motherboard model?
32GB just depends on whether you think you may use 14GB+ simultaneously
GSKILL SUPPORT is offline
post #3 of 18 (permalink) Old 07-18-2019, 01:14 AM - Thread Starter
I actually still don't have a motherboard choice but it will surely be an X570 board for the 3700X. I don't know anything about rendering but would light/medium rendering use more than 14+ GB?
My Rig
(14 items)
Samsung 850 EVO
Operating System
Keyboard
Ducky Shine 3
Mouse
Roccat Savu
Mousepad
Steelseries Qck
post #4 of 18 (permalink) Old 07-18-2019, 03:19 PM
Hardware Rep
Rep: 8 (Unique: 8)
16GB should be sufficient as you can manage and scale your work load / memory used.
post #5 of 18 (permalink) Old 07-20-2019, 11:49 AM - Thread Starter
Ok. Which ones of your 16GB RAM kits are b dies? I'm hoping to go with 3200MHz and just overclock it to 3600MHz.
My Rig
(14 items)
Samsung 850 EVO
Operating System
Keyboard
Ducky Shine 3
Mouse
Roccat Savu
Mousepad
Steelseries Qck
post #6 of 18 (permalink) Old 07-20-2019, 12:31 PM
rdr09's Avatar
Rep: 894 (Unique: 644)
Use this . . .
https://benzhaomin.github.io/bdiefinder/
Afaik, when its 3200 CL14 its B-die.
https://www.newegg.com/g-skill-16gb-...-217-_-Product
This is what i have . . . OOS
https://www.newegg.com/g-skill-16gb-...G.Skill+FlareX
Saw this in another forum.
Name:	3533 CL 14.JPG
By Built-in Benchmark Queen:
My 2.5 years old delidded 7980xe @ 4600mhz all core with 49ns memorylatency (4000c16 twekaed) is faster than 3950x max overclocked on water in every scenario. Pretty good for a ancient cpu
In gaming it has no chance vs my new 10900k @ 5400mhz and 4600c16 tweaked memory. ~35ns memorylatency.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #7 of 18 (permalink) Old 07-20-2019, 05:02 PM
Rep: 25 (Unique: 23)
For heavy 3drendering I would suggest 2x16GB 3200c16 with 3900x as more cores is probably more worthwhile than the bit higher performance per core faster RAM would bring.
For light\medium it is impossible to know exactly what that entails and if she will make use of over 16GB RAM or if it will be a waist this is something you need to check when she is working.
How much RAM is she actually using?
What is the software and how does it scale with extra cores?
Dasa is offline
post #8 of 18 (permalink) Old 07-20-2019, 06:06 PM - Thread Starter
Quote: Originally Posted by rdr09 View Post
Use this . . .
Is getting a Flare X for AMD still even a thing now?
Those questions, I can't really answer now nor can she (she's not computer-savvy). I can let her try rendering though and see how much RAM my Father's desktop (has 32GB) uses.
Sent from my SM-G950F using Tapatalk
My Rig
(14 items)
Samsung 850 EVO
Operating System
Keyboard
Ducky Shine 3
Mouse
Roccat Savu
Mousepad
Steelseries Qck
post #9 of 18 (permalink) Old 07-20-2019, 06:45 PM
Jedi Mind Trick's Avatar
Rep: 95 (Unique: 73)
Is getting a Flare X for AMD still even a thing now?Those questions, I can't really answer now nor can she (she's not computer-savvy). I can let her try rendering though and see how much RAM my Father's desktop (has 32GB) uses.
Not sure if the Flare X is a 'thing' for the 3xxx series, but I have both of those kits (3 sets of the Flare X and 1 of the Ripjaws V) and they all perform more or less identically (not sure why they wouldn't).
I am not 100% sure if B die is 'worth' it, I only got it because it was open box at my local Microcenter. I've seen 3000mhz/3200mhz 16gb kits for ~$60, while B-die is still ~$120. Yes it is better, but I don't think it is 2x better.
Jedi Mind Trick is offline
post #10 of 18 (permalink) Old 07-21-2019, 03:36 AM
rdr09's Avatar
For her use case, it is not needed.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
