3000 vs 3600mhz for $15 more? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 15 (permalink) Old 09-09-2019, 04:14 AM - Thread Starter
JMattes's Avatar
Rep: 76 (Unique: 69)
Quote: Originally Posted by The Pook View Post
could buy a used Z170 board for cheap and BCLK OC your i3 6100 if you need more CPU oomph though
probably less hassle to just grab a used CPU at that point though, there are ES Skylake i7 6400Ts and ES Skylake 6700Ks on eBay for ~$90.
https://www.ebay.com/itm/Intel-ES-i7...QAAOSwB09YIUBz
https://www.ebay.com/itm/Intel-Core-....c100005.m1851
An ES chip would be a good deal if I can overclock to the normal 4.0 clock without it heating up so much, I have an aftermarket cooler but it's not too much better than stock.
The real issue is overclocking it on my board. I read something about Z290s not overclocking and ES models not always working on Asus
This is the board I have, let me know?
ASUS PRIME Z270-AR LGA 1151
JMattes is offline
post #12 of 15 (permalink) Old 09-09-2019, 05:43 AM
Overclocker in training
ThrashZone's Avatar
Rep: 71 (Unique: 55)
Hi,
Well you could put ddr4 in it so not all that useless of a suggestion just attempting to use xmp profile is overclocking
https://www.asus.com/us/Motherboards...pecifications/
4 x DIMM, Max. 64GB, DDR4 3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
16gb kits aren't that expensive 2x8gh
32gb kits get up there a little 4x8gb or 2x16gb but not all that bad
But ddr4 at the least can be transferred to other systems even amd more easily than ddr3.
Probably find a good buy in ocn market place too memory is a tough sell.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #13 of 15 (permalink) Old 09-09-2019, 08:33 AM - Thread Starter
JMattes's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
I have an open post on the market for Ram.. we will see
Laundromatic - Feb 2012 TC Champs!
Laundromatic - July 2012 TC Champs!
JMattes is offline
post #14 of 15 (permalink) Old 09-15-2019, 03:17 AM
ahnafakeef's Avatar
Rep: 63 (Unique: 46)
Quote: Originally Posted by Dasa View Post
All the speeds you listed are probably running Hynix chips and can probably all OC to the same speed as each other.
They all have a similar latency at there rated speed.
Using this rough calculation they look the same but depending on sub timings they will be different and the 3600 kit may have the edge.
3000\15=200
3200\16=200
3600\18=200
The last kit will also have a little more bandwidth but that alone may not be enough to justify the price increase.
If you are willing to OC this $75 kit using micron chips should hit 3600+ with tighter timings than the kits using Hynix chips
https://www.amazon.com/Ballistix-Spo...gateway&sr=8-1
If the G.Skill rep pops in do you have any kits using Micron E-die priced around $75?
A few questions:
1. So the higher the value of (speed/latency), the higher the performance?
2. Does it also imply that 3000 at 15 will perform the same as 3600 at 18, since their (speed/latency) is the same?
3. Is (speed/latency) the best measure of evaluating memory performance? Or are there other factors that I should account for?
Thank you!
4K60
(14 items)
Intel Core i9-9900K
ASUS Maximus XI Formula
ASUS ROG Strix GeForce RTX 2080Ti
Corsair Dominator Platinum RGB 32GB (2x16GB)
Samsung 970 Pro 512GB
Samsung 970 Evo Plus 1TB
Corsair AX1200i
Corsair Hydro Series™ H115i RGB PLATINUM 280mm
Corsair Crystal Series 680X
Operating System
Microsoft Windows 10
Benq BL3201PT
Keyboard
Corsair Vengeance K95
Mouse
SteelSeries Rival 100
Audio
Bose QuietComfort 35
ahnafakeef is online now
post #15 of 15 (permalink) Old 09-15-2019, 02:24 PM
Rep: 22 (Unique: 21)
Yes so 3200c14 =228 which is faster but that calculation is just a very rough guideline.
Higher frequency will bring more bandwidth which is of some benefit especially with higher core counts fighting over the same bandwidth.
But latency is a balance of timings and frequency and is probably the most important for software that is not fully multithreaded.
With AMD higher frequency also brings down the latency of inter core communication.
Some good info on RAM speed with AMD in a recent gamers nexus test
Dasa is offline
