What memory speed is compatible with 2nd gen Ryzen? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 10-17-2019, 01:57 PM - Thread Starter
Rep: 0
So, everybody says "RYZEN NEEDS FAST MEMORY, AT LEAST 3000MHz!!!", but AMD says, that 2nd gen ryzen supports max. 2933MHz. So I want to ask: What will happen if I put there for example a 3200MHz module? Will it work? If yes, then at what speed?
JENYK KONYK is offline
post #2 of 11 (permalink) Old 10-17-2019, 02:14 PM
The last VRM burner
Rep: 33 (Unique: 18)
It will explode and take your pets hostage.
Ryzen 2 3200mhz in Google and check, damn...
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
KHX24C11T3K2/16X 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
SeaSonic Focus Plus 750W
Raijintek Tisis lapped+ Thermal Grizzly Kryonaut
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #3 of 11 (permalink) Old 10-18-2019, 12:33 PM - Thread Starter
Rep: 0
I checked and I saw what I saw. 3rd gen supports 3200MHz, 2nd gen only 2933MHz. But anyways, what will happen if I put there faster memory than the CPU should support?
post #4 of 11 (permalink) Old 10-18-2019, 12:46 PM
sudo apt install sl
WannaBeOCer's Avatar
Rep: 178 (Unique: 123)
Any speed above the stated supported speed is considered overclocking. Good luck and hope you have a chip with a decent IMC.
Silent
(20 items)
Core i9 9900K... CoffeeTime! @ 5.1Ghz w/ 1.36v
Maximus VIII Formula
Radeon VII @ 2100Mhz/1250Mhz w/ 1218mV
TeamGroup Xtreem 32GB 3200Mhz CL15
HP EX950 2TB
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
EK-Vector Radeon VII - Copper + Plexi
Thermaltake Core X5 Tempered Glass Edition
Operating System
Clear Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is online now
post #5 of 11 (permalink) Old 10-18-2019, 12:46 PM
Not New to Overclock.net
Diablosbud's Avatar
Rep: 80 (Unique: 63)
The official support for Ryzen 2000 is only 2933 MHz. But that doesn't mean you can't run higher, it's just not guarunteed.
Worst case the 3200 MHz doesn't run and you just return it. But it will probably run fine.
AMD Ryzen 5 1600 3.875 GHz
ASUS Prime X370-Pro
EVGA GTX 1080 FTW2 2114 MHz 356 GB/s
G.SKILL 2x8GB 3126 MHz 12-13-13-32-1T 48 tRC
Samsung 850 EVO 500 GB
Seasonic Platinum 660XP
Noctua NH-D15
2 x Cougar CF-V12HP Top Intake
Noctua NF-F12 2000 RPM Rear Exhaust
2 x Phanteks F140SP Front Intake
Thermal Grizzly Kryonaut TIM
Corsair Carbide Air 540
Operating System
Windows 10 Enterprise 64-bit
ASUS MG279Q 1440p IPS 150 Hz OC
Keyboard
Ducky Shine 5 MX Brown
Mouse
Logitech G203 Prodigy
Audio
Schiit Asgard 2
Audio
OPPO PM-3
Audio
HIFIMAN HE-560
Audio
Cambridge DacMagic 100
AMD Phenom 9650 2.83 GHz
Foxconn A74MX-K
OCZ 1x1GB DDR2 533 MHz 5-4-4-15-1T 15 tRC
Samsung 840 Pro 128 GB
OCZ StealthXStream 2 500W
Ryzen Wraith + Zip Ties
Corsair AF140 Quiet Edition
Diablosbud is offline
post #6 of 11 (permalink) Old 10-18-2019, 12:48 PM
Retired Staff
JedixJarf's Avatar
Rep: 305 (Unique: 244)
From what I've seen most chips will do 3200 on the mem.
JedixJarf is offline
post #7 of 11 (permalink) Old 10-18-2019, 12:57 PM
rdr09's Avatar
Rep: 867 (Unique: 634)
I have a mdie 3200CL16 and bdie 3200 CL14 kits from gskill. Both can oc to 3733 CL16/CL14 on Gen1+ and Gen2 using DRAM Calculator. I use DOCP and set them at 3333 MHz.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is online now
post #8 of 11 (permalink) Old 10-19-2019, 03:31 PM
Rep: 0
This kit works like a charm (samsung b die) i had them running 3333MHz cl 14 14 14 28 42 and tight subtimings on a First gen ryzen 1600x.
https://www.amazon.com/G-SKILL-Flare.../dp/B06XFT7DF9
Tapper is offline
post #9 of 11 (permalink) Old 10-20-2019, 01:50 PM
wingman99's Avatar
Rep: 62 (Unique: 45)
Purchase some G.SKILL 3200 AMD memory, then overclock after testing a 3200 speed.
i5 8600K OC 5.0GHz
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB F4-3200C14D-16GVK XMP Speed 3200 14-14-14-34
EVGA GeForce RTX 2070 XC ULTRA GAMING
ASUS VG279Q 27" 1920x1080p 144Hz IPS panel G-Sync compatible
wingman99 is online now
post #10 of 11 (permalink) Old 10-22-2019, 05:54 PM
Rep: 22 (Unique: 21)
Even 2933 is not guaranteed if you are running 2x16GB 4x8GB or worse yet 4x16GB but with a good MB and latest BIOS the odds are better than they were.
Dasa is offline
