Gskill Aegis 3000mhz - Default XMP not stable - Overclock.net - An Overclocking Community
post #1 of 47 (permalink) Old 11-01-2019, 08:42 AM - Thread Starter
marto7's Avatar
Rep: 0
From soon i am with Ryzen 5 2600 with ASrock X370 Gaming K4 and 2x8gb GSkill Aegis 3000mhz. Few times saw system freezing for 1 secont and then continued working.Im with last bios version and using default 3000mhz XMP profile of rams, so i decided to run memtest and saw Test 6 and 8 was full of errors.First higher voltages for ram and Soc, because read that helped other peoples, but sometimes i get no errors, sometime gets few. But not as many as default xmp voltages - 1.35V. First test with 1.35 received 50 errors on test 6 and 150 on test 8. So in the final i lowered to 2933MHz and used 1.4v for rams, but not sure if this is the best option, since im not understanding these SOC, VDDP and other voltages. Posting screens from BIOS.
marto7 is offline
post #2 of 47 (permalink) Old 11-01-2019, 09:07 AM
OG AMD
Redwoodz's Avatar
Rep: 600 (Unique: 465)
Does it pass memtest using Auto instead of XMP in memory settings? (usually defaults to 2400MHZ). You may have a bad stick so verify that first.
https://valid.x86.fr/cache/banner/4d8m5e-6.png
https://valid.x86.fr/cache/banner/bs72bx-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Trident Z D-die
TeamGroup Excalibur
GSKill Ripjaws PS850G
AMD FX Vishera 8350
ASRock Extreme 9 990FX
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Samsung Series 9 27"
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #3 of 47 (permalink) Old 11-01-2019, 09:27 AM - Thread Starter
marto7's Avatar
Rep: 0
Loaded UEFI defauts and in the bios saw its 2133mhz, not 2400. Run the test and made 2 passes without any errors. Whats next ? Firstly i saw other peoples have same problem like me, not running stable with default XMP profiles of their DDR4 ram (not same brand and model). What should i try now?
marto7 is offline
post #4 of 47 (permalink) Old 11-01-2019, 12:00 PM
OG AMD
Redwoodz's Avatar
First you have to understand XMP is an overclocked profile, you always may need to adjust voltages pass stock to be stable.
Then I would recommend downloading and installing DRAM calculator for Ryzen
https://www.overclock.net/forum/13-a...ram-bench.html
Further info here
https://www.overclock.net/forum/10-a...ty-thread.html
More than likely the secondary timings need adjusting. Hope this helps.
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
TeamGroup Excalibur
AMD FX Vishera 8350
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
Optical Drive
Samsung BD
Zalman 9900MAX
Fractal Design R3
Operating System
AOC 22" LED
Keyboard
Logitech
Other
Redwoodz is offline
post #5 of 47 (permalink) Old 11-01-2019, 12:28 PM
21Dante's Avatar
Rep: 1 (Unique: 1)
Could be possible that you have a potato imc.
21Dante is offline
post #6 of 47 (permalink) Old 11-01-2019, 01:16 PM
i n f a m o u s's Avatar
Rep: 40 (Unique: 32)
I ran into a similar issue with my memory kit not running stable when I first purchased them. They wouldn't run stable in dual channel mode or in XMP, so I tested each stick out individually and found out one of them was the culprit.
I'm content
(14 items)
Dell XPS 13 9360
(7 items)
AMD Ryzen 5 2600
msi B450I GAMING PLUS AC
msi GeForce GTX 1070 Aero ITX OC
G.SKILL Trident Z 16GB DDR4-3200MHz
SAMSUNG 970 EVO
Western Digital WD Black
CORSAIR SF450
Noctua NH-L12S
NCase M1 V6
Operating System
Microsoft Windows 10 Pro
LG 27GN850-B
Keyboard
Ducky One TKL RGB
Mouse
Logitech G203 Prodigy
Audio
CORSAIR HS60 PRO SURROUND
Core i5-7200U
intel HD Graphics 620
8GB LPDDR3 1866MHz
TOSHIBA SG5
Western Digital My Book
Operating System
Windows 10 Home
13.3” FHD InfinityEdge touchscreen
i n f a m o u s is offline
post #7 of 47 (permalink) Old 11-01-2019, 02:33 PM - Thread Starter
marto7's Avatar
Rep: 0
Tried Ryzen Calculator, but received a lot of errors with Calculate SAFE.Some of values are a lot lower, than default XMPs. So next thing that i tried was default timings with manual voltages, and passed test 6 and 8 without any errors.Posting pictures of the settings that i used. Any recommendation ? That night i will change the memtest to 10 pass and will leave it testing all night everything.
MB: ASRock X370 Gaming K4
CPU: Ryzen 5 2600 + Thermaltake Sonic Tower
RAM: 16GB GSkill Aegis 3000mhz
GPU: Asus GTX 1070 Dual
PSU: Corsair CX600
SSD: Samsung 860 Evo
marto7 is offline
post #8 of 47 (permalink) Old 11-01-2019, 02:53 PM
Turtle Lives Matter
damric's Avatar
Rep: 433 (Unique: 333)
You probably need to get SOC voltage up quite a bit. Also be sure you follow EVERYTHING on that calculator.
Borg Cube
(15 items)
Ryzen RGB AF
(17 items)
Polaris AF
R5 3600
X470 TAICHI
Gigabyte RX Vega 56 Gaming OC
Ripjaws V 4x8GB
Silicon Power A80 NVMe
EVGA SUPERNOVA G3 750W
TCP-612
2x EVGA FX 120mm Fan
2x Cooler Master MasterFan Pro 140 Air Flow
HAF XB
Operating System
10-64 PRO
Samsung 4K 60Hz
Keyboard
Logitech G105
Mouse
Devastator II
Audio
Logitech Z623
Ryzen 5 1600 (12nm)
X470 Pro Carbon
Vega 64
OLOy WarHawk RGB 4x8GB
SUPERNOVA G3
Wraith Prism
Metallic Gear Skiron 120mm x4
Metallic Gear Skiron 140mm x2
Phankteks Eclipse P400A
Operating System
10 Pro
Samsung 58" UHD
V7 L238E-2N
Keyboard
Rosewill NEON K85 RGB
Mouse
Logitech M570
Audio
Vintage Sony
R5 1600 (12nm)
B450 Steel Legend
XFX RX 570
OLOy WarHawk 2x8GB
Silicon Power A80
Rosewill CAPSTONE
Wraith Prism
Cooler Master Jet Flow 120mm x2
Cougar MX330-G
Operating System
10 Pro
ASUS 1080p 23"
Audio
Xonar SE
Audio
Logitech
damric is offline
post #9 of 47 (permalink) Old 11-01-2019, 03:37 PM - Thread Starter
marto7's Avatar
Rep: 0
I copy everything from the calculator and got errors. So tried again with default timings and the settings in my previous post.Will try to lower timings a little.
What exactly is SOC voltage ? And where i need to correct it for make the RAM more stable, because i see to values - (1st is SOC voltage (VID), and 2nd is VDDCR_SOC VOLTAGE offset). Which one for what it is ? Thanks
PSU: Corsair CX600
marto7 is offline
post #10 of 47 (permalink) Old 11-01-2019, 04:16 PM
Turtle Lives Matter
damric's Avatar
In your BIOS. The VID is the programmable request voltage and the offset is self-explanatory. It works just like Vcore and offsets and Vdimm and offsets. You're lucky to have that much voltage control. My x370 motherboard only lets me change offsets!
But yeah if those SOC voltages are set to auto, that's most likely the problem. SOC is the memory controller.
Borg Cube
(15 items)
Ryzen RGB AF
(17 items)
Polaris AF
R5 3600
X470 TAICHI
Ripjaws V 4x8GB
TCP-612
HAF XB
Operating System
10-64 PRO
Samsung 4K 60Hz
Keyboard
Logitech G105
Mouse
Devastator II
Audio
Logitech Z623
Ryzen 5 1600 (12nm)
X470 Pro Carbon
Vega 64
SUPERNOVA G3
Wraith Prism
Operating System
10 Pro
Samsung 58" UHD
V7 L238E-2N
Keyboard
Mouse
Logitech M570
Audio
Vintage Sony
R5 1600 (12nm)
B450 Steel Legend
XFX RX 570
OLOy WarHawk 2x8GB
Silicon Power A80
Rosewill CAPSTONE
Wraith Prism
Cougar MX330-G
Operating System
10 Pro
ASUS 1080p 23"
Audio
Xonar SE
Audio
Logitech
damric is offline
